Question about Car Audio & Video
I hookled up a crunch amp to my vehicle and the protect light comes on......
You Conected the power cables up wrong and the amp is protacting its self from being fried.Make sure positive and negative and remote turn on is correct
Posted on Nov 29, 2008
I have a Crunch Powerzone Pzi2250 1000 Watt Amplifier. and the red light blinks. What does that mean
My crunch powerzone pzi2250 1000 watt 2ch amp is stuck in protect mode. How do I fix this at home
Jan 16, 2011 | Crunch Powerzone P4175 Car Audio Amplifier
Protection light comes on , was only coming on when i turned up the stereo , now it stays on , all the wires are good and i cracked the amp open and nothing looks burnt
check your gain on your amp. If it gets hot the shuts off into protection mode you are over working your amp. Check to see the way your subs are wired up and see if your amp can handel the load.
May 20, 2010 | Crunch Drive V-3004 Car Audio Amplifier
I have a V 150 SE crunch amp. i have a red light
This more than likely means that you have a blown fuse. Go to an electronic store and replace the fuses. Make sure you get the exact same sizes and types that you had before.
Oct 24, 2009 | Car Audio & Video
Stock red light protection in my crunch amp
it is most likely a blown mosfet inside the amp
Aug 28, 2009 | Kicker SX400.2 Car Audio Amplifier
Changed speakers and now red protect light stays on? why?
the sub might have a short or is blown or the ohms are different
Mar 30, 2009 | Crunch PZi1000.1 Car Audio Amplifier
Help!!!!
It's likely that the amplifier has shorted output transistors. To eliminate other possible problems that can cause an amp to go into protect, read through the following page.
Amp In Protect - Troubleshooting
Jul 30, 2008 | Car Audio & Video
Crunch 400 watt amp
you' re problem is probably internal.
If you have the scematics you can sheck the components on the print.
Apr 27, 2008 | Car Audio & Video
My amp is on but no sound
Did you disconnect the battery? You may have bowwn a fuse, but that prolly wouldnt give you a protect light. Protect light usually means a short circuit, probably on the speaker end, sure there couldnt be maybe a single strand of wire crossing over the positive and negative speaker or amp terminals.
Feb 29, 2008 | Crunch P125.4 Car Audio Amplifier
My amp is on but the protection light stay's on!!
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If the protect light remains on, the amp likely has blown output transistors.
Feb 28, 2008 | AudioBahn A2801Q Car Audio Amplifier
Red LED "Protection Light is on" What is the problem
The red light means the amp is in protection mode. A few things can cause protection mode..... First disconnect the subs completely from the amp, and turn it on, if it powers up you have blown subs. Also try checking the main power wire at the battery...sometimes the current your meter is seeing is backfeeding from the remote wire, so your main power line could be blown at the fuse under the hood. hope this helps
Jul 17, 2007 | Crunch BlackMaxx BMX2250 2 Ch 1000W Amp...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
