Question about Video Game Consoles & Games
I took my ps3 to my brothers house and he set my ps3 up to run on a higher HD setting than my tv will allow and now it wont work on my tv anymore. just blue screen. how do i fix this without going back to his house and resetting it? thx
    Problem Solver:
  • 14 Answers
Did u try to hook it up to ur computer and maybe it will let u use some options to switch it back to how u want it
Posted on Nov 29, 2008
I took my ps3 to my cousins house who has an HD tv with a HD wire. But once I took it back to my regular tv it didn't work. The screen was black. Please help me.
I had this same problem myself, and it's simple to fix. First, make sure to power off your OS3. The only light should be the red "Standby Mode" light. Now, press and hold the power button until you hear a beep, and the wait a moment. The console should start outputting to your TV again.
The problem your having is the video settings. Once the PS3 was set to output to HDMI, that's all it's outputting to. It can't tell when there is an RCA connection (those red white and yellow connectors), only when there is a new HDMI. Next time you go to your friends, just make sure to into the settings and choose the RCA video output before you disconnect from his TV and go home, then you shouldn't have any problems.
Here are the Sony instructions for this process.
Dec 14, 2010 | Sony Playstation 3 (PS3) Console
My ps3 was working fine four days ago. I took it to my brother-in-laws two nights ago and hooked it up. We played it on his tv with an xbox hdmi cord and it was fine. I took it home and plugged it up to...
Ok you must be using a a/v cable at your house? And the hdmi cable at your brother in laws? If this is the problem its not the xbox hdmi cable. It doesnt matter all hdmi cables work the same. Its your settings. You need to hold you power button down and it should come on and beep twice then release it and a settings menu should pop up if it doesnt hold the power button down until it comes on and shuts off then hold the power button down again until it beeps twice. Hope this helps.
Nov 29, 2010 | Sony Playstation 3 (PS3) Console
Was on hd and wont go back to analog
Go to display settings and you must change the video output manually to 480 or less.
Nov 16, 2009 | Sony Playstation 3 (PS3) Console
Unable to use PS3 on HD channel
1. Connect PS3 to your TV
2. Select the Correct HDMI input on your TV
3. Press and hold the [power] button on the PS3
4. perform setup.
These are the steps to setup the video output for the PS3, It is possible that it is set to a resolution that your TV does not support.
If this doesn't work, you may want to contact Sanyo to ask if they have some protection circuit for the HDMI input. Some manufactures TV's will deactivate(turn OFF) the HDMI input under certain conditions. Unplugging the TV or some other procedure usually turns it back ON.
Apr 29, 2009 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Ps3 doesn't work propley with samsung hd tv
keep ypur finger on the off button for 20sec
Jan 11, 2009 | Sony Playstation 3 (PS3) Console
Played ps3 on my brothers hd tv
do u have hd?
if not u need to change ur settings to video instead of hd! but when i had to i needed it hooked up to hd first then went through settings to change it or it will be blank screen!
Dec 26, 2008 | Sony Playstation 3 (PS3) Console
PS3 Scart / HD
Turn it off with the "hard" switch in the back. Then turn it back on with the switch while pressing the power button on the front for 10 secs, this should reset your display settings.
Sep 07, 2008 | Sony Playstation 3 (PS3) Console
Ps3 wont show or load games
If you originally set up the PS3 with A,V cables it won't work on HDMI even if you set it up to and visa versa. There is a work around but you will have to call tech support. Here is a link at Sony's PS3 tech support that may help also. http://playstation.custhelp.com/cgi-bin/playstation.cfg/php/enduser/std_adp.php?p_faqid=263
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
PS3 - HDMI to SD change issues
While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.Good Luck!
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
23 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
