Question about Imperial IFS50 Deep Fryer
Imperal comerical deep fryer light keeps going out
Piot light goes out on a imperal deep fryer after its been lit a couple seeconds
  • Does the pilot stay lit for a couple of seconds or does it go out when the pilot knob is released? Does it go right when the main burners come on?
2 Suggested Answers
SOURCE: comercial deep fryer pilot light goes out
This problem could be caused by a few different things. You should check the condition of your pilot and the thermocouple, if the pilot is weak due to being dirty you will not generate the optimum Millivolts to run the fryer, you may need to dissassemble and clean the pilot. The thermocouple needs to be correctly placed in the pilot assembly, if it has dropped down to where it is not in the flame it will not work correctly. You may need a new thermopile as it may not be generating millivolts as needed. Gas pressure can cause this as well, if the pilot goes out then the main burners come on you should check the gas pressure. One more thing to check is the hi-limit thermostat, if this is cutting out early your pilot will go out. Imperial uses a self-resetting limit, after a few minutes your fryer will relight and work until if cuts out again. If your fryer pilot stay on with the thermostat off for long periods of time and does not go out immediately when the burners come on and the pilot is clean, you may need a hi limit. This is a lot of info, I hope it helps.
Posted on May 26, 2009
Bakers pride deep fryer will only stay lit for couple of minutes and then shut off
Hi there!
Normally hi limit sensing bulb is thicker and shorter than that of thermostat.
Try tightening all wire terminal crimps and connection.
Regards.
Feb 05, 2013 | Imperial IFS40 Deep Fryer
Pilot light will light but won't stay lit How do you clean the orifice?
I don't think it is the ortice it is most likley the thermal coupling change it and this will keep your pilot light will stay lit
Aug 31, 2010 | American Range AF45LP Deep Fryer
Light pilot on Royal deep fryer. Pilot will not stay lit. Second fryer has larger pilot have no trouble keeping it lit. How can I adjust the pilot so that it will stay lit?
there is a small adjustment screw on the gas valve,turn it clockwise to increase pilot,if that does not work the vent cap on the gas regulator on the back of the unit could be stopped up,remove that cap ,clean out or replace unit can operate without it just fine.If you increase the pilot and it still wont stay lit replace the thermocouple
Feb 06, 2010 | Vulcan GR45 Deep Fryer
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
How oftern should a deep fat fryer Oil be change and unit be cleaned
It depends on how much you use it. If you use every day all day them change oil once a week and cleaned at the same time. If used rarley then change oil when food tasted not as good as it shood.
Sep 10, 2009 | Imperial IFS40 Deep Fryer
My pilot light would come on but i had to press it to position. And when i tried to release it to light up, the fire went out.
Sometimes the thermocouple gets so weak that it may require you to hold in on the pilot knob for a couple of minutes after the pilot is lit. If it still goes out then you need to replace the thermocouple or thermopile, which ever you have.
captrick
Jul 08, 2009 | Cecilware GF-10 Deep Fryer
Burner will not come on
need tochange termal couple
Jun 01, 2009 | Imperial IFS40 Deep Fryer
Comercial deep fryer pilot light goes out
Nov 29, 2008 | Imperial IFS50 Deep Fryer
I replaced the thermocoupler still not staying lit.
I understand it that once the main burners go off, after the thermostat is satisfied (water heated) the pilot goes out too at the same time.
Make super sure the top of the t-couple is getting hit directly by the pilot flame. You may need to adjust the t-couples position, or even clean the pilot assemblies oriface. Double checking the connection of the coax cable at the gas valve would be a good idea too. tight but not super tight.
Nov 14, 2007 | Pitco Frialator SG14 Deep Fryer
Imperial IFS50 Deep Fryer Logo
44 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
