Question about LG Flatron L1715S 17" LCD Monitor
When the PC starts the monitor does not come out of the power standby mode
Hi, The problem is that when i switch off my PC, whether i choose to switch my monitor off or leave it go on power save mode doesnt make a difference. The next time when i start the PC, the monitor light turns to green for a quick second (implying it received a signal from the PC) but then goes back into the standby / power save mode whilst the PC continues to boot up. The only way to resolve this is to switch the PC off and try and switch the monitor off and on and simultaneously switching the PC on. I am running windows XP service pack 2 and have a LG L1715S 17" monitor. I have also recently upgraded the Nvidia graphics card drivers that i have on the PC to the latest ones available on the website. I have also ensured the power options within windows are set never to turn anything off i.e. Monitor or PC. Short of replacing the monitor cable i have tried everything else. (although dont see why the cable would be bad as mentioned above when i switch the PC on the monitor light changes colour to green for a brief second implying some input received from the PC). Any help at all is much appreciated.
  • jay desai Jan 17, 2007
    Apologies as the above description is not completely accurate once i checked the problem out again.
    Once the monitor is on standby and i power my PC, the monitor does not come out of the sleep mode and become active. i have swapped the monitor connecting cable and swapped the power cables and the same problem still occurs.
    any thoughts anyone?
Hi The problem is to do with a 680uf capacitor that tends to bulge and fails.this stops the monitor staying on when trigerd to do so,change this and happy day.
Posted on Apr 07, 2008
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
These messages appear during if the video cable becomes disconnected or
damaged.(most likely you will need to replace it)
Turn off your monitor and reconnect the video cable; then turn on both your computer and the
monitor.
If your monitor screen remains blank after using the previous procedure, check your video
controller and computer system; your monitor is functioning properly
Posted on Nov 15, 2007
Sorry it is a known issue, common to all LCD monitors :( Long story short: Sometimes they do this (it has to do with the soldering metal) it is very easy to repair so if it is in warranty you can contact Lg and if not a repair will not be too expensive ( they just need to apply some soldering metal in the weak spots)
Posted on Jul 27, 2007
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
When we switch on the screen it goes to stand by mode
Kindly let me know whether your monitor or cpu goes on standby mode. Kindly let me know whether you are using lcd or crt monitor and which operating system you are using.
Oct 03, 2010 | Computers & Internet
Monitor stuck in standby
Try tapping F8 when booting and then choose 'safe mode with networking'
if this works go to the lcd manufactures web site and look for a specific driver for your screen.
Aug 30, 2009 | Dell E551 15" CRT Monitor
Monitor will not turn on including power switch
I suspect the power supply for the monitor. Try a power supply from a working monitor. If you have a used computer store nearby, take your power supply to them and try it on another monitor.
There is no need to turn off a monitor using its power switch. Monitors automatically go into standby mode when they are not receiving a signal. In standby mode they use less than one cent of electricity per day. If saving electricity is your goal, raise the temperature in your home by a degree and run the air conditioning less.
May 17, 2009 | Dell Computers & Internet
My monitor gets switched off when i connect to cpu,the moment i disconnect it from cpu,its switches on automatically.what may be the problem?
One of two things:
1.) Your video card is 'stuck' in standby mode, which in turn sends a signal putting the monitor in low power 'standby' mode as well. When you disconnect it, the monitor returns to normal 'on' mode. Rebooting the PC should correct this issue.
2.) Your resolution or refresh rate are set outside the range supported by the monitor. When you connect the monitor, it starts receiving a signal that it can't display, so it simply turns off. You'll need to reboot the PC and press F8 quickly to bot into safe mode and correct the monitor settings.
Feb 12, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor blinks
your monitor haveing power supply problume it is not swtiching properly
ashok
Jan 21, 2008 | HP Compaq FP5315 15" LCD Monitor
Is this a Software/Config/Hardware Problem ?
Apparently someone must have went into your properties, By right clicking anywhere on the desktop, Choose properties and then screen saver and then power options, Once there look into the setting for hibernation,standby,sleep make sure that they are set so not shut monitor off after so many minutes. What I am thinking is when you quit using your mouse for any amount of time it turns the monitor off. I hope that gets you going, If not you can Write back here and ask me again we can look for another solution. Thanks
Jan 17, 2008 | Dell OptiPlex GX270 PC Desktop
LG Flatron L1715S 17" LCD Monitor Logo
343 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
