Question about Daewoo DTQ-20N3FC 20" TV
Horizontal 'pinstripe' lines on all channels
My Daewoo tv has started to develop very thin horizontal lines across the screen on all channels (including av). They resemble pinstripes and are sometimes horizontal, sometimes with a slight angle (maybe 10' from horizontal). Can it be fixed?
  • vil1363 Feb 21, 2008
    i need this part tms-73c47ey
    New Friend:
Pinstripes across tv screen
Posted on Dec 24, 2012
    Scholar:
  • 119 Answers
Sound like the screen control on the flyback is set just a little too high. the flyback has the red wire attached to the tube. the flyback has 2 small adjustable controls. if you look close enough 1 is marked focus & on is screen. turn the screen slightly to the left & look at your picture. the screen is like a master brightness & if it's up too high you will see what is called retrace lines. good luck.
Posted on Jan 16, 2007
  • r-r-r-really Jan 11, 2011
    I just picked up Sylvania 27" CRT type tv with similar problem. I will try this solution and re-post if I have anything.
Horizontal Band of Thin Red and Blue Lines on Screen
Sound like your Y-Sustain board has one foot in the grave. The Y upper buffer and Y lower buffer boards go when the Y Sus Goes too...
Mar 22, 2014 | Panasonic TCP46C2 46 in Plasma TV
I have horizontal lines over the whole tv,but the tv play you can see them good on some channels.Wat could be the problem?
There is mainly two reasons for this fault. The smoothing capacitor to video output supply voltage be bad, or the screen voltage to CRT is more than normal. These lines [thin horizontal lines runs across the screen; an inch apart or so to entire screen] is technically called 'vertical retrace lines' If you wish to get more details about this fault, check this site. It has details about it. Pull up older posts there.
Feb 10, 2013 | Televison & Video
Multiple horizontal lines runnning across the
It sounds as though you have a poor signal issue. Firstly try rescanning all the channels. If no difference check the aerial/dish connections, then rescan. Lastly check the aerial/dish externally for misalignment and connectability.
Jan 03, 2018 | Samsung Televison & Video
Horizontal lines on my LG 37'' 7000
Nothing you can do but be patient.
Dec 12, 2009 | Televison & Video
Black horizontal line across the middle of the plasma TV screen
It could be a defective Y-Buffer board, or a defective Plasma panel.
Oct 25, 2017 | Pioneer PDP-425CMX 42 in. Plasma...
Thin horizontal line across the screen
you need to replace the electrolytic capacitor in the horizontal section of of your tv sets,cause the capacitor is weak.need to repair
Jan 11, 2009 | Sharp 27C-240 27" TV
Black line running horizontally across TV screen
A line on an LCD, either horizontal or vertical usually means the video driver board is defective or the screen is defective, does it show up as black even on a dark screen? That means a line of LCD "shutter"s is not working and there is a problem that cant be fixed by a reboot or channel change. Bummer.
Feb 17, 2008 | Televison & Video
Horizontal lines on Screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 14, 2008 | Gateway FPD2275W LCD Monitor
Washed out colours and thin red lines across the screen
your problem is in red video circuit. please get it done with skilled tech.
Oct 05, 2007 | Panasonic CT-32SL15 32" TV
Open Questions:
See all Daewoo DTQ-20N3FC 20" TV Questions
Daewoo DTQ-20N3FC 20" TV Logo
859 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
