Question about GE JVM1190 Microwave Oven
Display panel reads "RESET" and keypad doesn't work
My GE Spacemaker JVM240 was in storage for over a year. I plugged it in and turned it on to try it and it seemed to work. I unplugged it, moved it and replugged it and now it doesn't work. The light comes on when the door is open. The display panel lights up when it's first plugged in, but the keypad doesn't work. After about 10 seconds, the display panel says "RESET". And that's it. The keypad does nothing. Any thoughts?
  • GE Master
  • 9,156 Answers
I believe I answered this, so pardon me if this is a dupe. It sounds like a problem on the control board. If it was stored in an unheated garage, shed, or other building, it could have some condensation deposits which could cuase corrosion on the circuit board. We repair these control panel assemblies nationwide for $32.50 and you can find out more through my listing here on FixYa: http://tinyurl.com/yzjozk If you have not tested and cleaned the keypad strip where it goes into the board, post back or e-mail me and I can give you instructions on that.
Posted on Jan 21, 2007
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker xl1800 ge profile problem
try to reset the settings and also the unit.. if you have an easy access to clean the keypad contact it is better to clean the surface..
Sep 23, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Have a GE Hood micro model # JVM1540DN1WW. Control panel doesn't work. Did hard reset buy cutting power. Probably bad smart board. Problem is this is the 2nd one I have had . These last only 2...
You have a failed membrane keypad.
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
It is part number WB56X10824 and you can order it here for $124.12.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site ,we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame. Be careful - the display is made of glass.
Some connectors on the relays may have a lock:
May 24, 2011 | GE Spacemaker JVM1540 Microwave Oven
GE Spacemaker Microwave, Model #JVM1540SN1SS, buttons don't work
The membrane keypad has failed.
The keypad itself is not available as a separate part, so the control panel frame with keypad would have to be replaced.
This is actually a pretty simple DIY job.
You can part number WB56X10826 from the Pros here for $114.62 plus shipping (that compares to $166.50 from GE!).
You can also find helpful exploded view diagrams at that link.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then disconnect your keypad strip as shown in the photo below, then remove the screws that hold your circuit board in the old frame.
Then carefully (since the display is made of glass) move your circuit board to the new frame, and reassembly is the reverse of disassembly.
May 27, 2010 | GE Microwave Ovens
GE Spacemaker Microwave powers off after few seconds of working
Hello :
This could happen because of a bad keypad . Just replace it and problem will be solved . I need you to think before replacing it . Because sometimes a new unit is better than repairing . Think it before !
good luck .
please rate !
Apr 01, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
Jan 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Microwave Spacemaker oven, Model JVM240
That would almost certainly be a problem on the control circuit board. If the bulbs happen to short / blow out or if they are removed or installed while the microwave is still plugged in, there is often an arc which causes damage to the board. We repair regularly these boards for such problems for $32.50 nationwide.
Dec 23, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave malfunction
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
May 29, 2006 | GE JVM1861SF Microwave Oven
GE JVM1190 Microwave Oven Logo
200 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
