Gateway mx6930 laptop freezes up every 10 minutes - keyboard and mouse become inoperable
  • 340 Answers
Perform the steps given below to increase you system performance.
Uninstall all unwanted software.
To uninstall software:
Click on Start -> Settings -> Control Panel -> Add/Remove Programs
Select the software (one at the time) from the list and click on Add/Remove button and follow the online screen instructions.
Erase unnecessary files in the windows temporary folder.
Double Click My Computer.
Double Click the drive where windows are installed. This is typically drive C.
Double Click the windows folder. This is typically C:\Windows.
Double Click the temp folder. This is typically C:\Windows\temp.
Press control A to select all files and folders.
Press the delete key.
If confirmation is asked to delete these files choose yes to all.
Defragment hard disk.
Close all applications.
Disable your screen saver.
Disable all the programs on the taskbar if possible.
Click Start.
Click Program.
Click Accessories.
Click System Tools.
Click Defrag.
Select the drive to defrag. You should defrag every hard disk on your system. This process can take quite some time.
Click Ok.
Enable your screen saver.
Remove Startup programs (if you know what you are doing)
Click Start
Select Run
Type msconfig in the text box
The "System Configuration Utility" window will open
A list of programs will be shown each having a checkbox to the left of the name.
Click on the checkbox to enable the program (so it runs when windows boots) and click a second time to Uncheck the box to disable the program (so it does not run when windows boots).
Set the size of the virtual memory (swap file) to a constant optimal size.
Right click My Computer
Click Properties
The System Properties window lists the amount of RAM in your PC
Click Performance
Click Virtual Memory
Click Let me specify my own virtual memory settings
Click the arrow next to the hard disk.
Here are some guidelines to choose the best location for your virtual memory file
a) Select the quickest hard disk.
b) If you have, two hard disks that are similar in performance select the hard disk that does not contain Windows system files (usually C:).
c) Make sure the drive has free space equal to at least twice the size of the recommended swap file size.
d) If the partition is on the same physical drive, select the partition in alphabetical order. For example, if you have one 20GB hard disk and you partition it into two 10GB partitions drive C & D) You should pick Drive C over Drive D if meets all the guidelines of a, b & c.
Set the Minimum/Maximum to: With large hard disks settings at least 128mb or 256mb swap file should be sufficient in almost every situation.
Note: The amount of RAM plus the size of the virtual memory file is the maximum amount of RAM you can use at once.
Click OK.
After setting the size of the virtual memory file windows will display the following message. You have chosen not to let windows manage virtual memory automatically.
Click Yes.
You must restart your computer before the new settings will take effect. Do you want to restart your computer now?
Click Yes
Next :-) please vote if this help you
Posted on Nov 29, 2008
  • Teis Thomsen
    Teis Thomsen Dec 05, 2008
    When less than a quarter feel the need to vote for the effort some of us at FixYou offer, I think to myself, ”is it worth it”.
    They get help, and do not care to thank you; “thank you” do not cost a dime, so why????
    /Teis
The problem of freezing is due to Energy Saving setting in Windows 7 or Vista.
Posted on Dec 27, 2009
  • bio2 Dec 27, 2009
    The freezing problem is due to Energy Saving setting in Windows 7 or Vista. Disable the setting and no freezing.
P875 satellite keyboard
Do the key lights flicker when on freeze stage? I had such a problem with my keyboard, it died after around a month :(
Apr 12, 2013 | Computers & Internet
How do i access the @ on the key when i do shift and the key it will not type @
Hold down the Shift key by using your one finger and by using the other finger hit number 2 or @ key together. It must type letter @.
May 18, 2010 | Gateway Laptop Keyboard for MX6930,...
My new imicro mouse won't work. Why?
may be ur mouse become faulty or the port in which u r connecting mouse become fault.just check ur mouse on any other pc.
if found useful vote plz
Feb 20, 2010 | Microsoft Wireless Notebook Optical Mouse...
Im trying to replace the dc jack on a gateway mx6930. I need help removing the case to get at this. You know I removed all visable screws from the case, started prying, and stoped as not to break anything....
yes you need to pull ALL parts HDD, dvd drive,....
then turn it over and pry loos the cover above the keyboard you should then be able to remove the keyboard
Jun 08, 2009 | Gateway MX6931 Notebook
Mouse moves on its own
Your palm might be brushing on the touch pad while you are typing that is probably why the cursor jumps to a different location. as for disabling the touch pad I think that it is not possible unless you install a synaptics driver for your laptops touch pad.
Apr 01, 2009 | Gateway Laptop Keyboard for MX6930,...
Shortage?
There is a ribbon cable between the laptop & the screen. It sounds like you have a short in that cable. If you're not good with tedius electronic repairs, it would be best to have a shop repair it.
Mar 25, 2009 | Gateway Computers & Internet
Wireless keyboard and mouse freeze and become completely inoperab
Its probably a compatibility issue with the hardware. The best is to use cabled mouse and keyboard.
Jan 18, 2009 | Sony VAIO VGC-LV140J 24-Inch All-in-One PC...
Gateway notebook MX6930 trackpad issue
Has the left mouse button ever worked? If so when did it stop working, make a system restore to that date
Nov 17, 2007 | Computers & Internet
Computers & Internet Logo
627 people viewed this question
Alun Cox
David Payne
David Payne
