Question about Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer
Lexmark X73 Want to send a fax through present DSL line? Any ideas?
  • Anonymous Mar 05, 2008
    Hello
    My filter didn't work, Is there a difference between dsl and broadband (I have comcast)?
    Russell
  • joanee Mar 18, 2008
    I would like to know how to send a fax to the 7170 and how to recieve a fax.
My comcast digital doesn't allow me to fax, and I have reconfigured my ECM and BPS accordingly. I also installed a digital filter...still I can't send or receive faxes. Both Lexmark (I have a x7170 AIO) and Comcast says they've done all they can. Any suggestions?
Posted on Mar 05, 2008
    Novelist:
    Champion:
  • 202 Answers
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Posted on Jan 31, 2007
SOURCE:
Can't receive or send fax
~ Configure Fax Settings ~ Check Communication under Fax Settings
drd: all ecm: off v.34: off dial tone detection: on RTA: RTA of the fax must be higher than the RTA of answering machine ~ Check the physical connection of the fax ~ line port must be connected to a phone jack ~ if you're using DSL (Internet), Use DSL Filter
Jul 06, 2010 | Lexmark Office Equipment & Supplies
Cannot send a fax
For a fax to work you do not need a broadband. What you need is a phone like. It seems that you are trying to use broadband for fax because it is the same phone line that they both are on. Sorry, will not work that way. If you trace back you will find that there is a little box that has the phone line coming into from outside. The box splits it into phone and dsl. It is this phone line that should go into the fax and not the dsl line.
So please remove the dsl line from the fax and connect the phone line and you will see that the fax works.
Dec 14, 2009 | Lexmark X1240 All-In-One InkJet Printer
Lexmark 1200 series
you will need to have a one to two spiter box so you can still have internet and still be able to use the fax machine.
May 01, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark x2470. Fax solutions not working after going high speed
Please check that the Phone line for faxing is connected to a seperate NON FILTERED phone line. Not to the dsl line. You can use a line splitter for this. Also the dial up modem may need to remain in your computer for the fax software to dial out. Hope this helps.
Dec 07, 2008 | Lexmark X2470 All-In-One InkJet Printer
I have the lexmark 6500 andwhen i fax i keep getting a fax error message.
check and make sure you are not using a dsl filter on the fax line and your dsl is disabled when sending also check the fax send and recieve type
Sep 12, 2008 | Lexmark Office Equipment & Supplies
I am disabled and bought the Lexmark x6570 so I could send and receive faxes. I want to set the unit up on one phone line for use for both faxes and general phone conversation. I presently have a y...
No, you don't need to buy an adapter, just one more phone cord. You already have the splitter, so run one phone cord from the splitter to the printer. You'll see there is a line in and out. Run the out to your phone. Voila. You should be all connected.
Steve
Sep 11, 2008 | Lexmark Office Equipment & Supplies
Faxing
WEll the x7350 is a fax and scanner and copier plus printer. Which x73 do you have?
Jul 27, 2008 | Lexmark X73 All-In-One InkJet Printer
Faxing w/
SInce you have DSL...you must have a phone line...try hooking it up to your phoneline to send a fax. If you would like to send faxes from your desktop over the internet...signup for an account on efax.com
Good luck to you my friend.
Seek PC REpair
Feb 09, 2008 | Computers & Internet
Lexmark x73
Yes you need to connect to computer to receive and send fax........ Telephone as to connected to dial up modem of the computer if you dont have dial up modem then the faxing wont work.........
About Distinctive Ring Pattern Detection (DRPD)
"Distinctive Ring" is a service provided by some telephone service providers. Two phone numbers are assigned to one phone line so that you will hear different ring patterns for incoming phone calls than for incoming faxes. If you subscribe to this service, follow the instructions below to program your All-In-One to use it.
On the X125:
Press Setup once, then press Menu nine (9) times until DRPD appears on the display.
On the X63:
  1. Press Setup once, then press Menu eight (8) times until DRPD appears on the display.
  2. Press Options until you see Learn, and then press Start/Yes.
  3. Dial the phone number that you want to use as a fax number. (Do this from a different phone line, not from the line the fax will be installed on.)
  4. Press Setup.
  5. Press Menu until you see Fax Receive Mode on the display.
  6. Press Options until you see DRPD, and then press Start/Yes. The All-In-One detects the ring pattern and answers all incoming faxes on the second ring.
Sep 20, 2007 | Lexmark X73 All-In-One InkJet Printer
Connecting
jon, I am assuming you have DSL modem. Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. Good Luck, Tim
Feb 03, 2007 | Lexmark X4270 All-In-One InkJet Printer
Lexmark X7170 All-In-One Scan/Copy/Fax and Photo Printer Logo
141 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
