Question about Cooktops
Electric shock I'm not very familiar with ovens so I'll try to explain what happened in detail. My mom was cooking on the stove-top (Westinghouse with coils and tin foil underneath to catch drippings). It's pretty old and it's never had a problem before. Anyway, she also puts up this little fold-out piece of foil to keep back spray that sits on the top around the coil. About in the middle of cooking when it'd been on for a while, suddenly there's this LOUD buzzing sound and it starts spitting out white sparks from the coil. It did this twice and settled down, then we turned it off. It looks pretty normal now, but we're not using it again until we figure out what went wrong. Was it the foil? A short-circuit? Does it need to be replaced?
  • 706 Answers
Hello butterfly777,
Remove all traces of foil ( with power off) and make sure the coil is fully seated into the electrical terminal block.. these are typically just pushed in to seat them.. Run the heater up to full power and let it stay there for 10-15 minutes.. if you don't see any problems with it... in all probability its ok.. and can be run that way..
I am speculating on what may have happend... perhaps a piece of foil flashed on you and sparked a little.. foil is electrically conductive but the coil element itself is grounded externally so if it doesn't spark after it is run up during your test.. it should be ok.. If you are uncompfortable or feel it poses a threat..get a replacement heating element...
Hope that helps..
Posted on Nov 29, 2008
How to remove the stove top on frigidaire stove model FFGS3025PS
IF you open the door to the stove, you will see screws under the lip of the cook top, take those out, check the back of the stove for screws and then lift the cook to. On some models you may have to remove the sides of the stove too.
Mar 13, 2016 | Frigidaire Stove/Oven/Range Cooktop -...
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
My Jenn Air Electric stove is making a clicking noise. When I put my hand on one of the cook top knobs I can actually feel a vibration when the click occurs. What is this?
Gas stove? LP? It is probably the electric spark ignitor. Many times when you clean the stove top water from the sponge gets below. The water droplets (align mysteriously) make the connection between the wires, and the stove thinks it's supposed to be igniting. When the water evaporates, the switch will work fine again & the clicking should only occur when igniting & then backed off.
This happened to me once before.
Nov 21, 2010 | Jenn-Air 4 in. JEC0536ADS Electric Cooktop
I have a frigidare electric stove. The oven got
Thanks for using FixYa. Error code F1 means a bad Electronic Range control (ERC) and to resolve this issue you’ll have to replace the Electronic range control (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Jul 26, 2010 | Frigidare GLEC30S8C 31 in. Electric...
Broke glass on electric genn-air
Please do not use the stove if the element is viable because of broken glass, this could become a danger to yourself.
Look at the cost of a new stove, you should be able to get one for
around 400.00. One of my customers had a glass top with 4 burners,
they had the same thing happen, the cost to replace the top was
1,200.00. So I would assume that you can get a new stove with 4
burners less then it would cost to replace the part on a stove you don't like. Maybe there is a LOWES around you to look at stoves,
they seem to be everywhere,like death and taxes.
As for putting a 4 burner top on a stove that has 2 with grill, I don't think it can be done without the extra cost of adding the parts to run the other 2 burners, so like I said in the long run,it just might be cheaper to but a new stove. It should not be a big deal to remove the exhaust from the grill part of the stove.
I looked at the model# you put down,and it does not have a grill,
from what I see, there are 4 burners and a downdraft vent in between the 4 burners, there are 6 models with this part # and none have a grill,only the downdraft vent.
If the model# is right, the cost would be around 300.00 for the glass, and then the cost of having it replaced. So I would say over
400.00, In which case for the same amount you could have a new one, but you must weigh the difference for yourself and see what you think is the best way to go.
If you have any more questions,please post back and everyone is more than willing to help you. I hope I have helped a little.
Mar 24, 2009 | Jenn-Air JED8430 Electric Cooktop
3 wire cook top to a 4 wire outlet
Older 3 wire connectors where Wht=Neutral Ground Return, Red=One Phase Hot, Blk=Second Phase Hot, of 220VAC stove connections.
Newer Electrical code standard has a forth wire that is bare copper for a separate safety ground return.
I suggest you but a 4 wire pig tail cable for your stove top, available at Depot or Lowes, and connect 3 wires of this 4 wire cable just like the 3 wires are now connected. The 4th bare copper safety is attached to any metal part of the stove. Find a screw you can loosen to wrap it around and tighten.
Mar 02, 2009 | Jenn-Air JED8230 Electric Cooktop
Kenmore flattop stove
how do I change the eye on my electric 2000 kenmore smooth top electric range
Dec 12, 2007 | Kenmore 30 in. 42701 / 42702 / 42709...
Cooktops Logo
122 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
