Question about Compaq Presario 2100T Notebook
Screen blank when fully open.
When I open my laptop fully, nothing shows on the screen. When the cover is open 3 - 4 inches, my screen fully displays. Tried pushing small button under corner of laptop, no change. Removed cover and no visible breaks in any wiring. Anybody have this happen or have some suggestions where to check further?
HP S230 monitor won't connect to my Dell Inspirion 15 laptop via DP to HDMI cable
Hi Msdco1, 1st try fixing your laptop..... The link below is a YouTube video showing 3 ways on how to fix your laptop, Also there's videos down the right side of the link that may help as well, I hope this helped....CHEERS..
ALL LAPTOPS DISPLAY NOT COMING ON BLACK or BLANK SCREEN DIM DISPLAY
May 10, 2016 | Dell Inspirion 15
Laptop is dead, will not post. Battery charge led is lit. Tried removing battery and discharging ps, no luck. Suggestions?
Hi Anonymous, The link below is a youtube video showing 3 way on how to fix your laptop, Also there's videos down the right side of the link that may help as well....CHEERS..
Apr 24, 2016 | ASUS K53U-DH21 15.6 inch AMD Fusion E-450/...
Display shows a blank area in the right lower corner, of around 2 to 3 inches
You have dead pixels on your screen. You will have to replace it. I suggest you give it to Dell Service Centre.
Nov 18, 2010 | Dell Latitude D610 Notebook
My lab top when restarted it beats 3 times, screen blank
Nothing to worry, Open your laptop from the back side.Remove the RAM  and reinsert it.
Your system will work fine.
Rate this solution.
Dec 27, 2009 | HP Pavilion dv9700t Notebook PC
I turned the phone on and there is nothing on the display. I can hear sounds but nothing shows up on the display. No menu...nothing...just a blank screen. This is on a Sidekick 3.
IF you sidekick 3 screen is blank then the lcd needs to be replaced. Replacing the Sidekick 3 LCD screen is pretty easy and cost about 25 dollars if you buy it from ebay.
Here is a guide for it Sidekick 3 LCD Flip Screen Replacement
and here is a link to the screens
Buy a replacement Sidekick 3 LCD screen.
Nov 06, 2009 | T-Mobile Sidekick® 3 Cellular Phone
No display in Acer aspire 4520g laptop
Have your laptop check up the technician, it has somethingt to do with your video card
Nov 05, 2009 | Acer Aspire 4520-5582 Notebook
I need instructions for installing Acer keyboard a2797.001
I'm not sure which model Acer you have but the pic of the keyboard looks simular to the Acer Extensa or TravelMate series laptops. If so, there's a plastic cover just above the keyboard, but under the screen that covers the display hinge. Open the display fully and gently pry up on the hinge cover. Then slide the horizontal bar next to the opening about a quarter of an inch and lift it off. You should then be abl to pry up on the keyboard to remove it.
Sep 08, 2009 | Acer KB.A2707.001 Keyboard
Black Screen
Have you tried cycling all the way through the options with the F4? Most laptops toggle in a manner similar to: 1) Laptop only, 2) External display only, 3) Both displays, 4) Back to Laptop only (cycle repeats).
Jun 28, 2009 | Toshiba Satellite L300D-ST3501 Notebook
Blank screen during POST and vista startup
The screen is going bad. Take it to a reputable repair person for a a electronics check out.
Mar 26, 2009 | HP Pavilion dv1000 Notebook
Compaq Presario 2100T Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
