Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
What is the size & pitch of the Wild Thing?
I bought a dremel chain saw sharpening attachment kit and not sure which grinding stone to use. I am not sure of the chain size/pitch.
  • sheldonc2 Mar 17, 2009
    trying to find the size and pitch of the chain for the Poulan Wild Thing. I am not sure what stone to use.
    Top Expert:
  • Poulan Master
  • 78,267 Answers
Moto tool makes a set of grinding stone wheels with the 3 common sizes, it is the best set up around and cheap to buy.
Posted on Nov 29, 2008
What is the file size (to sharpen chain) for a Poulan Pro 295 46cc?
I am pretty sure this machine ran a .325 pitch chain, so the file size is 3/16, if it is running 3/8 low profile chain ( 91 ) it will be a 5/32 file, the pitch should be marked on the bar .
Sep 16, 2011 | Poulan Pro Chain Saw 46cc 20"
Sharpen chain with an electric sharpener
Having cut a lot of wood when I was younger I know from experience just how important a sharp chain is.You need a guide so all the teeth cut at the same angle.If I were doing it now I would use an outfit like this.You will find that when your out cutting that it won't take much to dull a chain and that cuts in to the sprocket that turns the chain.A sharpe chain will throw big chips whill a dull chain will through out small chips because it's scratching the wood instead of cutting it off.We just used files without guides.I never did get the hang of that But my partner did.This is what I would use today.By the way never use a chain saw alone ,that way you have some one to help you if something goes wrong. I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.I am not endorsing this site just the type of tool.
right-tool_2143_15026
right-tool_2147_24719010trans_1x1.gifright-tool_2147_24738108
The Precision Granberg Chain Saw Grinder combines the features of the Grind-N-Joint with the accuracy of the File-N-Joint. Easily clamps onto the saw bar for fast, precise, and stable chain saw sharpening.
This grinder requires threaded stones. SEE BELOW.
GI-G1012Ctrans_1x1.gifRegular: $70.00trans_1x1.gifSpecial: $59.94trans_1x1.gif
Calculate Shipping Rates Zip Code: Country:
trans_1x1.gif Granberg G417-3 5/32" Grinding Stones (Threaded # 31399)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G418-3 3/16" Grinding Stones (Threaded # 31401)trans_1x1.gif3-Pack
trans_1x1.gif trans_1x1.gif Granberg G419-3 7/32" Grinding Stones (Threaded # 31400)trans_1x1.gif3-Pack
GI-G419-3trans_1x1.gif$9.27
May 27, 2011 | McCulloch 14" Electric Chain Saw Mcc1514
I need help with chain sharpener #193020
If you have a Dremel tool, Dremel has an attachment to sharpen all types of chain saw chains and lawn mower blades. If you don't have a Dremel you may to consider getting one.
May 16, 2011 | Northern Tool Garden
Looking for sharping stone from efco fl64 /8 chain
There are multiple chain sizes 1/8", 3/16", 1/4", 5/32", 7/32" and 3/8" chains so the /8 chain number has me guessing. After the qurestions below, here is my best guess.
Also is this for a chain grinder?" or
Are you looking of a hand held type stone?
Aluminum Oxide Chainsaw Sharpening Grinding Stone
or Ceramic stone?
I will assume that your looking for aluminum oxide stones at this time.
http://www.oregonchain.com/homeowner/products/accessories/replacement_stones.htm
This is wide selection of sharpening stones.
You can also use hand held chain sharpening files of the same size that have shapening angles marked on the file set fixture.
Hopefully you have a sharpening guide that will keep your angles correct while shapening.
A safety note: Improperly sharpened chainsaw blades can be very dangerous to the user.
Thanks for using FixYa.
Kelly
Mar 10, 2010 | Oregon Scientific Garden
What size file do i use for a Ryobi chainsaw model PCN4545 to sharpen the chain
The standard chain file should fit it. It is about 3/16 dia. I found the dremel to work 10 times better, they have a little stone bit just for chains. Eventually, you have to take it in for sharpening, it will set all the teeth the same.
Feb 24, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Degree of pitch when sharpening chain on Shindawa chain model 360
It is dependent on the manufacturer of the chain not the saw.
Download this and look carefully at page 9.
http://www.northerntool.com/downloads/manuals/193020.pdf
I think it is exactly what you requested.
I hope you find this helpful.
Lou
Jan 15, 2010 | Garden
Chain saw cuts at an angle
I have seen this problem of a chain saw cutting at an angle brought up again and again on forums, and result in a variety of answers about sharpening the chain, or replacing the bar and/or chain. In a number of these requests for solutions, none of the advice has solved the problem. I have used chain saws for about 45 years now, and there is a condition that some chains develop with the pitch of the teeth or the guides...or both...that will cause them to cut to the left or right at an angle (usually left). While I have not figured out what causes this, I have solved the problem of correcting it. First, turn the nose of your bar and chain toward you on a bench, look down it like sighting a gun and take a look at each tooth and guide. If the saw is cutting left, the teeth or the guides (or both) on the left (while you are looking down the bar from its tip) will be pitched differently than the teeth and/or guides on the right. The pitch of those teeth or guides (those little ears that stick up about on-fourth inch in front of each tooth) will be: 1) too much in line with each other, or 2) the teeth or guides will be less pitched than the teeth or guides on the right side of the chain. Solution: take a large pair of lineman's pliers or similar pliers and pitch those teeth and guides to match those on the right side of the chain. Also, make sure the curved part of your chain teeth peek out around the outside edge of those guides. If the guides are directly in line with your teeth, they will hinder cutting by the teeth. You can do this with the chain on the saw if you don't have too much slack between the bar and the chain. Last, make sure that the chain guides are not as tall or taller than your teeth. If they are, you will need to file them down a little (with a flat file) until the teeth are slightly longer than the guides. Afterward, make sure the teeth on both sides are equally sharp, and go cut a straight cut! TennesseeBob
Jan 15, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Which dremel bit do i use for sharpening some scissors and how?
any fine grinding stone will work the main thing to remember is to make sure you maintain the correct angle of the blade
Dec 04, 2008 | Dremel 700 03 Super Accessory 185 Piece...
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
458 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
