CD ROM won't play
The drive shows up on the computer list and will eject the drive from there but nothing will play and windows auto play doesn't auto play
it's a
LG CD-ROM CRN-8241B on a IBM think pad 390x. I think I'm missing a driver for the drive. the problem may have started by the drive getting disconnected while the computer was running. please email me at crazyfingers42@yahoo.com if you can help thanks ~ dooooood
  • chrisjimm Nov 30, 2008
    same problem as listed. Windows sees the drive but cannot read it.
  • 153 Answers
Check the Hardare manager is there any question mark at the icons of the CD drive? If the auto play does'nt work then the CD-rom is not reading the CD, either the CD format is different or the CD-rom lens is faulty. Note: don't remove Hardware when PC is running, you might cause damage to your Hardware devices.
Posted on Dec 02, 2008
My emachines EL1850-01e Disc drive won't open, I've tried pressing the button and I can't find the eject button anywhere on my computer!
there is a small hole on or around the drawer . straighten a paper clip insert it in the hole to release the lock .
Feb 17, 2012 | E-Machines emachines (emachinees) CD-ROM...
I have an HP pavilion slimline s3600f desktop pc and the optical disk drive doesn't seem to be reading cd's or DVD's.
Check the Device Manager to make sure that the OS does not have any issues with the device. If there is an exclamation point ( ! ), then Windows has issue with it. If there is an " ! " then right-click on the device and select update driver.
If the drive shows in My Computer, right-click on the drive and select "eject" from the list. This will verify that the OS is talking to the device.
Check your BIOS settings to make sure that it appears in the BIOS and is not disabled.
Also, Microsoft recently released an update to disable Auto-Play on CD/DVD drives. If Auto-Play isn't working (due to this update), then put a music/movie cd/dvd into the drive and open Windows Media player and try to play the disc through there.
The drive may not be "broken" it just may be that auto-play has been turned off by Microsoft.
May 24, 2011 | HP Pavilion Slimline s3600f Desktop PC
I have a laptop that doesn't have eject button for slot cd player
go to Dektop / My Computer
right click
u will c all the drives....i mean..... c: d: etc
locate ur CD/DVD rom drive,..letter...d: or e: etc..
select ur CD/DVD rom drive
right click and chose option Eject...
u r set...
Dec 20, 2009 | Toshiba Sattelite A105-S2051 Notebook
The CD ROM Drive is not ejecting properly
hi,
Locking device / software installed
First, verify no locking software is being loaded, which would allow the CD-ROM tray not to open. If you are unable to determine this, reboot the computer and as it is booting up, attempt to eject the tray. No power to computer or CD-ROM drive
If you have recently installed a new CD-ROM drive or you have moved the computer, it is possible that the power to the CD-ROM may have become loose or disconnected. Check the cable connections. Bad eject button
If you are running Microsoft Windows 95, Windows 98, Windows NT 4.0, Windows 2000, Windows ME, or Windows XP, open My computer, right-click on the CD-ROM drive and choose the option to eject. If this ejects your CD-ROM drive tray, it is likely that the button on the CD-ROM drive has become defective and it is recommended that the drive be replaced. CD stuck within drive
It is possible that a CD may have become stuck within the CD-ROM drive. If the CD-ROM drive has a small hole (that is not the head phone jack), using a paper clip, place the paper clip within the hole and attempt to manually eject the CD-ROM tray. If the CD-ROM drive is only partially able to be opened, attempt to pull the tray gently to see if it can be manually ejected. If it cannot be opened any further, it is likely that the gears within the CD-ROM drive have become bad, dislodged, or that a CD is positioned in the drive, which does not allow it to open. Incompatibility with IDE / ATAPI interface
If you have an IBM compatible computer and recently installed the CD-ROM drive and are unable to open the drive, attempt to temporarily disconnect the IDE cable to verify that you not experiencing an issue with an incompatibility between the CD-ROM and motherboard. Once the IDE cable has been disconnected, power on the computer and see if the CD-ROM drive tray is now able to be opened. If the drive is able to be opened with the IDE / ATAPI cable disconnected, it is recommended you use the interface card supplied with the CD-ROM drive or the ATAPI interface on the sound card / motherboard. Bad drive
Unfortunately, if after following the above recommendations you are still unable to properly open the CD-ROM drive using the button on the front of the CD-ROM drive, it is likely defective and should be replaced. Caution: If you are able to open the CD-ROM drive using a paper clip. We do not recommend that you continue using the CD-ROM drive by manually ejecting the CD-ROM using a paper clip. The drive should be replaced and this is not meant to be used as a temporary solution. Additional information and tips for buying a new CD-ROM drive can be found on our CD-ROM buying tips section.
