Question about First Alert SA302 Dual System Smoke Detector
Replaced battery, test button will not work - First Alert SA302 Dual System Smoke Detector
    Novelist:
  • 152 Answers
Hello make sure that the cover is on properly or the button will not reach the inside contac also make sure you have a fully charged batery sometimes sitting in the store so long they go dead or they are old stock with very little charge left.
if all else fails replace the unit better safe than sorry.
good luck
Posted on Dec 10, 2008
My remote stopprd working! I replaced the batteries and it still does not work! FCC ID. M8CRL. 103
Disconnect power at the source, then remove batteries from remote and press all buttons to eliminate a stuck button problem. Reinstall batteries. Restore power and test operation.
Jul 05, 2016 | Dryers
Replaced batteries on a Fortress 520 but the led still shows rb to replace battery
Have the UPS perform a self test. Pres and hold the on button or the test button.
Feb 12, 2014 | Powerware Best Power Fortress UPS System
AT&T 974 phone intercom button flashing and won't work
1) test the adapter if working with another phone and replace it
2) if working clean the contacts batteries with pencil eraser, and see if working.
3)test the batteries voltage is o.k wit VOM, and replace if necessary
4) test the power supply from the base if is o.k otherwise you must open and repair or go to the repair shop for fix it.
5) Read the owner manual section troubleshooting for help
God bless you
Sep 17, 2012 | Lands Phones
The buttons on my TI-30X IIS are not working except for the 0, equal and second buttons
Sounds like you have a shorted out circuit card. Try replacing the batteries first to see if the power returns to the keys. If that doesn't work, you will find it cheaper to find a replacement calculator vs sending it to an authorized factory repair center. Hope this helps.
Dec 11, 2010 | Texas Instruments TI-30XA Calculator
Only one side of the outlets work...
From the User Manual:
“OVERLOAD/CHECK BATTERY” LED: this red LED lights continuously after a self-test to
indicate the capacity of the battery-supported outlets has been exceeded. To clear the overload, unplug some of your equipment from the battery-supported outlets; then use the ON/OFF/TEST button to run a Self-Test. If the UPS continues to detect an overload, remove more equipment and repeat the self test until successful.
CAUTION! Any overload that is not corrected by the user immediately following a self-test may cause the UPS to shut down and cease supplying output power in the event of a blackout or brownout.
The LED flashes to indicate the battery needs to be recharged or replaced. If the LED flashes (and a continuous alarm sounds) during a prolonged blackout or brownout, the UPS’s batteries are nearly out of power; you should save files and shut down your equipment immediately.
If the LED flashes following a UPS self-test (after the UPS is turned ON), it may indicate that the battery needs to be replaced. Allow the UPS to recharge continuously for 12 hours; then use the ON/OFF/TEST button to run a Self Test.
If the LED continues to flash, contact Tripp Lite for service. Should your UPS require battery replacement, visit Tripp Lite on the web at www.tripplite.com/support/battery/index.cfm to locate the specific replacement battery for your UPS.
Hope this helps!
Jul 25, 2010 | Tripp Lite Internet Office INTERNET550U...
My remote stopped working with my television. all I need is a manual that I cannot find. for CL007 remote
Remotes are pretty simple things to fix. a few problems, tests and fixes.
1) test remote closer to device - if it works then replace batteries.
2) If some buttons fail to work that used to work - disassemble and clean muck off board and rubber contact pad.
3) remote will not work at all at any distance - use camera on phone to see IR led operation when pushing buttons on remote - could be batteries, IR led failure or ceramic resonator failure - you need test equipment to faultfind.
The only parts that tend to fail on a remote are batteries, IR LED, Ceramic resonator, and dirty/wet board/rubber contact pads
Mar 19, 2010 | Zenith ZN620 Remote Control
My apex digital converter's remote no longer works. Therefore I have no TV picture because the apex wants to be re-installed due to loss of electricity temporarily.
Mar 19, 2010 | Televison & Video
I can't tell if the battery needs to be replaced in our Belkin 900. Should the green indicator on the front be completely lit up? Only one seems to be.
Link to manual:
http://cache-www.belkin.com/support/dl/f6c900.1100unv.pdf
Turn on your UPS by pressing and holding the On/Off/Test
button for approximately 2 seconds until the “ON LINE” Green LED
comes on. Pushing the On button less than 2 seconds is a test function.
Simple test: plug a light into one of the battery backup outlets. Then unplug unit. If the light stays on then it's working and the battery is ok.
Mar 02, 2010 | IBM Belkin Enterprise 900VA (31P7076) UPS...
Camera battery is dead and was just bought a week ago
If the contacts have been cleaned in the battery chamber, check the lower contact post - it's spring loaded and often gets stuck and doesn't make good contact with the battery. A little WD40 usually will free it up. Your batteries are probably still good.
Oct 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
First Alert SA302 Dual System Smoke Detector Logo
93 people viewed this question
Top First Alert Home Experts
JOHN LAPIER
Tom Chichester
Are you a First Alert Home Expert? Answer questions, earn points and help others
