Question about Milwaukee Tool Milwaukee 10 Amp Recprocating Saw Sawzall Plus with Quik - Lok Cord
Cannot get blade to release from Sawzall Quik-Loc.
  • ablewasi Feb 05, 2009
    I have the same quic-lock blade holder mechanism. The collar turns, but the blade is not being released. Have tried muscleing the blade out and using wd-40, etc., but still not releasing. Is there a means to take apart the collar assembly?
  • 2,176 Answers
Will the collar on the Quik Lok Turn and if so how much? What you can do is spray some WD-40 on the mechanism to free up the collar, sometimes it gets gummed up from cutting. It should open and close with a snap, hope this helps
Posted on Dec 09, 2008
Saw blade jammed - cannot remove
Unplug from power. Spray blade locking mechanism with wd40 or similar lube. 1. If you have a quik release, work the release with a pair of channel locks while wriggling the blade. If not removed, you can remove the footplate from the saw and drive the pin out that holds the quik release in place, paying attention to how the parts reassemble. 2. If you have a set screw retainer, totally remove the retainer.
Sep 08, 2012 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee sawzall blade
Cut or snap the blade off at the end so you can get the holder apart. I have had to do this before. Usually you can just use a set of pliers and work the blade back and forth until it snaps off but I just use an air powered cut-off tool and cut them.
Aug 05, 2012 | Milwaukee tools Milwaukee 6509-22...
Milwakkee cordless lithium sawzall clicks but blade wont move
you have a gear problem, if this is a newer sawzall I would take it back for warranty repair. If you need a breakdown you can go to milwaukeetool.com and download one. They have a good warranty
Jan 27, 2012 | Milwaukee Tool Milwaukee 10 Amp...
Motor on my sawzall 6572 runs but blade does not move. Blade locked in tight. No reciprocating motion.
The gears are stripped internally in the saw...it will need to be repaired..
heatman101
Jul 27, 2010 | Milwaukee Tool Milwaukee 10 Amp...
Cannot get the blade out of the porter cable reciprocating saw
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
May 27, 2010 | Porter Cable Variable Speed Quik Change...
Missing the blade holder thingy for sawzall cat # 6527. Thanks, Mike
Mike, is this the quik lok blade assembly and if so the part number is 14-46-1011 and if not you would need to go to Milwaukeetool.com and type in your model number but you would also need to have the serial number handy for the different versions and parts for these tools. If you want to forward it to me I will come up with a part number for you.
Oct 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
I have a Milwaukee sawzall 6509-22 with a quick loc cam. Blade went in fine, but now the saw wont release the blade to come out. How do I fix this problem. Note: locking cam is turning fine
K you used the saw after inserting blade?? If so couple ideas, hold collar open and put saw blade in a vise and try pulling back on saw, or you can remove the quik lok cam and release it that way, its not that hard, but I would try vise first. Let me know
Jul 29, 2009 | Milwaukee Tool 10 Amp Sawzall Plus with...
Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Jan 21, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee Sawzall problem
ive had it happen to many of mine also. it happens what i do is blow it out with an air compressor or a can of dust off while opening it and shutting the lock. then pour some liquid wrench into the lock. and work it in by opening and shutting it a few times. that should help. this is a common prblm with many different brands of sawzalls.
Oct 28, 2008 | Saws
Milwaukee Tool Milwaukee 10 Amp Recprocating Saw Sawzall Plus with Quik - Lok Cord Logo
277 people viewed this question
Top Milwaukee Tool Saws Experts
Jim Thurston
Craig Butler
Craig Butler
JOHN LAPIER
Are you a Milwaukee Tool Saw Expert? Answer questions, earn points and help others
