Question about Epson EMP-TW10H Multimedia Projector
Epson TW10 Projector displaying "error in epson cinema filter"msg
Will only work in cinema dark mode, now and change to normal daytime modes result in this error message, do you know what is the best thing to do (is there a part I can buy etc) as I have googled the world with no response . .
  • 1 more comment
  • catrescue Nov 29, 2008
    No lights flashing on panel, works normally etc, just not in normal mode just cinema black. The error message that comes up is on the actual video screen when I try and display in any mode that isnt cinema black
  • Robert Borjesson Dec 28, 2008
    The same error appeared after approx 150h of use.
    The projector have only been used short periods of time and always been shut down properly.
  • wfraga1818 Jan 04, 2009
    I had the same problem in TW1000( epson homecinema 1080 ), used by 30hours !! show the "error in epson cinema filter" always !! and in Brazil don't have assistence to this model !!
    Genius:
  • 1,447 Answers
Hi
What is the error message? Are there lights flashing on the panel? Keep us posted. thanks!
Posted on Nov 29, 2008
Epson powerlite home cinema 8100 picture quality problem?
It can be a bad lamp. Under menu setting, select Dynamic or presentation. Those are my favorite picture settings.
Aug 30, 2014 | Epson Powerlite Home Cinema 8100 Home...
Epson powerlite home cinema 8100 problem with picture
Dark pictures after a lamp change normally indicate that the lamp isn't aligned properly, or that it has been touched with bare fingers and caused a black mark, or it's an inferior (budget) lamp.
Aug 30, 2014 | Office Equipment & Supplies
Epson projector is stuck in start up mode
1, the lamp is ok
2,the lamp ballast is ok
3,seems that the power supply or mother board is defective
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color
wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mobile: 0086-13178867858
Wechat ID: 008613178867858
Whatapp ID: 008613178867858
Skype: lampdeng@hotmail.com
http://www.lampdeng.com
Dec 24, 2012 | Epson ELPLP69 - V13H010L69 Projector...
I have the same issue. the light just beneath the power light is flashing red in one second intervals. I called Epson and they said that it was an internal issue. I think the apeture isn't opening...
I've seen this problem many times. You can get this status from two causes. The most common being the Error 08 - Cinema filter. There is a pinion gear inside the motor housing that begins to slip and fails to move the filter. I have successfully pulled the gear and put loctite gel on the shaft where the pinion sits and let it cure. After the bold is complete, the gear no longer slips, the filter moves, and the pre diagnostics passes.
The only other solution is to replace the motor/transmisson assy.
The second is error 0A Auto iris error. Not as common but both give the same result.
Jan 19, 2011 | Epson PowerLite Home Cinema 1080 Projector
I have an Epson EMP TW10. I have replaced the lamp but it will not illuminate. The temperature warning light flashes red permanently after switch on.
Hi
Can you check the filter for the projector, looks like a screen underneath or on sides, open and clean it up.
Hope this helps
Mar 26, 2010 | Epson EMP-TW10H Multimedia Projector
MISSING CABLE
you can buy any vga cable at any electronics shop in your area. usually epsons pin configuration is just standard so any vga cable will do. also try to look for it in any computer surplus store (if theres any). LCD TV nowadays has a bundled vga cable that will work with your projector too.
Jan 31, 2009 | Epson (ELPLP25H) Projector Lamp for...
EPSON EMP TW2000 COLOR MODE QUERY
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
Jerry
Lampdeng Limited
Oct 23, 2008 | Epson Office Equipment & Supplies
Epson EMP TW 10H spares
i can understand what is your mean
Aug 22, 2007 | Epson (ELPLP25H) Projector Lamp for...
Epson EMP-TW10H Multimedia Projector Logo
902 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
