Question about Nokia 3110 Cellular Phone
Transfer pictures from Built In Memory to Memory Card
Is it possible to copy a picture from "BUILT IN MEMORY" on to a MEMORY CARD ? Thank You, Carol
  • 495 Answers
Yes you can, check for options like "Copy to memory card". Suppose you want to transfer a image file, then click "options" text on the image file will provide you copy options.
Posted on Dec 01, 2008
Copy pictures in built in memory to memory card
You have to connect to a pc, transfer the pictures to the computer, then you can transfer them from the computer to the memory card file on the camera.
Jul 30, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
I took pictures on my camera without a memory card can i still download my pictures
I'm glad to provide the steps to transfer images from Internal Memory of the Camera. When the camera does not have a memory card in it, the images are saved by default to the camera's internal memory, which holds different amounts of images based on how many megapixels are built into the internal memory and what image quality and compression are selected in the camera's menu. Once a memory\picture card is inserted in the camera, the camera then saves the photos to the memory\picture card and ignores the internal memory.
There are two ways to transfer the images from the internal memory.
  • To transfer photos to a computer from the internal memory using the USB cable, first remove the memory card from the camera. Then, when the camera is connected, the computer and software will only see what is in the internal memory and transfer those photos or videos. During the transfer process, the computer makes copies of the photos and videos-the original images remain in the internal memory. After the transfer is complete and the camera is safely disconnected from the computer, the contents of the internal memory can be deleted by using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
  • The other way to transfer photos from the internal memory is to transfer them to the memory\picture card using the BACKUP function in the SETUP menu. If there is no memory\picture card in the camera, the BACKUP function is grayed-out. During BACKUP, copies of the images are transferred to the memory\picture card-the original images remain in the internal memory. After the BACKUP is complete, the internal memory can be cleared by removing the memory\picture card and formatting the internal memory using the MEMORY FORMAT function in the SETUP menu in the camera's menus.
Note: When the camera is connected to a computer using the USB cable with a memory\picture card in the memory\picture card slot, the computer will only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
Jun 16, 2011 | Olympus Cameras
I tried to install software which came along with my digital camera nikon coolpix s3000. After installation I opened the icon but it showed some error. I need to transfer pictures from camera's internal...
If you need it, you can download the current versions of all (free) Nikon software from
http://support.nikontech.com/app/answers/detail/a_id/61
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
To copy pictures from internal memory to the memory card, press the Playback button, select MENU, then select Copy.
Mar 08, 2011 | Nikon Coolpix S3000 Digital Camera
I have a DMC-LZ7, with some pictures on the built in memory. Can I transfer those pictures to a memory card? The pc cable doesn't talk to the camera.
Yes. There's a "Copy" option in the playback menu. It can copy all pictures from internal memory to a card, or individual pictures from a card to internal memory.
Sep 28, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
Hi i have a Panasonic Lumix DMC-FZ8. How do I
This should help
Press [ menu set] to display the [PLAY] mode
menu and select the item to set.
You can copy recorded picture data from
the built-in memory to a card or vice versa.
1 Press up/down to select the copy
destination: (in to card) and then press
[MENU/SET].
Jun 17, 2010 | Panasonic Lumix DMC-FZ8 Digital Camera
Built in memory
Go into the menu and find "copy". You will have the option to copy the internal memory to a memory card.
May 09, 2010 | Panasonic Lumix DMC-FX12 Digital Camera
I lost the download cable for my Exilim camera. There is a picture in the internal memory that I really, really need! How do I transfer the picture in the internal memory on to a memory card?
This procedure will copy all files from internal memory to a memory card.
1. Load the memory card to which to copy the files.
2. Turn on the camera, enter the PLAY mode, and press the MENU button.
3. On the "PLAY" tab, select "Copy" and then press right-arrow.
4. Use up/down-arrows to select "Built-in->Card" and then press SET.
Wait until the Busy message disappears before doing anything else. After the transfer the last file transfered will appear on the display.
Apr 14, 2010 | Casio Exilim EX-Z77 Digital Camera
Built in memory
From the Playback menu, select "Copy." This allows you to copy all pictures from internal memory to a card or vice versa.
The process is fully explained on page 79 on my copy of the manual.
Mar 17, 2010 | Panasonic Lumix DMC-FX12 Digital Camera
Kodak Easyshare M1063. Picture transfer.
Try NOT connecting your camera to your computer.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Aug 04, 2009 | Kodak EASYSHARE M1063 Digital Camera
Error message
the builtin memory was full , confirn first the picture transfer to your PC by opening on it before you erase from camera.transfer all record or picture to your PC and erase all pictures by deleting or formatting.
Nov 27, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Nokia 3110 Cellular Phone Logo
215 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
