Question about Jensen VM9410 Car DVD Player
Wont load or eject
I hooked up my head unit last night, and pretty much everything works, but the head unit will not load or eject CD's and obviously DVD's. Is there a wire that I possibly didn't hook up that would power a motor? Any help would be appreciated. Thanks
I have the same problem! tuner works just fine. I cant access the dvd mode. i can only access tuner, video input, and rear cam. Ive tried different cds and dvds and it did not help. Also it seems like the ejection mechenism is running continuesly.
Posted on Dec 27, 2007
Is the unit New or used? And I take it that the tuner works and plays radio stations...how about the monitor will it come out and retrack? If there is power to the unit it could be a defect with the cd/dvd.
Posted on Feb 03, 2007
SOURCE:
Dodge stratus cd player button doesnt work
Pull the player out and have it repaired.
Jan 19, 2018 | 2002 Dodge Stratus
My Dual XDM7615, will not even shut off and no buttons will work at all, it wont open or change stations and only plays radio on a station that sounds like AM,remote controll has new battery and wont even...
unplug the reciver from the back of it and wait for 20 sec. and plug it back in, this should allow you to eject. now turn off your car and jush eject, when it opens to eject's push the release button on the back of the face like your removing it but instead force the face to completely go down, as far as it will go. now turn your car on and put a cd in and see if that works for ya.
Jan 24, 2010 | Dual Car Audio & Video
The cd will not eject from the unit
you need to call radio shack or a stereo place to see if they can help if you take the loader out and bring in.
Jan 01, 2010 | 2005 Mercury Mariner
Wont turn on
  1. go over all the wiring and make sure nothing came loose.
  2. find the reset button usually behind the face. reset the radio.
  3. make sure the face plate is completely on the head unit.
Dec 23, 2009 | JVC KD-R200 Car CD/ MP3 Player
Radio wiring hook up
SOUNDS LIKE THE EJECT BUTTON IS STUCK ON, TRY TAPPING ON THE EJECT BUTTON OR RECHECK THE WIRING TO MAKE SURE THAT YOU HAVE ALL THE WIRES IN THE CORRECT SPOTS. ALSO CHECK TO SEE THAT THE GROUND WIRE ON THE BACK IS CONNECTED AS WELL. HOPE THIS HELPS. LET ME KNOW. GOOD LUCK
May 02, 2009 | 1989 Honda Civic
2003 infiniti g35 cd player
its a very common problem with g35 in dash clarion cd changer head units. a small plastic gear gets worn or brakes and wont eject or change cds. you need a new one, should be covered under your warranty.
and to get your cds out try this.
Feb 03, 2009 | 2004 Infiniti G35 Sport Coupe
My stereo wont play a cd at all i have done everything thats said in the manual but dont know what else to do? the cd will load in normally and eject normally but just wont run any ideas?
ok make sure the cd is not scratched and the head unit is cleaned and also make sure the cd player unit is grounded good and make sure none of the fuses in the red wire (12v) are not blown or busted
Nov 07, 2008 | JVC Car Audio & Video
HHB CDR-850 Professional loading problem
I had the same problem with mine. The manual says to unplug it from the power and plug back in. That did'nt seem to correct anything. I also was having an issue with recording. It would'nt record data for tracks and recording would scramble. I had this burner for 10 years and loved it untill last night when it crapped out on me completely. I am VERY disappointed!
Mar 30, 2008 | HHB CDR850 CD Recorder
The aux input will not work
you must go back into the menu and turn on aux otherwise the head unit will not recognise the aux devise that you are trying to plug in
Mar 25, 2008 | Kenwood KDC-MP3035 CD Player
Clarion Problems
take the deck back to where u boiught it from its faulty
Nov 04, 2007 | Clarion DXZ475MP CD Player
Jensen VM9410 Car DVD Player Logo
508 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
