Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu nightmare this is gonna sound really daft but how do i do a complete re install if it wont read the cd? Is it a case of take it back to the shop?
    President:
  • 2,961 Answers
Are you putting in the cd before you boot up and not after it has tried to boot, as it should give you the 'boot from CD' option and te you to press enter.
Posted on Jan 16, 2007
Hi having problems with my partners Fujitsu Siemens ScaleOP Desktop Computer. She recently reformatted the PC with a Genuine copy of Windows XP which installed perfectly without any hitches but when...
Can the drive read other disks? I'm guessing no. If no, it would appear as if the drivers for the CD rom are not loaded. If this is the case, you will need an internet connection to download the drivers for the cd rom so it will work. Other than that,you can try to install generic cd rom drivers through windows, that may work. Good luck.
Sep 26, 2012 | Computers & Internet
Need Good & Free test and read/write surface scan tool for a Fujitsu MHT2040AH.
Try the ultimate boot CD, there you can use may hard drive diagnostic utilities, perhaps Test Disk will suit your needs, here;s a link
http://www.ultimatebootcd.com/download.html
Hope that helps
Christopher
May 17, 2012 | SimpleTech Simpledrive Computers &...
I have a 2005 vw cabroilet the passanger door wont open from inside or out any ideas?
Hi
Common fault on this car, the inside of the back of the door handle has either came off or broken off, I know it might sounds daft but lock and unlock with the remote and get someone to pull hard on the door handle, they often jam then this snaps the plastic clip inside the rear of the handle.
also try having someone sit on the inside and do the same to get the door open whilst consatntly using the lock and unlock on the remote fob. Otherwise I would recommend putting it in a garge as removing the door card with the door shut is a bit of a nightmare and most likely will end up damaging the panel caosting you more.
If you need more dteails please get back to me
Regards
Dan
Nov 07, 2010 | 2000 Volkswagen Beetle
Wont start up and then starts making a clicking noise? i can go into bios fine its after that can u help?
Sounds like you've experienced the "click of death." Hope you didn't have too much important stuff or you backed it up, 'cause you're gonna need a new hard drive.
Feb 01, 2010 | Fujitsu LifeBook C6581 Notebook
When I Play Music through Winamp/Media Player it
That is unusual - pressing in case should not effect play - not like a tape drive would.
Are you playing from CD or Hard-drive?
If Cd - try copy music to hard-drive and see how it plays - if ok - then something may be rubbing on CD in CD-Player? But that would give read errors. Have to remove CD Player and clean it.
Jan 29, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Have just installed a Fujitsu Asta 24lC air con heat pump problem
Hi Shannon,
I would pursue your fight with Fujitsu, normally their units are reliable:(
It could be a really simple problem or a really complex one ranging from many componenets. A air conditioner has many more components that people may think. Keep fighting to get the unit repaired will it is still under warranty, after that Fujitsu wont want to know you. It could also be a wiring and refrigerant fault. Call Fujitsu out again.
I take the time to answer your question, so please rate me.
Thankyou Mat
Aug 24, 2009 | Heating & Cooling
Fujitsu v2000
I assume you mean cd driver..
your cd is recognised as plug and play and shouldnt need any drivers installing .
on the underside of unit youll find retainer screws for cd ..remove these to slide cd drive out ...startup pc and when in windows slide drive back in and sys will detect and install it .you may have to remove other covers to gain access to retainer screws for cd drive.
dont really matter which screws you remove whilst looking as long as you dont forget where they go and to replace them
Jan 25, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
DVD rom drive
It sounds like the drive itself is faulty. Since you've reformatted, it obviously isn't a software problem. CDs and DVDs are read by two different lasers so its not uncommon for one disc not to be read yet the other is just fine which seems to be the case. A new one can be purchased for under $40. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010100005+1036508690&name=Slim+Combo+Drive
Jun 23, 2007 | Toshiba Satellite A135 Notebook
Fujitsu nightmare
This is because it has not written the system files yet as it has frozen on repair. assuming youv'e set the cd as the first boot device, it sounds like a complete re install is now necassary, but if you get the cd to run you will need to format the drive first then a clean re install.
Jan 16, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
161 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
