Possibly damaged Toshiba satellite A105s2484...
While disassembling to replace Wireless and then DVD...Strip cables yanked off while trying to keep it from falling...Reconnected them...
Will sometime power up and no service/repair manuals schematics with lap-top. I will NOT a thing until I get some advice and I hope I did`nt short it out...Will provide more details.
Thanks.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 144 Answers
It's unlikly you can fix it. you will need a repair shop if it is a broken ribbon.
Posted on Dec 01, 2008
How do i repair toshiba satellite a105 ribbon cable repair
Have you tried hooking up an external monitor to it and seeing if it works? I would try that first to rule out a video card issue. If the external monitor works fine, here is a website with pictures on how to disassemble the laptop to replace the screen:
Toshiba Satellite A105 Laptop Disassembly Guide Cooling Fan Heatsink...
Jul 23, 2014 | Toshiba Computers & Internet
Need to know where antenna card is located on my p25 toshiba laptop
The Wireless Module is located on the Bottom of the laptop,
http://www.irisvista.com/tech/laptops/ToshibaP25/disassembly/big/Toshiba_SatelliteP25_03.jpg
The top card to the left. (With the red arrow)
White Wireless Antenna wire, and a Black Wireless Antenna wire.
You can see which terminal the White wire connects to. Leaves the other terminal for the Black wire.
Beginning page of pictorial disassembly guide, (Page 1),
http://www.irisvista.com/tech/laptops/ToshibaP25/SatelliteP25_1.htm
Page1::Page2::Page3::Find another model, is in White, and on the Top of each page, and Bottom of each page.
The Wireless Antenna wires attach to the Wireless Module,
http://www.ebay.com/itm/WIFI-WIRELESS-PA3299U-1MPC-Card-for-17-Laptop-Toshiba-Satellite-P25-/170900245815?pt=LH_DefaultDomain_0&hash=item27ca72cd37
Looks to me the White wire to MAIN, and the Black wire to AUX.
The Wireless Antenna wires then thread up through a cavity (Hole), in the laptop body, and go through/by the Right Hinge.
From there they go into the Display Assembly, and connect to the Wireless Antenna,
http://www.irisvista.com/tech/laptops/ToshibaP25/satP25_LCD.htm
http://www.ebay.com/itm/Toshiba-P25-Satellite-Laptop-WiFi-ANTENNA-K000006070-/220547282983
Scroll down, read the description.
The Wireless Antenna wires route through CHANNELS, and LATCHES.
The Wireless Antenna wires MUST go back in the SAME routing they were originally.
Failure to do will cause the laptop to not go back together correctly, and can cause damage to the Wireless Antenna Cable. (Wires)
[Pinched/Broken]
For additional questions please post in a Comment.
Regards,
joecoolvette
Feb 06, 2013 | Toshiba Satellite P25-S607 Notebook
What is Causing my top case cover to hang up and not come off?????
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
Click on the photo in Step 4.
What screw did you miss?
Display Assembly is removed in order to remove the Upper Cover.
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-3.htm
Step 12.
The Upper Cover has TABS going around the perimeter, on the inside edges.
These Tabs snap into matching LATCHES on the Base Enclosure.
(OK. Toshiba? Bottom Cover)
Just like the article, I like to start with a thick guitar pick, to get an edge to come up. I start at the Right/Middle, but it's really a personal preference thing.
After the Upper Cover edge is raised a little, I then use my fingertips. You would find a Spudger Tool though, makes life a whole lot easier doing this,
http://www.amazon.com/Techni-Tool-Spudger-Alignment-Tool-Black/dp/B000PDNPYK/ref=sr_1_7?ie=UTF8&qid=1359090938&sr=8-7&keywords=spudger+tool
(It isn't made of metal)
Can't get the guitar pick, or spudger tool in? Move over a little. You are at a Tab/Latch.
Regards,
joecoolvette
Jan 25, 2013 | Toshiba Satellite A205-S5831 Notebook
Screen on laptop is distorted halfway
A) Video Cable connections are loose:
Connection at the motherboard, and the connection at the back of the LCD screen, in the Display Assembly.
Both need to be checked.
[For Toshiba the Video Cable is termed LVDS Cable.
Low-Voltage Differential Signaling Cable. I will just keep referring to it as the Video Cable ]
B) Video Cable is damaged:
Observe the sheath at the motherboard side of the Video Cable?
Is there obvious signs of damage to the sheath of the cable?
