Question about Hunter 52" Ceiling Fan With Light And Remote Control
Electrical box not working
I tried to hook up my new ceiling fan.  previously had a dome light.  hooked everything up correctly but I didn't put electrical tape on one of the wires (because I was just testing it out... stupid).  the hot wire hit the metal ceiling fan box and sparked. now the wire doesn't work.  tried hooking up the old dome light and nothing. the circuit breaker is working properly.  Light is on two light switches, a dimmer and a regular switch.  i have i hooked up to a extension cord right now so please help.
    Problem Solver:
  • 6 Answers
Unfortunately it sounds like the main electic wire is shorted out. Not the one to your fan, but the one that provides the power supply FOR the fan. The only way i know to fix this is to get an electrician. I am certain the wire needs replacing.
Posted on Nov 29, 2008
I have a ceiling fan with 3 lights. We do not use the remote control and did not install it. The lights stopped going on today. The fan works, but the lights do not. I have tried changing bulbs, but...
Sounds like a loose wire. If you turn the lights on via a wall switch or a pull chain, I would start where you hooked the wire for the lights to the house electricity, most likely where the fan meets the ceiling. Pull the "bell" part of the fan down that covers the ceiling box and see if there is a loose wire inside. There should be a plastic cap called a wire nut that covers the wire connection. Make sure it is secure and if possible, put some electrical tape around it. Please let me know if you have questions.
Sep 12, 2010 | Vacuums
How to install a ceiling fan
very simple make sure power is off take old one down and hang new one hook up wires black to black white to white and ull have probably a blue wire from light hook it up to the black wire also then screw fan to the electrical box and lastly put on blades and sometimes u have to balance it with lil weights this is a pain and tedeous but usually dont have to do this turn ur power on and check
Feb 24, 2010 | Hampton Bay 24002 Ceiling Fan
Minka F719 Lavery Wired fan and fan works but light does not come
The light leg should be hooked to a power source. If you have a separate wire from a wall switch, that's where it should be hooked. Otherwise, you can hook it to the fan leg and operate the light from the switch on the fan.
Jan 31, 2010 | Minka F719-TSP Treville Tuscan Patina...
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
Remote is not working and fan won't turn on
Take the fan down. Remove the blades, by pass everything, by cros wiring the fan using a plug in to see if the motor is working. If it works then you have a defective remote.
Jul 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Lights don't work
Don't know if I can solve it, but it is a Home Depot private lable. Try googling it and see if you can get some info. I suspect that you either hooked it up wrong, or it has damaged contacts.
Mar 28, 2009 | Hampton Bay 24002 Ceiling Fan
Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Mar 15, 2009 | Hunter Low Profile III 20807 Ceiling Fan
I am having difficulty wiring my hunter ceiling fan
For the fan alone, you hook the black wire from the fan to the black wire in your electrical box; white to white. If there is a red wire it's for the light, hook it to the black wire from the box. If you let us know what wires are available in your box and what's coming out of the fan and whether the fan has a light and whether the box is wired for separate lighting, we could go a long way towards solving your problem in more definitive terms. Hunter is a premium fan, their package directions are good.
Dec 30, 2008 | Hunter 52" Ceiling Fan With Light And...
Hampton Bay Model 73554 Ceiling Fan
Its not hooked up right.
Black is hot , Black to Black always.
green is ground , usually the green grounds to the mounting screws without any connections needed.
the rest are variable
you can have only 1 or 2 extra wires left.
one to fan , one to lights,
either way they go to white (neutral)
Do you have a dual wall switch with lights and fan or are you using the remote?
How many wires and what color are they that comes out of the ceiling box?
Jan 26, 2008 | Hampton Bay 73554 Antigua Ceiling Fan
Dryers Logo
81 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