Jul 02, 2009 | Computers & Internet
My burners do not show up as installed on my computer they just disappeared
Does your CD burner eject or does its light indicator come up? I just want to check to make sure there's power getting into the CD burner. And if it does:
1. Right click on the My Computer icon on the desktop and select Manage
2. Click on Device Manager on the left pane.
3. On the right pane, select DVD/CD ROM drives to expand it.
Do you see your CD drive listed in there? If yes, right click and select uninstall. Then restart your computer. This will reinstall the driver that came with Windows.
If this does not work, you need to update the driver.
Apr 14, 2009 | Computers & Internet
Our hp pavilion 4535 will not read discs
I'm thinking of a couple of solutions:
  1. Auto run as turned off, navigate to your drives (usually in the My Computer icon) and check for your disc drive (usually Drive D:). If it is showing a disc then you can right-click and open to see the contents or double click for an auto-play.
  2. If you open up the drives and don't see a CD ROM drive then it might have gotten dropped some how. In this case you will want to go to the device manager and check to see if the CD ROM drive is listed and if it needs some fixing.
Mar 13, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Cd stuck inside laptop
turn off the laptop and turn it on again as soon as you see the windows startup push eject button see if it open if not then the CD rom is jammed inside
Sep 16, 2008 | Computers & Internet
My Kodak Picture CD will not auto load
If your computer is operating with WINDOWS 95, WINDOWS 98, or WINDOWS NT 4.0 Systems, this CD contains software that automatically launches when you insert the CD. Getting Started:
Insert your Picture CD disc and wait for the software to load (it could take as long as 5 minutes, depending on your machine configuration, CD drive speed, and the number of images on the Picture CD).
Note: This loading process installs some Picture CD program files onto your hard drive. The KODAK Picture CD installer walks you through the steps. The final step may be to restart your computer. If so, be sure to restart to complete the installation.
After your computer has rebooted:
  1. Eject the Picture CD and re-insert it into the CD drive.
    The program should launch automatically.
  2. Click the magazine cover to turn to the Contents Page.
  3. Follow the links to read and do more with your digital photos.
If nothing happens after waiting for the Auto Play, you may need to manually start the Auto Play program. (Auto Play is a program that starts up the CD installation process the first time you use the CD.)
To manually start Auto Play:
  1. Right-click the My Computer icon.
  2. Select Properties from the pop-up menu.
  3. Click the Device Manager tab.
  4. Click the CD-ROM drive icon; click the "+" to view the CD-ROM drive information.
  5. Double-click the CD-ROM driver icon.
  6. Select Properties from the pop-up menu.
  7. Click Settings.
  8. Check Auto insert notification and click OK.
Note: This enables all CDs to automatically run any Auto Play software.
Sep 12, 2008 | Cameras
CD driver stuck
In the front side of the dvd drive you will see a small hole ...so to eject that cd put one niddle in that hole and .
Now press the button at just after that apply a force on niddle .suddenly you will notice that cd will come outside ,if not try more times and you will learn to eject the cd when you are unable to do it by pressing the eject button...
Low feed backs hurt my ratings and I am tring to help you with your problem,so let me know that the information i given you is helpfull or not.
Thanks
Dilip Bagdi
Technical Associate
Dec 06, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
263 people viewed this question
David Payne
David Payne
