Question about GE 30 in. JGP336 Gas Cooktop
How do I open the unit?
My GE cooktop (mod # JGP963SEF1SS) has not worked since we cleaned it with a sponge. Something shorted out and keeps blowing the fuse at the panel everytime I plug it in. I need to open the unit to check wiring and components. There aren't a lot of screws and those I've removed don't seem to help. Any suggestions?
  • 1,543 Answers
Disconnect power before dissassembly. I believe on your model you will have to remove the burner caps and burner heads, then the screws you find under them. (either small phillips, or more likely small torx) You can disconnect spark ignitors then if you like. You may then just have to dry things out, most likely at the burner ignition switches on the burner valve stems.
Posted on Nov 29, 2008
Igniters on my Bosch gas cooktop not working. I guess it needs cleaning. How do I do it?
You can try to clean the two pins with degreaser and then soap and water using a skrubby sponge for delicate surfaces However, my Bosch cooktop has had problems with the igniters (particularly on two burners) which required the replacement of the control unit. This requires opening the unit completely and replacing the white plastic box and connections to each burner. It is easy enough to do, but it is a bit scary to lift off the glass as there is probably an adhesive which one has to lift the top off of. Another thing you can try is to adjust the two screws that are uderneath the removable cover of the burner. Sometimes just tightening or loosening them a bit can solve the problem
Dec 08, 2016 | Bosch Cooktops
Why does the f1 code appear when cleaning my oven
Its an error must be the blower motor..one blower will blow air to cool tge chamber. try to open the unit & look inside
Sep 20, 2014 | General Electric Ge Stove / Oven / Range...
How do I replace spark ignitor on GE JGP963SEF1SS gas cooktop?
If none of your burners are igniting, you need a new Spark Module. If only 1 or 2 of your burners are not igniting, you may need a Spark Igniter. Click on the pictures below for a larger image.
The Spark Module is number 318 in the following diagram (underneath the burners):
The Spark Igniter is number 154 in the following diagram:
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jun 02, 2011 | GE Cooktops
Cooktop keeps blowing fuses. when we hit the
you will have to remove top and find short . it sounds like a burner of melted wiring. .. also ck the swithces for dark connections as the could be the cause. mm
Jun 30, 2010 | Maytag MEC5430 Electric Cooktop
30 in. JGP336 Gas Cooktop: We have a GE model # JGP933SEK2SS gas cooktop. ...
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
May 18, 2010 | GE 30 in. JGP336 Gas Cooktop
Cleaned gas cooktop and spark ignitor started sparking on its own
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Apr 07, 2010 | Whirlpool SCS3014LS Gas Cooktop
No power to cooktop and breaker isnt tripped
maybe reason breaker kept blowing was a faulty cooktop
Nov 07, 2017 | GE 30 in. JP340 Electric Cooktop
I have a similar problem with my GE Profile stove
one of the ignitor switches is shorted out.sometimes it is moisture inside and it happens after boilover or spraying some liquid for cleaning.remove the knobs and try a hair dryer to dry them or leave the unit unplugged for some days.it should work fine after this ,if not then the bad switch needs to be replaced.always avoid boilovers and spraying any cleaning liquid for cleaning.
Aug 16, 2009 | GE 30 in. Profile JGP989 Gas Cooktop
Starter keep trying to start when cook top is off.
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
Nov 14, 2007 | GE 30 in. JGP337 Gas Cooktop
GE 30 in. JGP336 Gas Cooktop Logo
285 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Dave Harrison
80stech
Are you a GE Cooktop Expert? Answer questions, earn points and help others
