Question about Kitchen Ranges
Elements on while controls are off - Kitchen Ranges
  • 121 Answers
Replace burner switch
Posted on Nov 29, 2008
Heating elements dont heat up. heating elements not working
Control the thermal switches first they have priority where it goes wrong and the cable shoes on it second the controller clock there are some heaters with nickel-chrome woven filament elements that also can have similar problems also a broken filament but mostly only a problem with the connecting wires cable shoes.
Jul 25, 2017 | Dryers
J have a moyer diebel 500 HT i need a picture of the tank were the heater elements go ..i had a repair guy com in to wire the heaters up because they shorted out and he wired them wrong if you can help me...
Hello there
The 500HT machine is very old one. Turn off the power first. To get to the elements you have to get the control box off first so you can get to take off the elements cover , now you can see the elements.
If the system have been wired wrong and short circuit it. the temperature control may have to be change too. I would change the two elements and the temperature control and the hi ltd control all together at the same time so you know that system have no problem anymore. All the best Dickson
May 02, 2011 | Moyer Diebel 24 in. 501HT Built-in...
Stovetop heating elements turn off and on intermittently. They don't stay on.
The heating elements on an electric stovetop are controlled be a control called a reohstat. The reohstat regulates the temperature to the elements and as such they do cycle on and off during use. If you turned the control to low and the element stayed on all the time it would get too hot and burn what you're cooking.
Feb 06, 2011 | Kitchen Ranges
Both the bake and broil oven elements do not heat up / they are unresponsive. I can set the oven temp but on the control panel and it appears that everything is OK there I've replaced both elements and...
Must check the the voltage of 240 coming in to the oven sometime there is 120 volts which will light up the control panel but not enough to turn on the heat elements also check the wiring diagram some times there are cut off switches between the control panel and heat elements those can be bad too!
Appliancetek
www.astrepairs.com
Jan 14, 2011 | Ovens
Westinghouse freestyle 521 stove ceramic top.elements wont turn down no matter where switch is. burns food. Have used different size pans etc,
there is a problem with either the elements or the controls,i doubt it is the elements as its unlikely that all of them are faulty at once.the control knobs or control panel is more likely the problem.
May 29, 2010 | Cooktops
Elements and light in stove work but clock and stove do
The issue would have to be in the clock or the power wire going to the clock.
The clock controls the power to the oven elements and there are no fuses or other devices to control the elements.
May 20, 2010 | Maytag PER5710 Performa Electric Kitchen...
Ge double oven, no heating
check that u have continuity through the elements if you dont then replace the element next if you do have continuity through both elements check to make sure you have power coming from the main control to the element if you dont have any power leaving the control board then replace the control
May 18, 2010 | GE Profile JTP56 Electric Double Oven
Two elements not working
First of all, are you sure it is the elements and not the controler? To test the elements, lift theplate out of the worktop, change the 2 wires from a good element to that element. put the plate back in it is home and use the good elements touchtronic button to turn on the element. I am willing to wager that it is the control unit and not the elements.
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
Nov 12, 2007 | Kitchen Ranges
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
