Question about LG WM-1832C Front Load Washer
Getting error code on lg front loader washer
I have a lg wm1832 front load washer that gives me an error code of fs. Can you help me with this problem.
  • 1 more comment
  • aj546 Nov 29, 2008
    Sorry Rick my fault the error code for the lg washer wm1832cw should have read fe sorry for the confusion and thank you for your help. Hope you can help with the error code now.
  • aj546 Nov 30, 2008
    Ric it is the hot water that is the problem cold is fine. would it possible be the valve where the hose connects to that could be faulty? Again thanks for your help.
  • sgregg308 Mar 02, 2009
    I have an LG Tromm washer and it has an LE code. Whats does that mean and what is the solution
  • 706 Answers
Hello aj546,
Kinda figured there was a miscue there with your error code however... the error code FE refers to the fact that water is overflowing ( normally means the inlet water valve is stuck open and continues to let in water beyond the expected and/or sensed level.. so the water pump turns on to drain it and keep the level down. This kind of problem would probably warrant a aservice call from a tech since the majority of troubleshooting would require diagnosing the failed component itself and is not something that I recommend you try. There are too many pieces of hardware that have a direct impact on how this works and I highly doubt you want to play the shotgun approach..try this to see if it fixes the problem and if not..try that...
Before calling for service.. try this..
remove or disconect ac power from the washer..let it sit unplugged for at least an hour..then try washing 1 towel at the lowest cold water setting to see if that works ..if it does..repeat the process using only hot water.. if that works... then try the same test using warm water.. ( this test may help determine if the water inlet valve .,.either hot or cold is leaking through it)... If you still get the FE test..call for service.. That's the best I can offer via this chanel... BTW..if only one of the two tests fails.. ( Hot water only generates an FE error.. then chances are the hot water inlet solenoid valve assembly is either sticking open or the controls to that are commanding it to remain open... Hope that helped you..'
Regards,
Rick
Posted on Nov 29, 2008
  • 706 Answers
Hi Again,
I am not sure how to interpret your response when you say "it is the hot water that is the problem cold is fine" When you say it is the hot water that is the problem..are you saying that when you run a hot water cycle only that you get an overfill condition which in turn cuses an FE error? Did you swap the hoses to teh inlet valves on the back of the washer and the problem stayed on the same side ( meaning that if the problem showed up as the hot water wash over-filling when you ran a hot water load, you got an overfill condition when you ran a hot water fill again but with the cold water hose connected to teh hot water side of the washer?) What I am getting at is ..is the problem ( regardless of what temp you set your wash at) consistent with the cold or hot water inlet valve? If it is,,, then you have bypass water leaking thru that valve.. which could be the valve itself is damaged, contaminated with foreign materal so that it cannot close all the way or the conmtrol circuit is not commanding it closed when it should be... So my friend.. those are a few questions I have for you to mull over and get back to me.. It looks like we are getting close to solving the problem thou.. Get back to me when you can with your findings..
Regards,
Rick
Posted on Nov 30, 2008
  • 706 Answers
Here is a link to get the service manual with ALL the LG error codes for your washer.. It does not show FS as an error code however.. perhaps you are misreading the display. Ifthat's the case..this manual will help troubleshoot your problem.. Good luck
http://136.166.4.200/contents/Laundry/WM1832/WM1832xx_Service_Manual.pdf
Regards,
Rick
How to fix the error code E40 on Electrolux EWF1073 Front Load Washer?
I don't have an electrolux, but I have an LG front loader. Mine was giving a simular error code, and I found the drain hose filter was clogged. Bee running fine since
May 07, 2014 | Zanussi ZWF1640 Front Load Washer
How to fix a EHE error code
1. Start the drier normally
2. Before the "EHE" error appears, open the drier door!
3. Because the door was opened during program, "dE" error is shown
4. Close the door and press "start/pause" to continue
5. Program will continue normally; problem fixed!
Apr 30, 2014 | LG WM3431 Front Load Washer / Dryer
Lg washer error codes
I am getting error code UE on my front loader LG washer
Jan 05, 2014 | Washing Machines
Have a LG front loader and it's giving me LE error code and water is in the machine..... What is LE???
For LG's 'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
We cannot help any further from a distance.
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Sep 04, 2011 | LG WM1812C Front Load Washer
Getting a "te" error code -- a heating issue?
I had the tE or te error (an L with a line through it) error on my LG front loader and my local appliance store sold me the thermistor for $7. I layed the unit on its side and accessed the thermistor through the bottom. It plugs into the bottom of the tank. Blue and white wires. No screws and 1 tie-wrap. (Leave the rubber grommet in - just pull the thermistor rod out.) Works like a champ!
Jan 05, 2011 | LG WM2487H Front Load Washer
LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
Jan 03, 2009 | LG 4.0 Cu. Ft. 7-Cycle Front-Load Washer -...
OE error code on LG front loader
The OE error code means:-
The Drain hose is kinked or blocked or the drain filter is blocked
Solution:-
Clean and straighten the drain hose and clean the drain filter
Nov 01, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM-1832C Front Load Washer Logo
2,199 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
