I have a Samsung HT-z510 home audio and the wireless receiver for the back speakers stays in standby mode. I have set the mode to cinema but it still stays in standby. What can I check next?
  • Anonymous Dec 20, 2008
    I have the same problem. I was told to:
    On Dec 19, 2008, at 5:58 PM, Samsung Tech Support wrote:
    Okay, you need to reset the wireless module by following the instructions below to fix the issue.
    1) Make sure you have the Rear speakers plugged into the SWA3000, Front speakers plugged into the HTS base and the TX card plugged into the HTS base.
    2) Turn off HTS base and Turn on wireless receiver
    3) Get remote control and a Pin in hand and stand next to the Wireless receiver
    4) Point remote control at HTS base and hold Remain until a blue/red light blinks on base
    5) Let go of remain and with a Pin - press RESET on wireless base 5 times, quickly.
    6) After the 5th time press power on remote control to turn on HTS base
    7) Repeat if process does not work, if it still doesn’t work then service is needed
Here is how I reset. Key terms to identify: Main unit, remote unit, transmission card, reset button on remote unit. 1. Unplug both units and remove transmission card from rear of Main unit. 2. Wait five minutes. Insert transmission card in rear of Main. 3. Turn on both units. If units do not communicate, there will be a solid red indicator on remote unit...In this case continue with 4. Use remote and turn off main. 5. Point remote at main and enter the following four digits, holding each down for about a second:  0   1   3   5 6. The main unit should turn on. 7. With remote unit on, press and hold down the reset button for 5 seconds.
Posted on Mar 01, 2009
  • esohr Mar 01, 2009
    Sorry, prior post in my name is confusing because of the formatting.
    In step 5...there are just four digits 0,1,3 and 5.
    Step 6 follows the 5 and is confusing.  Just "0"  "1"  "3"  "5"
What can I do to listen the TV set audio throut the Home Theater System HT-Z510, How shall I install de cables.
Posted on May 11, 2009
Code to change settings for Small loud speakers to large. Model No HT-F450K to HT-F455K models
Speaker size selection usually is part of receiver set up; the DVD player has nothing to do with it.
Jun 27, 2016 | Samsung HT-C650W DVD Home Theater System,...
Some of my speakers arn't playing sound on my HT-E555OW
If you are trying to play a cd, you must manually tell the unit to play it in surround sound. Cd audio defaults to stereo only. Does it do the same thing if you are playing a dvd? If it happens on dvd's as well, then something in the speaker setup menu is wrong.
Dec 25, 2012 | Shure Samsung Ht-E5550 3D Home Cinema...
How to I get my surround sound speakers to work with the cable box?
One way would be to connect one of the the digital audio outputs to the HT as an input (HDMI or optical digital audio).
Another would be to select one of the DSP modes that uses surround speakers. They work with all input modes.
http://downloadcenter.samsung.com/content/UM/200802/20080203110035031_HT-Z510-XAA-0125.pdf
Jan 28, 2011 | Samsung HT-TZ512T Theater System with...
Hi, Ive tried to set up my samsung blue ray
It seems as though the HT works fine, so to get the TV itself to play through the HT setup, take the audio out from the TV and hook it up to a separate channel on the HT receiver. Turn on TV and receiver and put the receiver on the respective channel of the receiver. I hope this helps.
Oct 26, 2009 | Samsung Audio Players & Recorders
My main unit will not connect to the rear unit
I had a similar problem but mine cut out intermittently.
First, check to make sure the speakers are plugged in solidly. I was plugged into an outlet with a fancy cover and it caused the connection to short out intermittently.
2. Make sure all your wires are securely attached to the receiver unit.
3. If that doesn't work, try turning off the wirless speakers and the Home Theater system and then turn on both of them.
If one of these doesn't work, Samsung has chat support available onlline.
Good Luck!
Mar 13, 2009 | Samsung HT-TZ512T Theater System with...
Home Cinema Samsung HT Z310R- Speakers not working with TV
You need just one cable that goes from your TV to your HT system.
On your TV you should see an RCA jack for "AUDIO OUT" and you need to plug that into your AUXILLARY "AUDIO IN" on your HT system
When you are watching TV and you want the sound to come through the HT system, just set the HT system to "AUX" mode. Most Samsung systems will have 3 'AUX' modes, set the remote on 'AUX 1' then wait a few seconds, if no sound comes through then set it on "AUX 2" wait a few seconds and if it doean't work try AUX 3.
Hope that helps.
Gary
Feb 11, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Installing Samsung HT-Z510 wireless speakers
I was able to solve the wireless speaker problem through unplugging all of the units and starting over. I need to have the signal go from the satelite box to the recioever then the TV in order to get home theater to work.
Jan 05, 2009 | Samsung HT-Z310T Theater System
Speakers won't connect
Here is a link to Samsung's HT-Z510 Home Theater rear speaker troubleshooting guide.
http://www.samsung.com/us/support/popup/howToGuidePopup.do?howto_guide_seq=629&type=hometheater&subtype=hometheatersystems
It has worked for me after a couple tries. Good Luck!
Dec 27, 2008 | Samsung SWA-4000
Wireless receiver module is not receiving
if its in standby how do u here anything change audio settinsg to cinma ok dsp mode
Jan 22, 2008 | Audio Players & Recorders
1,543 people viewed this question
 Grubhead
Grubhead
