Question about Dishwashers
Drain hose problems
I have a kenmore ultra wash III dishwasher.  I am attempting to hook it up and can not find the correct type of drain hose (this dishwasher was given to me second hand).  what type of hose do you recommend?     Thank you Teri
  • 706 Answers
Hello Teri,
If you have access to a Home Depot or Lowes or any other home goods store, they should be able to provide a hose for you .. You may need to use a hose clamp to attach it but most of these types of home goods stores sell all the components for this... Since its a Kenmore ( you may be able to go to Sears and get a drain hose kit..but most drain lines are pretty much the same as long as they have the right ID and you have hose clamps.. Hope this helps you..
Regards,
Rick
Posted on Nov 29, 2008
Kenmore ultra wash dishwasher odor
Is the drain line going over an upper edge before connecting to the sink drain line? Also try to make a rinse with white vinegar.
Jul 06, 2015 | Kenmore Dishwashers
I have a Kenmore ultra wash model 665, stock# 15951. When the tub starts to fill the water runs out the drain.
This means there is either an air gap in the drain hose or the drain hose loop is less than 32" high preventing back flow
Sep 18, 2010 | Kenmore 24 in. 15159 Built-in Dishwasher
Kenmore ultra wash dishwasher won't drain tried
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Aug 27, 2010 | Kenmore 16764 Dishwasher
Kenmore Ultra Wash 15812990 won't drain... I have already checked the connection between the dishwasher and the house drain line and the issue is above that. Someone suggested I clean out the food...
I removed the kick plate and unhooked the hose that connects to the bottom of the dishwasher. When I didn't get a gush of water, I knew my problem was higher than that. I took a pair tweezers and stuck it up the spout and found nothing. So I attempted to drain the diswasher with the hose unhooked and got some water to come out. I did this several times and apparently flushed down a large piece of rubber--either from a water bottle or a broken piece from inside the dishwasher. I removed that piece and had pressure when the drain button was activated. So I hooked the hose back up and ran a rinse cycle--and it drained fine.
Oct 30, 2009 | Kenmore Dishwashers
Kenmore Ultra Wash III Dishwasher will not drain properly
Fixerfailure, is the knock-out plug still inside if the garbage disposal inlet?
Stick a screwdriver in there to make sure.
spazmo1969, could be the rubber flapper is broken off in the pump discharge outlet.
Dec 27, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Can't find replacement rubber seal for sink attachment
if it is on the hose then it should be a check valve.
Nov 24, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher Problem
there is no real way of checking the keypad. Not with a meter but if you push normal wash for example and it does not respond this usually means that you have a bad keypad
Nov 09, 2008 | Kenmore 15899 Built-in Dishwasher
From the sound of things, your dishwasher drains faster than your sink drain ( via the garbage disposal) can drain it off.. You may have a problem with the way your sink drain/trap is vented and there is too much back pressure to drain down quickly.. When you run water from your sink, does it take a long time to drain down or if you fill your sink up and drain it, does it drain slowly ? That may be your problem.. Hope that helps.
Aug 26, 2008 | Dishwashers
Dishwashers Logo
75 people viewed this question
Top Dishwashers Experts
