Question about Classe CAV-500 5-Channel Amplifier
Channel cuts out
I have a CAV-180 which has had an intermittent problem for several years, and now seems to behave more consistently: whenever the amp has been powered on for 15 minutes or more one of the channels cuts out completely, no sound or distortion. All other channels behave fine. If I turn the amp off for an hour or so and then turn it on that channel will work perfectly for the next 15 minutes, then turn off. I presume the problem has something to do with the temp of the unit when it has been on for awhile but would like anyone's expert help if this can be repaired at home or I need to ship it off. Thanks !!
    Problem Solver:
  • 11 Answers
I suggest you switch your speakers and test again , if the same happens , ship it it can only be an output problem >>>>Good luck
Posted on Mar 19, 2007
Why do leds flash randomly on faulty mackie dfx-6 ?
Genuine and consistent random flashing is normally a cable fault if is the main VU graph but there are other symptoms as well. If is the O/l (Clip) or Solo Leds on a channel strip have you checked for earth loops etc? Does it do it all the time or only when there's a signal? Which Leds are flashing and is there anything else that is not behaving correctly? It would seem if you can get a repair shop to have a look this would be your best bet.
Jul 27, 2014 | Mackie 1604 Vlz3 16 Channel Mixer
One channel cuts out
check for corrosion or dirt around the screws that hold that board in place. the screws provide ground at several different places on the pcb that are not otherwise connected. good luck
Jan 05, 2014 | NAD Audio Players & Recorders
Kicker impulse 325xi 2 channel
have this amp, had this problem, had to crack it open to re-solder the RCA input jack as the soldered mount connections failed. Seems like the issue was the input spiking when those connections moved around, or it was caused by poor connection between the mosfets and heat-sink(causing near-instant overheat condition). There are 4 or 6, don't remember. They were attached to 2 slide rail looking pieces of aluminum that fit in the shell. I broke them free (as it made the job faster) and reattached with minimal heat-sink compound. Thing runs like a champ now. Get another 20 years out of it.
Oct 30, 2013 | Car Audio & Video
I have a KIA sephia 2000 it does not pick speed behaves as if it cuts the gas ..what is the problem with it?
Do you not have a repair shop, you go to several times a year?
When you step out of your car at a repair shop & are greeted,
do you immediately ask ,what is wrong with it?
No, you go for a road test with you driving & the mechanic
riding ,to experience the symptoms ,or you don't leave the car there
Sep 23, 2011 | Kia Sephia Cars & Trucks
I have a Onkyo TXSR-574 Receiver. After playing for a period of time (its never consistent) the receiver will cut off. You can cut it back on and it will play about two seconds and cut off again. It's...
The amp is protecting itself from something either real or perceived by the protection circuitry.
Check your speaker impedances to make sure they are all what they are supposed to be (IE, 4 or 6 or 8 ohms depending on the speakers and arrangement).
Feel the amp to see if it's warmer than it should be - blow any dust out of the heatsinks.
when it cuts off, try spraying freeze mist on the components until it turns back on and behaves - accurate use of freeze mist can diagnose a thermal problem easily.
Look for bulging or leaking capacitors anywhere in the circuity.
Failing that, it'll have to go into a shop.
Feb 22, 2011 | Onkyo TX-SR574 7.1 Channels Receiver
2001 Windstar 3.8 missing + cutting off. Was getting p170, p171 intermittently for a while then noticed driving issues when p303 & p304 codes started appearing. I read several forums and cleaned EG...
You may be headed for the notorious 3.8l head gasket failure. Just had the head gasket replaced in my 2000 Windstar and it is performing normally.
Mar 24, 2017 | Ford Windstar Cars & Trucks
Intermittent shorts in a Crate Limo TX50DE Guitar
turn that ****** on and get a can of freeze spray. coming and going type issues is usually related to a failing electrolytic capacitor. there may also be a bad mosfet, rectifier, diode, etc. i would be suspect to caps. schematics probably only available thru crate and you have to pay a couple bucks, but trust me its worth the couple bucks spent and having it on its way than wasting hours online not getting anywhere. by the way i checked my sources and came up with nada.
Feb 20, 2009 | Crate SPA1600 Power Amplifier - SPA Series...
Alesis RA500 amp - channels crackle, distort, cut out
you have a problem in output stage and output ic need to check or replace.
Jan 27, 2008 | Audio Players & Recorders
Classe CAV-500 5-Channel Amplifier Logo
173 people viewed this question
Top Classe Audio Players & Recorders Experts
Are you a Classe Audio Player and Recorder Expert? Answer questions, earn points and help others
