U-Line Refrigerator Ice Maker Logo
Posted on Nov 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
U-Line combo 75 not getting cold
I have a U-LIne Combo 75 that is not getting cold. The light goes on, so I know it has power. How can I tell if it is a compressor or thermostat problem? The thermostat has three wires: Blue, Yellow and Red. If I short any of these wires, will the compressor turn on? Which wires and how long before the compressor turns on? What is the part number of the thermostat if I need to order on?
  • billb531 May 21, 2009
    DONT NO MUCH ABOUT THESE BUT I DONT HEAR THE COMPRESSER TURNING ON , THE LIGHT IS ON AND THE ICE MAKER ITSELF IS GETTING 'HOT'
Anonymous
Level 2:
  • Expert 286 Answers
  • Posted on Jun 06, 2009
Anonymous
Expert
Level 2:
Answers
286
Questions
0
Helped
114192
Points
558
The 3 wires is. Yellow on terminal 2 (common) red wire on terminal 1 (icemaker) and Blue on terminal 3(compressor and fan). If you bypass the yellow and blue then the compressor and fan should run. If you bypass the red and yellow then the icemaker will advance. Hope this helps.
Anonymous
Level 2:
Scholar:
  • Expert 81 Answers
  • Posted on Nov 29, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
81
Questions
0
Helped
18237
Points
190
i have some procedure in troubleshooting a ref., as follows:
1. check if the compressor will run when you plug the ref in the outlet/power.
a. if the compressor run and it will not produce the cold or heat. then the problem is, the system of your ref. has a leak. it lost all the freon charge into the system. find a near service center in your area.
b. if the compressor run and it stop. unplug your ref. from power.
  • check the capacitor if it is ok, using a multi tester. by determining a good capacitor in resistance test at 100 kilo ohms or 10 kilo ohms the pointer will deflect to right and it will slowly going to left or a higher rating. bad ca[pacitor pointer steady in zero position or infinite.
  • but if the capacitor is ok then some trouble in mechanical parts inside the compressor. specially when you turn on your ref. you feel some surge power from the case of the ref. find a near service center in your area. if you need to replace the compressor and some parts of it.
c. if the compressor will not run, unplug your ref from power and then check the follow:
  • check the compressor resistance by using a multi tester, open the terminal box of the compressor. have some checklist in the terminal setting that has a letter symbol R (running) connected to what color of wire, same also with S (start) and C (capacitor) check in its terminal resistance.
I have a line 6 spider jam ...was playing guitar and then the sound went dead... loops work lights work but no sound
It probably the output Ic named TDA7293 and maybe because of the fan malfunction, let me know a bit further to help you more.
Do you have the user manual
You can download the Line 6 Spider III 75 user manual here http://line6.com/legacy/spideriii75
My line 6 spider 3 75W amp will not show any lights when I turn it on nor make a sound. Only the backlight on the display will turn on and be blank. I have tried the factory reset and it still will not...
Probably the 3.3 volt power that supplies the DSP has failed or is being shorted out. If you are not electronicaally adept, best to take it to a shop for repair.
How do you reset your line 6 spider jam?
Hold down the settings/tone button as you turn on the power and keep holding it for 5 to 8 seconds. Here is a link you might like:http://line6.com/community/docs/DOC-4629
Got a Line 6 Spider III HD 75 at the flea market.
The unit has internal fuses. You have to take it apart. If the fuse is blown you more than likley need some service. You can call Pro Line Music 215-736-8055
U-line combo not making ice. Have cleaned
bad water valve, thermostat, freezer not cold enough, make sure the ice maker metal rod is at down position or on back of the ice maker plastic water line is frozen. also depends what year combo you have, there operation is a little different.
2helpful
2answers
Replace left front window regulator
You can get a replacement window regulator from many on-line parts warehouses, or at your local Kragen, Autozone, etc. Price for the regulator only (less motor) run between $65-$85, with the motor costing around the same price. I did find one place which had the regulator/motor combo for $75.
Here are a few on-line links:
1Aauto.com ( This is where I found the combo for $75)
PartsTrain.com
Car-Stuff.com
By the way, I am going to try to replace the same parts on my 1998 Sienna van. Any idea where I can download the procedures for free? Don't need the entire repair manual, just the information for replacing the regulator/motor.
Mojo
3answers
When turned on only gets a straight line of color in middle of screen
You lost your vertical sweep. most likely the vertical output IC or a power supply source is the problem.
Top U-Line Refrigerators Experts
Kardoc
Jorgie  the...
Jorgie the...
ADMIN Andrew
ADMIN Andrew
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
