Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic pt51 hx 41e
Hi ladywinn
i just replaced my convergence ptk 150's and reassembled the left part of the tv chassis. i turned on the tv and there is no power to the screen. sound works great but i guess no power to the picture tubes. you sound like you really no your stuff. please give me a hint.
thanks
denny
  • Panasonic Master
  • 5,138 Answers
Recheck all of your solder connections recheck and make sure everthing is pluged or reconnected right then retry set.
Posted on Nov 29, 2008
Convergence problem can't be fixed with remote
Model indicated usually NEVER has convergence problems.
Look on back for "chassis" number, is it a PTK 195 chassis?
If it is I can tell you what is likely wrong and it is a do it yourself repair.
BEFORE YOU RATE THIS SOLUTION LET ME KNOW IF 195 CHASSIS.
SD TECH
Jul 27, 2011 | RCA P52937 52" Rear Projection Television
Rca hd56w66 convergence problem. ladywinn said it was a fuse where do i get replacement fuses?
that tv has a convergence module and a convergence power supply it also has a block fuse on sweep module but i can promise you replacing a fuse will not correct your prob. the fuse is there for a reason if it opens there is a prob.but i dought its opened its located on sweep module there will be 3 block fuess in a row on the left side of the sweep module they are small red blocks good luck
Feb 03, 2010 | RCA HD56W66 56" HDTV
Red ghost images
Yes there is a repair kit for your model which contains the two Convergence ICs and the 6 feed resistors. The kit alkso has step by step instructions with pictures so you can easily do the repair. Heres the link for the correct kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
Jun 01, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
RCA P56926 Would not turn off
This tv make a lot loose connections. If you re solder and nothing change, check fly back area's is OK?... Look around convergence board for liquid coolant ( some times CTR liquid coolant projection splitter , becarfull, Liquid is danger!!) Wash yous hands and clean chassis with acetone.
Apr 19, 2008 | RCA P52926 52" Rear Projection Television
Convergence problem
If the set is a ptk 195 chassis,check your menu in screens to see if the adj. projection tv is there,if not the convergence power supply is bad.
Feb 23, 2008 | RCA P52937 52" Rear Projection Television
PT-51HX40b chassis BP819
if you get to the red chk press the power button on remote numbers should appear lower right each time you hit power button nummbers change keep going till 00v00 appears press ch up then it should read oovo1 at this time press vol up now your ready
press 1 to toggel colors
use vol and ch buttons to move cursor
press mute to choose to addjust
press7 to save data
good luck
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
RCA 52" Rear Projection P52930BL
You can adj. from the front panel of the set using the channel and vol. buttons,if the set you have has a ptk 195 chassis,check and make sure you have adj. projection tv in screens of the menu,in not the convergence power supply has failed,replace the reg on the board,part number is 215530
Oct 04, 2007 | RCA P52930BL 52" Rear Projection...
Three colours don't converge
Sounds like your convergence power supply board is bad if it is a ctc or ptk 195 chassis. Located above the main board on the left and dynamic convergence board on right. Has two plugs and held down with quarter inch screws. Most problems on the board is the IC on the metal heat sink which is stk 730-010. whatever you can see the part number on it. Unsolder with solder wick and solder in new. If this doesn't fix a new complete board will do.
Sep 09, 2007 | RCA P46922 TV
Misconvergence
Convergence on RCA P56940 chassis PTK195 can only be done by service center with RCA Chipper Check computer interface box. Sounds like possibly missing -15 volt or +15 volt supply to digital convergence circuit, bad i.c.'s U19503 or U19504. Supply voltages come from regulator supply transformer T19701 diodes CR19707 (-15 volts) and CR19709 (+15 volt)
Dec 22, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
87 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
