Question about Arctic Products Lil' Arctic Sun Patio Heater
Need a replacment part for an Arctic Sun patio heater
I have a Arctic Sun bullet style, stainless, piezo ignition, patio heater.  I was I need the thermocoupler components.  While cleaning a spiderweb out of the pilot light assembly, the thermocoupler broke off.  I have a PDF with pictures of the Unit and the problem if you'd like to take a look.  How sells replacement parts for Arctic patio heaters
BernzOmatich3200n
Repairing Benzomatic Patio Heater
The above link unfortunately states Benzomatic no longer provides parts for their patio heaters. There may be a comparable generic part out here that you can substitue for the original part.
Tall Propane Patio Heater Starting Striker Switch
The second link shows an igniter switch that may work. You can find other possiilities by doing a search on the web for" Propane Heater igniter switch"
May 16, 2014 | Stainless Patio Heaters - Steel Deluxe...
Pilot light will light and stay lit, but will go out when you turn on the burner.
The most likley cause for patio heaters that light but go out when turned up is a worn thermocouple. These are consumable items that need changing when the patio heaters fails to light. Found this site very useful:
patio heater problem solving
Dec 31, 2012 | Stainless Garden Sun Steel Propane Patio...
We were given an 87" stainless steel propane patio heater. Our deck ceiling is 96". Will that be enough clearance?
Had a look at the manual on a BFX750 patio heater and the distance required is 50cm above (18") and 60cm to the side (24"). If its the same type with around 13kw or 44,000BTU/h of power then this is the clearance is needed for air and heat.
How much does the hss-a-ss stainless steel patio heater cost?
There are many generic patio heaters that use standard model codes, it can be very difficult to find who the supplier is. HSS or SS is a standard Chinese factory code, to find a price and supplier take a look locally or via the web and ask for Chinese patio heaters. Worth asking if they have a stainless steel burner, many just fit a chrome or tin plated burner, for more information found this very useful specialist patio heaters.
Jun 08, 2012 | Stainless Garden Sun Steel Propane Patio...
Broken patio heater
Hi, Depends on what is broken. If it will not light the first thing to go on a patio heater is a thermcouple, but it could also be a tilt switch. Found this very useful patio heater guide to problem solving.
Apr 22, 2012 | Stainless Garden Sun Steel Propane Patio...
I need the instructions on how to put my patio heater togeth
There is a specialist patio heater company that might help, they have lots of help pages, see patio heater tips, try emailing them for a manual.
Nov 22, 2011 | Stainless Garden Sun Steel Propane Patio...
I purchased GardenSun Patio Heater Model: HSS-A-SH and no screws or bolts came with it. How do I get or replace them? Thanks
Go back to where you got it and tell them. They should provide the needed pieces, free. If you have to buy them, they still should know what to give you. Good luck...Lee
Nov 24, 2009 | Stainless Garden Sun Steel Propane Patio...
Broken patio heater part
http://www.firepitsinc.com/customer-service.html
FIXYA is simply a web site where people answer questions for free.
The link above may have phone and email for a vender to help you buy a part. FIXYA doesn't sell parts.
Feb 14, 2018 | Arctic Products Lil' Arctic Sun Patio...
Arctic Products Lil' Arctic Sun Patio Heater Logo
278 people viewed this question
Top Arctic Products Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
Are you an Arctic Products Heating and Cooling Expert? Answer questions, earn points and help others
