Question about Samsung HCM653W 65" Rear Projection Television
Samsung HCM653W Convergence problem
Posted by hendricksfam on Nov 21, 2008
I have a above Samsung TV (HCM653W). RGB color not right. Ghost the image. I replaced the AssyPCB,SUB,PCL54R,P54A but no solutions. Which pcb board I should try to fix the problem. There are audio and video on the tv, but not right not pleasure viewable pictures. Please advise me If you have any idea.
Thanks for your time.
Nicky Patel My convergence is off, the red will align but the blue won't. And at the tope of my screen and the sides it's kinda bowed a little, so that when I align the red in the center of the screen the top and the sides are still off. The repair tech said it would be a $600 part threw him. I've been looking online and I see convergence modules for $60-$70. What should I be looking for to replace it. I definately don't want to spend $600 to fix it!
Tim Hendricks Comment posted on Nov 21, 2008 Heres a guide on the Convergence IC fix
http://cmpalmer.blogspot.com/2006/11/fix... That was very helpful to build up my confidence in doing this myself. But I am at a delima now, that was for a Panasonic TV and mine is a Samsung HCM653W, so now all I need to know is...What are the party number for the Convergence ic's that I need to buy now. I am almost certain that is exactly what I need, now seeing that Chris Palmer had the EXACT problem as I do.
Tim Hendricks Comment posted on Nov 29, 2008 Ok, I replace the IC Subconductors STK392-040 and I still have the same problem. The top and the right side of the screen are bowed in and the blue will not align. What else could the problem be?
  • Samsung Master
  • 5,138 Answers
CK low ohm resistors and pico fuses some are green,some are yellow .they will be around ics some may be under heat sinks that hold STKs.
Posted on Dec 22, 2008
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
Samsung HCM653W 65 in rear projection tv
its the convergence board/bulb problem for sure.check that and replace it.every thing will be fine.thanks.
Aug 22, 2008 | Samsung HCM653W 65" Rear Projection...
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Service code needed to complete convergence adjustments
I have the service convergence code: mute-1-8-3 (make sure your tv is on and set to antenna. if it doesn't work press S. Mode and make sure is says standard then re-enter code.
So, I have the code but I need the convergence chips. Where did you get the convergence chips?
Jan 26, 2009 | Samsung HCM653W 65" Rear Projection...
HCM653W color convergence off
Ck low ohm resistors 3.9 omh and pico fuses they look like resistors but they are green or yellow 5amps, 6amps,sometimes after replacing STKs there is bad resistors or open pico fuses.
Dec 22, 2008 | Samsung HCM653W 65" Rear Projection...
Ghost image
You will have to replace both the convergence IC's on your TV..
Oct 23, 2008 | Sanyo PLC-XR70N 70" LCD Monitor
Samsung Tantus HCM 22 convergence problem
Check this website to buy the entire convergence amplifier board. Replacing the entire boars is a DIY since there isn't any soldering involve only open back cover of the TV and unplug a few wires to remove the old board and install the new one. Keep in mind that this board could be used or reburbished.
Samsung no longer has the assembly.
If you need more info let me know.
Aug 28, 2008 | Samsung HCM422W 42" Rear Projection...
Samsung HCM653W
Convergence board will have 2 big black ics on it STK392-110s or 150s Use number on STK s in your set.To get parts call 1-800-223-3205 Electronix Parts.
Aug 25, 2008 | Samsung HCM653W 65" Rear Projection...
RGB COLOR PROBLEM.
You will need to check the plus and the minus convergence voltages in the main power supply. There are a couple of circuit protector fuses that go bad. Do not replace these untill you replace the convergence IC's or you will cause more problems in the main power supply. Good Luck
Apr 22, 2008 | Samsung HCM653W 65" Rear Projection...
Samsung HCM653W 65" Rear Projection Television Logo
251 people viewed this question
Henry  Thomas
Henry Thomas
