Question about Car Audio & Video
I have a CXSGT08HP sony car stereo. It was installed by a friend at home. The memory does not work. Can you tell me which wire is the memory wire and were i need to hook it up to?
  • 11 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Hi Justtamera,
I’m attaching a wiring diagram which hopefully isreadable. I’ll also list the “where to”instructions for all of the other wires. It’simportant that several wiring steps be done in a particular order.
About the Memory Wire:
The memory wire is Yellow and should be connected to the +12 V power terminal (which isenergized at all times). First besure to connect the black ground (earth) lead to a metal surface of the car.
Important…
>>Before making connections, turn the stereo unit and carignition off to avoid short circuits.
>>Connect the yellow and red power input leads onlyafter all other leads have been connected.
>>The power antenna (aerial) control lead (blue)supplies +12 V DC when you turn on the tuner.
Hope this helps. Lemme know if you have more questions or would like me to email you acopy of the owner’s manual.
Thanks, and take care.
Gail :-)
Connecting the Sony CXS-GT08HP Car Stereo Unit
1. To a metal surface of the car
>First connect the black ground (earth) lead, thenconnect the yellow and red power supply leads.
2. To the power antenna (aerial) control lead orpower supply lead of antenna (aerial) booster amplifier
>Notes
>>It is not necessary to connect this lead if there isno power antenna (aerial) or antenna (aerial) booster, or with a manually-operatedtelescopic antenna (aerial).
>>When your car has a built-in FM/AM antenna (aerial)in the rear/side glass, see “Notes on the control and power supply leads.”
3. To AMP REMOTE IN of an optional power amplifier
>This connection is only for amplifiers. Connecting anyother system may damage the unit.
4. To the +12 V power terminal which isenergized in the accessory position of the ignition switch
>Notes
>>If there is no accessory position, connect to the+12 V power (battery) terminal which is energized at all times.
>>Be sure to connect the black ground (earth) lead toa metal surface of the car first.
5. To the +12 V power terminal which isenergized at all times
>Be sure to connect the black ground (earth) lead to ametal surface of the car first.
Important…
>>Before making connections, turn the car ignition offto avoid short circuits.
>>When your car has built-in FM/AM antenna (aerial) inthe rear/side glass, connect the power antenna (aerial) control lead (blue) or theaccessory power supply lead (red) to the power terminal of the existing antenna(aerial) booster. For details, consult your dealer.
>>A power antenna (aerial) without a relay box cannotbe used with this unit.
Posted on Nov 29, 2008
  • gail lamarra Nov 29, 2008
    Sorry about the bogus paragraphs of format code. I typed your note/response in Word then cut/paste. The "bonus text" isn't apparent until you hit post/submit, and by then it's too late to fix. :-(
Install sony stereo in 96jeep
there are 2 ways to install a radio, (skipping hacked in)
1: the stock car adapter kit, sold everywhere even walfart.
2: or using the sony , install sheet and wire names
match those to car, names.
easy huh?
ground to ground.
+12vdc wire to same , ignition on. power.
memory wire to memory wire.
dial light to same.
LF speaker to LF speak
and the like, matched 1 for 1.
antenna to antenna.
here is one.
http://www.scosche.com/car-audio/installation/88-96-jeep-reverse-hrns
at wally
http://www.walmart.com/ip/Scosche-1989-1997-Jeep-Eagle-Car-Stereo-Connector/23000122
this does it right. no hack jobs.
the fsm pages show which color is what here
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
Feb 18, 2014 | 1995 Jeep Cherokee
2001 nissan pathfinder se wiring diagram
I have a 2001 Nissan pathfinder and had the stereo changed. The original stereo had the feature of the controls on the steering wheel but when the stereo was changed that feature no longer worked. I had brought the car to a shop where they installed that stereo and the controls were not working but I didn't want to bring it back to them. I now have a Sony Stereo in it now and would like to get the controls on the steering wheel working again. Could you please tell me which wires are the ones that connect the steering wheel controls to the stereo.
Mar 04, 2012 | Cars & Trucks
Sony Amplifier, Sony CD Player, Sony AM/FM Tuner, Sony FM Stereo/FM-AM Receiver, Stereo Cassette Deck........I need to know how to connect all of these components so I can use the stereo system...........a...
The actual task of hooking up a home theater may take a little time, especially if you are doing a custom installation with lots of separate components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
Jun 22, 2011 | Sony Audio Players & Recorders
MY DASHLIGHTS WENT OUT AND ITS NOT A FUSE. IT HAPPENED AFTER I HAD A STEREO INSTALLED ARE THJEY CONNECTED?
Who installed the stereo? A professional? Or you or a friend? Either way sounds like some wires touched something they shouldn't have! Take it back to where stereo was done and tell them to fix it.
Mar 13, 2011 | Chevrolet Monte Carlo Cars & Trucks
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
Car Door Speakers wont work after installing new Stereo
check you Fade and Balance,sometime the ground is used for two speakers sometimes a ground is used more then once will cause your problem ........Good luck......
May 14, 2009 | 1998 Ford Explorer
Illumination?
you need to splice the + wire into the Acc wire. the with power only when you turn the key. and the - wire into the black ground wire. hope this helps
Jan 29, 2009 | iLO XM-MP3-CD Car Stereo
Will the sony CXSGT08HP fit a 2000 Ford Taures?
yes, however you will need the dash kit (approx. $80.00) and modification of the braces inside the dash behind the "radio" In the taurus, the radio is actually located in the trunk. Only the dials are up front. Most installers will charge extra for this car's "extensive labor" but it can be done.
Dec 17, 2008 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Sony Home Stereo Fuse
When the wires touched, the output transistors overloaded before the fuse had a chance to blow. The outputs need to be changed. It is possible that the driver stage for the final outputs is bad also, but there is no way to know that without removing the bad outputs. Figure on $25-$45 in parts for this repair.
Dan
Aug 26, 2008 | Audio Players & Recorders
New stereo/speaker problem
You'll need to get at the speaker and wiring to tell. A substitute speaker will be needed as part of the test...accordianman
Jun 13, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Car Audio & Video Logo
610 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
