Question about Samsung TXM3096WHF 30" TV
Video warps on edges then cuts out to black, then fades back in
Hello experts! Well, my Samsung TXM3096WHF 30" TV has been exhibiting some odd behavior for the last 3 days or so. The video will kind of "warp" or wiggle on the edges of the pic, then it will cut out to either full black, or just darken then head to the center of the screen, sometimes looking like a double image. It will then recover anywhere from 2-10 seconds later & pop back into a normal pic. Note: it almost makes the same sound as when the TV goes off & comes on...kind of a "static" pop as the pic goes out and comes in. This behavior happens about every 30 seconds - 5 minutes or so. Audio is still fine & playback on Tivo or normal TV is fine.
Here's what I've done: I've checked the cable connection to the back - it's tight. I've checked the cable connection from the TV to the Tivo box - tight. I've checked the other end of the cable connection to the router - tight.
It should be noted that I've never had any "tuneup" done on this TV and it's about 5.5 years old.
While typing this note, the video has popped out about 5 times. :(
Thanks SO much for any assistance!
Lisa T (frustrated TV viewer)
    Sergeant:
    Champion:
  • 283 Answers
Please dont rate me if could not fix your problem. Check the tv lamp. If doest work well, replace it. Thank you..
Posted on Nov 29, 2008
STRANGE PICTURE ,TVS PICTURE PULLED IN FROM TOP AND BOTTOM AND BOTH SIDES ,,PICTURE LOOKS LIKE BUTTERFLY IN CENTER OF SCREEN ,,
I would say you have a power supply or deflection system defect. This would need a technician to diagnose the problem as it will require some tests to determine where the problem is originating. For example, a main power supply defect could cause reduced supply voltage which would affect both vertical and horizontal deflection.
Nov 25, 2009 | Samsung TXM3096WHF 30" TV
It just stopped turning on
how long have you had this set. it sounds like you are having a power board problem most likely the board is dead you will have to take it to your local tv repair shop or if you are good at stuff like that you could open it up and see if their is any blown caps or burnt spots on the board
Aug 07, 2009 | Samsung TXM3096WHF 30" TV
2 faded areas on print out
If your printer looks like this:
Then you need to clean the developer blades. In the image above it is the black blade that need to be cleaned. If there are streaking on any other color, then then also needs to be cleaned.
To clean the developer blades, look to this link. http://losingambition.com/clp300imagefix/ It describes how to clean them. It only takes a few minutes to do once you get the developers out of the unit. Just be careful when you clean the edge of the blades. You need to make sure that the residue is completely removed from the edge. Also be sure that when you reinstall the blade that the little foam does not get trapped below the blade.Otherwise when you print the side where the blade is not properly installed will have too much color.
If you are afraid of messing your printer up, then you need to buy a new imaging unit. They go around $100.
Feb 20, 2009 | Samsung CLP 300 Laser Printer
Cuts off
Hi, tough question, could be lamp, lamp circuit is overheating,t-con module or you have a bad color wheel, the latter usually causes a hi pitched squeal periodically, you have 2 choices, 1. try replacing the lamp 2. call a tech and let them diagnose it, too many possibilities without doing some diagnostics, video-tek
Feb 03, 2009 | Samsung HL-67A510 67" DLP HDTV
My tv shows are taping in black and white
if you have the dvd's s-video plugged in and also something plugged into the yellow video input this will happen , does the piture on the tv show black and white?
otherwise the vcr head is dirty and needs to be cleaned
please rate a fixya and I'll be happy to even assist you further
electech
Nov 07, 2008 | Samsung DVD-V2000 DVD Player/VCR
Purple glow
yeah your tv got magnetized this unit needs to be desmagnetized there is a device we tech have wich is a wheel that can do that
May 10, 2008 | Samsung TXM3096WHF 30" TV
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Tv just shut off, now now power will not turn on at tv or remote
I have the same problem with my Panasonic Tau 32" HDTV (tube). It's well out of warranty, so I might "explore" and see if I can find a burned fuse or other component.
Jan 05, 2008 | Samsung TXM3096WHF 30" TV
Samsung slimfit television 30"
In this model the horizontal drive coil vibrates and makes a high pitch squeal. Most times it is intermitent. Touching on the coil with something (non electrical, like wood) will make it stop or change it's pitch. The fix my shop uses: It's not to technical, but, we put fingernail polish around the coil. It's a remedy I've used for decades and has always worked. Some shops use a hot glue gun. With the back open you can hear the coil to locate it. When fixing the problem have the set unplugged. When a technician is working on a television while it's plugged in. He uses only one hand and stays away from the high voltage.
Aug 11, 2007 | Samsung TXM3096WHF 30" TV
Samsung TXM3096WHF 30" TV Logo
80 people viewed this question
Jerry Greenberg
Jerry Greenberg
