Question about Kenwood KCA-BT100 Wireless Headset
Kenwood dnx5120 unable to eject disk from dvd, message states that demonstration mode is active. How do we turn off demo mode?
  • lowfrontier Jan 23, 2009
    I am having the same problem with my head unit.
To turn off demo mode. Hold down the src button and hit the reset button and release it. Continue holding down the src button until the system is fully rebooted. You will then be able to eject your cd and it will be out of demo mode. Came from Kenwood tech support.
Posted on Jan 23, 2009
Tip
How to Turn Off Demo Mode
<span style="font-weight: bold;">Blaupunkt:</span><br /><br /> <ol> <li>Press the (PWR) to turn the unit off.</li> <li>Press the (DIS) and (1) simultaneously for more than 3 seconds to activate the demonstration mode.</li> <li>Press both buttons again from more than 2 seconds to cancel this mode.</li></ol>or<br /> <ol> <li>Try pressing and holding menu for 10 seconds to turn it off.</li></ol><span style="font-weight: bold;">Bose:</span><br /> <ol> <li>Unplug the unit and wait ten seconds.</li> <li>Plug it back it and press repeatedly on the eject button.</li> <li>The demo disc will eject.</li></ol><span style="font-weight: bold;">Clarion:</span><br /> <ol> <li>Press and hold the "D" button to enter the settings menu.</li> <li>Use the next track button until SCRN SVR is displayed, use the rotary knob to select "OFF".</li> <li>Press the "D" button to exit the settings menu. </li></ol><span style="font-weight: bold;">Garmin:</span><br /> <ol> <li>DO NOT DO THIS TO A FUNCTIONING UNIT. Hold down your MENU key, Go to your SYSTEM tab, SYSTEM INFORMATION.</li> <li>When the software version window come up, hit ENTER.</li> <li>Press RANGE UP 3 time, Range DOWN 3 times, RANGE up 1 time, RANGE down 1 time.</li> <li>The system should reset, when asked to use RETAIL mode say NO.</li></ol><span style="font-weight: bold;">JVC:</span><br /> <ol> <li>Hold down the SEL button for 2-3 seconds.</li> <li>Use the &lt;&lt; or &gt;&gt; buttons to find DEMO.</li> <li>Turn the VOLUME knob until it says OFF or DEMO OFF.</li> <li>Press SEL again.</li></ol><span style="font-weight: bold;">Kenwood:</span><br /> <ol> <li>Go into standby mode, hit menu and then press "hold". A menu should pop up.</li> <li>Use knob to select demo.</li> <li>Press in on the knob and hold until it says "demo OFF".</li></ol>or<br /> <ol> <li>Switch to Standby.</li> <li>While holding down 5, press Reset with a paperclip or similar and continue to hold down 5.</li> <li>Demo mode should now be off.</li></ol><span style="font-weight: bold;">Magnavox:</span><br /> <ol> <li>Press and hold the menu button for 5-10 seconds until the normal menu pops up and then go to the section that says demo and turn the demo mode off.<span style="font-weight: bold;"></span></li></ol><span style="font-weight: bold;">Pioneer:</span> <ol> <li>Turn the vehicle's key to the Accessory or ACC position.</li> <li>Press the "Source" button, located on the left-side of the radio, and press the "Off" button that appears on the screen to turn off the unit.</li> <li>Locate the "Volume/Mute" button, located on the left-side of the unit.</li> <li>Press and hold the "Volume/Mute" button until the demo mode turns off.</li></ol>or<br /> <ol> <li>Turn the radio off.</li> <li>Push "Memory 5" or "Memory 6" (depending on your model) for just a second.</li> <li>When you hear a beep, demo mode is off.</li></ol><span style="font-weight: bold;">Pioneer Premier:</span><br /> <ol> <li>With the unit Off and the car ignition On and Running, press button number 5 and release that button to turn off Demo mode.</li></ol><span style="font-weight: bold;">Sharp:</span><br /> <ol> <li>When the unit is in the power stand-by mode (demonstration mode), press the X-BASS/DEMO button.</li> <li>The demonstration mode will be cancelled and the display will disappear.</li></ol><span style="font-weight: bold;">Sony:</span><br /> <ol> <li>Press display twice to turn off Demo mode.</li></ol>or<br /> <ol> <li>Press and hold the select button.</li> <li>Press the select button repeatedly until the desired item appears.</li> <li>Rotate the control dial to select the setting DEMO.</li> <li>Rotate the control dial to select the setting DEMO-OFF.</li> <li>Press and hold the select button.</li></ol><br />or<br /> <ol> <li>Press the STOP and the EJECT buttons simultaneously for 5 seconds.</li> <li>UNLOCKED should now appear in the display and you should be able to eject the disc.</li></ol>If Demo mode comes back on every time you turn off the ignition and back on, you have a wiring problem with your Constant +12 Volt Memory wire.
on Jun 22, 2011 | Audio Players & Recorders
My unit will not let me eject dvd disc it says it cant eject while in demonstration mode how do i shut the demo mode off
shut off the unit .press and hold for 30 seconds SRC and reset . then while pushing the SRC release the reset botton,hold it until the unit turns on and release it.
I tried it it worked well. (for Kenwood DDX7017 ).
May 17, 2011 | Kenwood DDX7017 Car DVD Player
The reciver is stuck in demo mode. Can`t get it out of demo mode.
The demonstration will activate the first time you turn on
the power. When the demonstration starts, the following
message appears in the display:
“NOW DEMONSTRATION MODE IF YOU FINISH DEMONSTRATION PLEASE PRESS POWER KEY WHILE THIS MESSAGE APPEARS IN THE DISPLAY THANK YOU”
To cancel the demonstration
Press the Power 1/0 button to turn the receiver off while the above message is being displayed. The next time you turn the receiver on, the demonstration will not appear.
It's in the manual - page 3.
Jun 10, 2010 | Sony STR-DE445 Receiver
The function DEMO MODE can´t be set off. I want to set any wall paper and the DEMO MODE stay ON.
CLICK HERE for a PDF version of your manual.
To turn OFF DEMO mode - go to page 50 of the manual.... and find the following-
1 Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO Mode" display.
2 Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches as shown
below.
Demo Mode "ON"
Demo Mode "OFF"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 10, 2009 | Kenwood KDC-MP7028 CD Player
Demonstration Mode on in dash tv
To turn off, Press and hold in the SRC button and while holding press the reset button. Continue to hold the SRC button until the unit powers back on.
Mar 11, 2007 | Kenwood Excelon DDX-7015 Car DVD Player
Demo mode problem
From the user's manual (pg.23): 1. Select the Demonstration Mode. Push the Control knob towards [FM] or [AM]. Select the "DEMO" display. 2. Set the Demonstration Mode. Press the Control knob for at least 2 seconds.
Feb 13, 2007 | Kenwood KDC-MP232 CD Player
Kenwood KCA-BT100 Wireless Headset Logo
542 people viewed this question
Top Kenwood Radio Communications Experts
eradiostore
eradiostore
michael galang
Jaime Hernandez
Are you a Kenwood Radio Communication Expert? Answer questions, earn points and help others
