Question about Yamaha HTR-5850 Receiver
Sound cutting out
I have my HTR-5940 with 5.1 surround. I play my Xbox 360 using the optical input. As I play video games my sound cuts out for short periods of time whenever there are loud noises, such as many guns and explosions going off at once while playing HALO, or if I fire a powerful gun in Tom Clancy's VEGAS. My question is if there is a noise reducing function that is supposed to protect me from hearing unwanted 'noise' and if it can be turned off. Hearing my fantastic sound cut out in the middle of a heated battle is very frustrating.
  • Adam Lebovitz Feb 11, 2007
    I still can't figure this problem out. I play my games in the Entertainment: Game mode. Would this problem stop if I used another mode?
    Habit-Forming:
  • 143 Answers
I'm presuming you are referring to a Yamaha HTR,right???(Night Listening Enhancer (Cinema/Music) and SILENT CINEMA)..see page 32 in this manual at this link,here's the owner's Manual,also available to download for free in .pdf (Adobe) format.......https://www.manualslib.com/manual/197349/Yamaha-Htr-5940-Av.html
Posted on May 09, 2017
SOURCE:
SOURCE: YAMAHA HTR 5660 MAKES POPING SOUND WITH LOUD NOISE AND BRIGHT LIGHT
Looks like you've got the best connection available - initially I thought it might have something to do with decoding the prologic signal from the analog input, but obviously not! And since you've got the audio separate from the video it is unlikely there is any interference from the video signal in the cable. Have you tried a different DVD player (I reckon that is most likely)? Also try connecting the video signal DIRECTLY from DVD to the TV if you aren't already doing so (you are anyway aren't you - the HTR 5660 doesn't have HDMI out does it?) Finally, if you have some spare cables around, try changing them - see if you get the same response when using component video cable instead of HDMI.
Posted on Jan 29, 2008
  • 12 Answers
SOURCE: Yamaha HTR-5990 Audio no longer works
Hi everyone:
You may reset your unit, to do so here is the procedure.
1. Depress the MASTER little Button so it has to be in the OFF position
2. press simuntaneously the A/B/C/D/E and TUNNING/CH > buttons and the press MASTER again
3. Keep the two buttons pressed until the SLEEP blinks on th display, at this point you will see a message that last for maybe 3 seconds,
4. after the message you will see the number 1 and a series of numbers on the first row and the word MARGIN on the second row.
5. Turn the PROGRAM knob until you reach tothe number 11 FAC PRESET on the first row and PRESET INH on the second row
6. press the TUNNING/CH > button once, and the message on the second row will display PRESET RSRV
7. Press the MASTER again and your unit will have the factory settings.
I Hope this solve your problem
Miguel
Posted on Feb 16, 2008
avenger77
SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
Posted on Aug 10, 2008
  • 92 Answers
SOURCE: Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
Posted on May 20, 2009
  • 50 Answers
SOURCE: Looking for code for m yamaha htr-5940 for comcast
if it is a 4 code try 0176 , if it is 5 try 30176. dont forget to program the remote to turn the receiver up and not the box or tv
Posted on Jul 05, 2009
My xbox is cutting out everytime i play for a long
hello, try cleaning the fan as it could be getting blocked from a dust build up, i hope for your sake your xbox 360 just needs cleaning, make sure you clean all of your xbox with a damp cloth, not wet as this will damage the xbox even more, and also clean the surrounding area where you put your xbox on, as this will help clear dust. if this does not help and your still within warranty contact microsoft for a free fixing service as long as you have warranty thats still valid
good luck
Apr 22, 2010 | Microsoft Xbox Console
I have a yamaha htr-5940 and have hooked my PS3 directly to my Television with a HDMI cable and to the receiver with an optical cable, I am not getting any sound from my speakers (surround sound) am I...
get into the menu of the receiver and find "input settings" look for "audio" and set it to "auto" If it still has no audio, put it on the input it needs to be "DTV" "Aux" etc. then press input mode on the remote. It should say "auto" or "digital" if so, pull the optical off the back of the receiver and make sure you see a red glow. That let's you know a signal is present. If it's not, get into the menu of the PS3 and find the audio section and set it to Dolby Digital. If you still have an issue, post a comment and I will help you further. Hope this helps
Nov 07, 2009 | Yamaha HTR-5940 Receiver
Xbox 360 and bose surround sound no video
If your TV is HD, you should definitely be connecting the component video cables (green, blue and red) from the 360 to the TV (the 321 will not do video pass-thru from component cables). -Make sure you have a picture at this point. (TV switched to whichever input you connect the 360 to)
You can get an RCA extension cable for the audio portion (red and white) to connect to the 321 for audio. You could also connect an optical audio cable to the 321. An optical cable must be assigned from the system menu to work..
Let me know if this helps.
May 31, 2009 | Microsoft Xbox 360 Pro System Console
May 18, 2009 | Yamaha HTR-6130 Receiver
Left from speaker not working- Yamaha HTR-5940-6.1 channel
Redbird,
What do you have in the "multi channel input" jacks on the rear of the receiver? Those inputs Right, Left, Center, Surround R+L, and Sub are used when selecting 6 channel mode. They bypass the receivers surround processor board.
John W
Jan 10, 2009 | Yamaha HTR-5940 Receiver
Surround sound not working properly
this isnt a solution to your problem but i have a suggestion. I see this problem has been posted a couple days now and i think that because your problem looks like it involves more stereo equipment rather than the xbox 360 console. i think you would get a better answer actually a soltuion if you posted this in the stereo section.
Dec 22, 2007 | Microsoft Xbox 360 Console
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
Hook up your Xbox to a Dolby Digital Decoder
Xbox® is the first and only game console to support in-game Dolby® Digital 5.1 surround sound. This lets you experience all the game sounds from your home theater system in full 5.1 surround. Before you get started, make sure you've got the following: A digital audio output. A free optical digital input on your receiver. An optical digital audio cable. Digital Audio Output Your Xbox didn't come standard with a digital audio output, but you're gonna need one for this to work, so hightail it to the store for the Advanced AV Pack or High Definition AV Pack, both of which have digital audio outputs. Microsoft makes both of them. You can also buy third-party AV cables for Xbox?but make sure they have a digital audio output. Free Optical Digital Input For this slammin' sound system to work properly, you need at least one free optical digital input on your receiver. Ready to Hook It Up? Let's Go! Connect the digital audio output to your Xbox. Connect one end of the optical digital audio cable to the digital audio output on your Xbox and the other end to the optical digital input on your receiver. Turn on your Xbox with no disc in the disc drive. In the Xbox Dashboard, select Settings. Select Audio. You will see an Audio Mode screen that shows Dolby Digital and DTS status. Select Dolby Digital. You will see the question "Does your stereo system support Dolby Digital Audio?" Select Yes. You will see Dolby Digital Enabled in the audio screen. Your Xbox is now ready for Dolby Digital gameplay. Insert a game disc and play!
Nov 20, 2005 | Microsoft Xbox 360 Console
Yamaha HTR-5850 Receiver Logo
116 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
