Question about Kenwood KM300 Chef Stand Mixer
Kneading Blade Stuck on Kenwood Mixer KM300
The kneading blade on my machine is stuck inside and won't come loose for cleaning, changing,etc. Any ideas? Thank you.
Lightly tap out the dough with a piece of wood in the direction you would usualy remove it
Posted on Jan 29, 2007
Why wont my food processor work?
[PDF]Food Processor - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-xp.pdf
CuisinartDough blade, metal chopping blade, 3 slicing discs, shredding disc, detachable stem... food processing technology plus the largest work bowl on the consumer ...
[PDF]Download Manual - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/dlc-10s.pdf
Cuisinartwork bowl, cover and pusher ... The work bowl won't come off until the ..... DOUGH.BLADE. 12. The Pro Classic1" Food Processor can mix and knead dough in a.
[PDF]INSTRUCTION BOOKLET - Cuisinart
https://www.cuisinart.com/share/pdf/manuals/fp-12dc.pdf Cuisinart12-Cup Cuisinart Elite Collection® 2.0 Food Processor FP-12N Series. For your ...RECOMMENDED MAXIMUM WORK BOWL CAPACITIES ... dough blade, adjustable slicing disc, reversible ...... immediately after use so food won't dry on them ...
[PDF]Premier Series 7-Cup Food Processor DLC-2007N - Cui
Jan 01, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Blade is stuck in shaft of kitchen aid
Get some CRC around the shaft and into the beater hole and wriggle it about until it comes free. Rasp the build up in the beater hole out with a round file and clean up the shaft on the mixer. Remember you are cleaning out the hole not trying to make it bigger than it was. In my experience it is a build up of flour in there bonding itself to the hole in the aluminium beater.
Aug 31, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
I have a kitchenaid 600 professional stand mixer. I was told that you can only use the dough hook with setting 2 for only 5 minutes. What do you do for recipes requiring a longer time for kneading? Is...
You can knead longer than that, but you run the risk of over heating the mixer because at that point the dough is very firm. Your best bet is to knead it by hand.
May 14, 2010 | KitchenAid KP2671 Professional 6 Series...
Kitchen aid mixer speed control
sound like the link from the speed control to the motor has broken check this and good luck with the wife
May 15, 2009 | KitchenAid K45SS Classic Stand Mixer
Dough hook stuck in machine
Hi. Is it possible that some of the dough or flour you are mixing has made it's way into the attachment point with each batch, and therefore gumming it up progressivley ? Carefully lay the mixer on one side, being carefull not to lay it on the side mixer controls. Use a rolled up towel to support the head, this will make it easeir to see the attachment point. If there's a buildup of flour, wet it with warm water and a little liquid soap, until it softens, remove the attachment and clean the areas of contact. Apply a bit food oil to the hook before using next time.
Re: your second mixer The head locking pin may also have flour in it. This would inhibit the movement of the locking mechanism along it's guides. You may have to do some disassembly to get it cleaned out. After cleaning put a drop of regular oil on the moving parts. Be sure to clean the recess that the pin fits into as well.
If that's not your problem, then the pin may be worn enough to not fully engage.
If I have assisted you, please rate my solution. Good luck! ricardok45
Mar 11, 2009 | Kenwood KM300 Chef Stand Mixer
Blade won't release from mixer
Try to push up while you turn the blade. Don't be afraiid to turn hard.
Dec 30, 2008 | KitchenAid K5SS Heavy Duty Commercial...
Hobart A200 noises
Hi, here is my opinion: 1) your planetary, or attachment hub is making the noise as it goes around, and there is grease in the gear ring that keeps it lubricated, it may be as simple as removing the planetary grease ring ( the chrome ring), and taking loose the bolt and lowering off the hub and cleaning the old grease, and installing new, reassemble in reverse. You may also have bad bearings in the shaft portion of the planetary ( the shaft your attachments go onto) allowing the shaft to "wobble" a little bit causing a slight misalignment as the smaller gear goes around while mixing. How far you want to go is up to you.
For your other problem, I have seen the brass clutch bearings stick on the main shaft in the transmission, causing the planetary to momentarily speed up, or to maintain a wrong speed ( 2nd or 3rd) when set to first, but that would require full disassembly of the transmission. Best left to someone who has done it before, but if your inclined, go for it, but get a part breakdown first, or take pics as you go. Hope at least some of that helps, and thank you.
Nov 25, 2008 | Hobart A200 Stand Mixer
Kitchenaid Stand Mixer - gear assembly coming loose
There should be screws to tighten. Or maybe the pin holding the gearhead on is missing, tho that is unlikely.
Jan 21, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Kenwood KM300 Chef Stand Mixer Logo
687 people viewed this question
Top Kenwood Food Mixers Experts
Steve Allison
Steve Allison
Marvin
Marvin
nightiw
Level 1 Expert
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
