Question about Equator EZ 3600 CEE Front Load Washer / Dryer
Equator Wash dial just spins
It starts to work then....click click click click. Repairman tried to reset all the stops but still nada......control board???? EZ3612CEE Is it cheaper to just buy a new machine?
  • 2 more comments
  • lgb00 Dec 01, 2008
    Im told click click click...then count the number of times the light flashes the number corresponds to the problem IE my case 13 so its a thermostat.......thats what equator told me.....very good service consult there.
  • Anonymous Jan 25, 2009
    fyi, appliance desk was good at consult. Repair ordered a new thermostat (turns out there are 2) but a wire was off so reattached and shazam...works (for now)
  • Anonymous Feb 18, 2009
    Same problem: program button click click click... and keeps on turning. I cannot find a repairman in NYC (!) to service this brand. When calling Equator in TX... no answer.
  • mr4244 Apr 09, 2009
    my water doesnt drain
Just bought this ez 3600cee it says its ventless ,but yet came with
a venting duct work why?
Posted on Jan 25, 2009
Equator ez2512 combo washer dryer won't go to spin cycle and drain, it fills with water agitates then dial starts clicking around, it stops and fills some more but never spins or drains. What is the f
Check the outlet filter isn't blocked. The machine will only go in to spin if the water level is low enough. So you are left with the outlet pump not working or if you can hear the pump trying to work then you have a blockage. If all this is ok then I might have to suggest that the mechanical controller is goosed (The dial which you say is clicking around). I have taken a few of these to bits in the past. They are not really designed to be repaired (Surprise surprise) but you can repair them if you take your time. They are mainly just a small electric motor which by a series of gears moves a contact plate around to perform the required functions. Good Luck
Mar 15, 2014 | Equator Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining even after reset attempts
Did you check the most obvious item - the motor and belt that spin the drum and powers the pump assembly
Sep 12, 2017 | Equator EZ 3600 CEE Front Load Washer /...
What does E27 on display mean
Bosch washers come with built-in sets of error codes used to diagnose and correct common problems. The E27 code isn't often listed in Bosch manuals but relates to the washer door lock
The E27 error flashes on the washer LCD screen and stops the current load. Unplug your washer for 30 minutes and then plug it back in to reset the code.
Open and close the door two or three times to reset the sensor. Sometimes the door has been closed too hard and the sensor reading fails.
Mar 10, 2011 | Bosch Washing Machines
EQUATOR 3612CEE WASHER DRYER/NOT DRYING
First of all you may want to reset the unit, let me know if you need the procedure and after reseting if the unit the washer knob may go round and round all by itself, if this happens the door mode light will flicker in a particular sequence which once once counted we can understand exactly which part in the machine has malfunctioned which once replaced the unit should start to work properly.
Jun 08, 2008 | Equator EZ 3612 CEE Front Load...
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
The cycle knob just starts clicking through the cycles
I am having the same problem with mine. Call customer support and was given voice mail.
Dec 13, 2007 | Equator EZ 3612 CEE Front Load...
Equator EZ 3600 CEE Front Load Washer / Dryer Logo
206 people viewed this question
Top Equator Washing Machines Experts
Heartland Ho
Level 1 Expert
Dan Webster
Dan Webster
Are you an Equator Washing Machine Expert? Answer questions, earn points and help others
