Question about Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer
Maytag Neptune MLG2000AW Frontland Neither Washing nor Spinning
My 6 yr old washer just stopped working. When I turn it on, the water pumps into the tub, the door locks and light comes on. After the water fills, the dial doesn't move forward and a few seconds later the "On" light goes off. A few seconds later the Door Lock light goes off and door can be opened. I manually moved the dial to the next cycle and pushed the On button; the water drained out of the tub and the same thing happens again with the On light and Door Lock light going off.
I called a repair man and he came and opened front panel and said that the power was coming and when light goes out the power is off but he had no clue what it could be. He will call Maytag on Monday and get back to me. He just took my money and left without diagnosing the problem.
  • 1 more comment
  • sss776 Nov 29, 2008
    Would you elaborate further? I'm not a mechanic so I don't know what that means. How does one check and what part of the machine does one check. There is one panel on top that I've opened with a whole bunch of wires that are connected to all the dials and buttoms. The bottom panel below the door has a circuit board and what appears to be the motor in the back.
  • scott-staple Feb 10, 2009
    my washer is doing the same thing. it will turn on for like 3 seconds then turn off. the light on switch comes on then goes off when it shuts off. but the lock button does not come on unless i hold the button to fill the washer. but then it turns off. and it wont drain the washer by it self with out holding the button right before the rinse cycle. if any one can help us it would be help full.
  • Garny1234 Mar 25, 2009
    I have the same problem.  I know that is not the servo motor/circuit, not the start/stop button and it is not the wiring harness.  I think it is the main control board.  I have already replaced the wax motor, Q6 and R11 on my unit.  It acts like a interlock switch is not made, or is open.
  • 121 Answers
Sounds like the moter speed control
Posted on Nov 29, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag Neptune Front Load Washer is not draining all the way most likely not spinning well either. Clothes still have water in them when removed from washer and take forever to dry. Has anyone experienced...
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 04, 2011 | Maytag Neptune Washer
My neptune washer will not drain the water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer front loader has been great but my wife pointed out that it doesn't drain all the water out? The thought of that old water under the spinning basket (dont know the tech term) doesnt...
Yes, the Neptune is a great washer, arguably. :-> You just may have a clogged pump. Pull the back panel and the rest is evident. Pull baffles, remove gookus, pull pump, clean, etc. ...just like a plumber. Be sure to pull the rubber baffe directly from the bottom of the outer tub. You may need a wet/dry vac to assist you. It's a bear of a job but I do it all the time.
Rich
Western Appliance Repair
Washer Repair Meridian
Oct 09, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
Jul 10, 2010 | Maytag Neptune Washer
The washer is spinning, but water is not being drained out.
your pump is blocked .or the drain pump has stopped working.adrian;;;
Nov 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Problem
replace the door latch wax motor and check the drain pump for obstructions.
Jun 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
Won't pump out water
Loaded in truck hauled to repair shop.
May 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MLG2000A Front Load Stacked Washer/Dryer Logo
327 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
