Question about Dishwashers
Water backs up from the sink. pump works but no pressure
  • 338 Answers
Your drain hose is backed up in the air gap.. there is either a stainless steel colored thing on your sink or its white that normally you never do anything with. you have to take the 2 caps off of it and clear any debris. if you dont have one then you should get a bucket and take the drain hose off of the drain or the garbage disposal. then clean it out with something like a fridge coil brush (you can pick up at any home store for 10 bucks) then hit the drain button and let it drain into the bucket to make sure its pumping before you reconnect it to the drain. let me know if you need further assistance
Posted on Nov 29, 2008
Can I clean the valve to remove sediment?
when this problem presents I consider that the problem is in the weak tap stopper /seat
they can break down ,become enlarged and not move of the tap seat to allow full flow
that is the first check I would be doing
Mar 02, 2015 | Grundfos Pumps Grundfos Comfort System...
How does pressure tanks work
Pressure tanks do just that in a water system. They create pressure for water to flow when the water pump is on the off cycle. A manifold is plumbed into the tank from the main line coming from the well. The main water line continues to the house plumbing from the manifold. So it's line from pump to manifold - to tank, and from manifold to main into house. The manifold also has tappings for the pressure gauge and the pressure switch. The pressure tank creates water pressure. The water does not flow through the tank. Pressure tanks also have to be 'tuned' or adjusted to the low end pressure set by the pressure switch. Actually the tank pressure needs to be set 2psi below the low end pressure. Most residential water systems are set to operate between 20 -40, or 30-50 psi, which is set by the pressure switch, which in turn , turns the water pump on and off. So if a system operates between 20 and 40 psi, the pre-charged pressure of the tank should be 18 psi. Pre-charged means the tank is drained of water with the water pump OFF. The tank pressure is then checked adjusted by way of the air valve on top of the tank ( A tire gauge works). Pressure tank mainfolds are a common plumbing part.
Mar 19, 2014 | Utilitech 20-Gallon Vertical Pressure Tank...
Low water pressure in shower and sinks. Pressure good at water source.
Possible that the pump is not working to the the desired pressure and so might be clogged or faulty.
You can remove and clean the pump before this can be confirmed,There can be accumulation of dirt to the input of the pump which can be reversed flushed.
Jan 15, 2013 | Washing Machines
My little giant is used to pump water from a sink to the outlet lines. I noticed that it had leaked water when my washing machine pumped water into the sink. I was not present when that happened. So I ran...
if there is a restriction in the line the pump is trying for example to pump 25 gal an hour and its restricted to 15 an hour you now have back pressure of 10 pounds the water hast to go some Ware and what you see is the result of a leak i would check the out going line hope this helps you bob
May 02, 2011 | Little Giant 6 Cia, 1/3 Hp, 45 Gpm, 230V...
Ok at the place I am employed they have a 1 Hp submersible pump it pumps about 300 ft into the top of a 120 gal storage tank then the water comes out of the bottom of the tank and goes into our grundfos...
The booster should have been placed after you restrooms with a check valve to prevent back-pressure. then you can adjust both the sub-pump pressure, and the booster pressure accordingly
let me know
Dec 18, 2010 | Grundfos MQ3-45 1 HP Pressure Booster...
My water pump kicks on every 30 min or so even if there is no water used
When a pump goes on and off there is a water leak somewhere.
There should be a gauge. Let the pump build up pressure and watch the gauge.
The pressure will probably be dropping. This means that water is going somewhere. The leak could be anywhere that you use water, sprinklers, sinks, hose lines. If there is a valve above or near the pump, shut that valve and see if the pressure stops dropping. If the pressure stays up and the pump stops cycling on and off, the leak in in the pressure piping somewhere, you must locate it and repair it.
If the pressure continues to drop even with the discharge valve shut, the water must be leaking back into the well. There is a check valve somewhere on your line between the well and the pump. If this check valve is leaking, pressure will drop and the pump will come on to restore it.
If it is possible to shut off the discharge of the pump, shut that valve and watch the pressure gauge to see if it is dropping.
Dec 12, 2010 | RTO Wayne 1/2 Hp Shallow Well Jet Pump
Changed r/o 3 filters and now water produces 2cups
The pressure on an EMPTY tank should be 8-10 psi. Be sure the tank is empty before checking the pressure. A good way to empty the tank is to connect a small air compressor to the air valve on the tank, open the systems faucet, and turn on the compressor. A bicycle pump works too....Just more of a workout:)
Jul 08, 2010 | Culligan Sales #SY-750S Under Sink Water...
Dishwasher drains through the garbage disposal into the sink. Water backs up in the sink, but sink drains well in none dishwasher drainage. (There is a vacuum breaker on top of this sink, but I don't think...
The disposal isn't being used much which is causing the slow drain. Turn on disposal for few seconds and this should take care of the problem. During the pump out the pressure is greater than just running water from faucet.
Jul 05, 2010 | Dishwashers
Motor on reverse osmosis runs constantly
If this is a booster pump, many booster pumps like Shurflo have an adjustment at the top (allen screw) to back off on the pump pressure, turn to left to back off on pressure. If it never shuts off this can be an indication of a bad membrane, capillary tube, flow restrictor or automatic shutoff, causing all the water to run to drain. If you have low quantities of water, but pump always runs, this could part of the problem. Also high TDS (total dissolved solids) will cause the pump to work more. The higher the TDS 500+ppm the harder it is to produce quality water. With high TDS it's almost like taking muddy water, running it through filters and getting drinkable water. So the RO and pump have to work much harder to produce any quantity and quality of water.
May 01, 2010 | Culligan Under Sink Water Filter
Dishwashers Logo
41 people viewed this question
Top Dishwashers Experts