If so, there may also be damage to the tiny, thin wires inside the sheath, of the Video Cable.
Due to the routing of the Video Cable under the left Hinge, the Video Cable may be pulled on. This can create a bad connection.
Due to the above also, the Video Cable's sheath may be damaged, and the wires inside.
A view of the Video Cable by itself,
http://www.batterystyle.com/toshiba-satellite-a205-s5880-cable-p-484063.html
If the Video Cable checks out to be OK, the next item is the screen Inverter.
To test a screen Inverter you need a sensitive multimeter. This usually means expensive. { Or use a known to be good, compatible screen Inverter } Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter. {Or LCD screen)
Most consumers decide to just replace the screen Inverter because;
1) If the problem isn't the screen Inverter, it is the LCD screen.
(A LOT of people buy an LCD screen, when all they really needed was a screen Inverter)
An EXPENSIVE part.
(LCD screen? $150 to $400 approximately. Screen Inverter? Usually around $22 to $48 )
2) The ease of access to replace.
As stated, if the problem isn't the screen Inverter, then it is the LCD screen.
1) With ALL power removed, AC adapter (Charger), and Battery, remove the Keyboard Bezel, and the Keyboard.
This is the motherboard connection side.
Display Assembly removed with Video Cable.
Now remove the Display Bezel, and LCD screen assembly, to access the Video Cable connection to the back of the LCD screen.
{NOTE*
The screen Inverter is mounted at the bottom of the LCD screen, and behind the Display Bezel }
This shows the Video Cable, and it's connection at the motherboard side,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-2.htm
Scroll down, click on the photo in Step 9.
The Video Cable is the cable to the upper Left side. Has one Red arrow pointing to the left.
The photo in Step 10 shows the Video Cable disconnected from the motherboard.
(This is Page 2 of a disassembly guide. Pages 1 through 4 are available above, and below. Page1::Page2::Page3::Page4::Find another model,
in white.
Just thought I would state that. Don't want you to completely disassemble your laptop, just to fix a Video Cable, or screen Inverter, or LCD screen) )
2) LCD screen side:
http://www.irisvista.com/tech/laptops/toshiba-satellite-a215/disassemble-display-panel-4.htm
http://www.insidemylaptop.com/remove-lcd-screen-from-toshiba-laptop/
All three links above will help you with checking the connections, or removing the cable to perform a continuity check. (Test)
Also with accessing the screen Inverter, and LCD screen.
Regards,
joecoolvette
Jan 25, 2012 | Toshiba Satellite A205-S5880 Notebook
How to replace the built in wireless
This step by step disassembly guide with photos will help you perform your replacement.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-U205-U200/disassemble-laptop-1.htm
Best Regards,
Marcus
Sep 15, 2010 | Toshiba Satellite U205-S5034 Notebook
How do i remove the cd/dvd drive for my acer3003lc so that a can replace it
You can use the Toshiba Satellite 5205 guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
for the acer 3000
1. At the back of the laptop remove the three screws on the support posts for the screen
2. Open the laptop fully and lift the plastic panel that has the power button.
3. Remove the 2 screws holding the keyboard in place
4. Carefully slide the keyboard towards the monitor and lift.
5. To the left of the keyboard ribbon cable is the screw that's been causing all this grief.
6. Remove, slide out optical drive, reassemble.
Jan 03, 2010 | Acer Aspire 3003LCi Notebook
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
HOW DO I CHANGE CD/DVD DRIVE IN A TOSHIBA SATELLITE P105-S6114?
You can use the Toshiba Satellite guide for removing and replacing the DVD/CD-ROM drive or the keyboard. On this model you have to remove the keyboard in order to remove and replace the DVD/CD-ROM drive because the optical drive securing screw is located under the keyboard. Always start laptop disassembly with removing the battery or you can damage the system board if you accidentally touch it with a screwdriver and shorten traces. Removing the keyboard strip is not very difficult, use your fingers to release the plastic latches. If you want to replace the keyboard, do not forget to unlock the connector on the system boar before you pull the cable.
Sep 21, 2009 | Toshiba Satellite Pro A10 Notebook
A305-S6858 Laptop screen replacement
please reference follow steps to disassemble LCD screen
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A305/remove-replace-LCD-screen-inverter-1.htm
be careful all small cable like KB top cover LCD cable and inverter cable.
hope help you fix it, please take a rating let me know huw much helped you thanks! keep in touch your question.
May 21, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Computers & Internet Logo
107 people viewed this question
David Payne
David Payne
