Question about Epson Stylus C86 InkJet Printer
Epson C86 My printer says it is out of ink even though I just replaced all four inks. The level of ink on the black is full but the cyan, magenta and yellow still says empty. I cannot run a clean cycle at all, it will not print anything. What is the problem? How can I fix it other than purchasing all new inks again?
Throw it out...have had 3 epson's in our office in the last 5 years and ended up ditching all three...they are junk.
Posted on Jun 14, 2007
Hi, my epson stylus SX210 had ran out of magenta ink, can i still print if the black ink is still full in it?? Naoimh
These printer required replace cartrigde empty to continue printing
You must replace only the cartrigde empty
T0711 Black
T0712 CYAN
T0713 MAGENTA
T0714 YELLOW
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How many colours are available eg black, cyan etc
This printer has 4 colour cartridges, black, cyan, yellow and magenta.
It can generate a wide range of colours by mixing some or all of these inks to produce a colour photo images.
Feb 24, 2011 | Epson Stylus C86 InkJet Printer
I am out of magenta ink and the black still wont
Hiya,
Unfortunatly this is the curse of Epson and most modern printers, to be able to print you need the full colour set available.
Been through the same thing myself as well as with family and friends.
It's very frustrating.
Sorry I cant help further.
Mike
Sep 24, 2009 | Epson Stylus C86 InkJet Printer
Epson DX7450 compatible ink problems
Press and hold the data button
Sep 22, 2009 | Epson Printer
Type of catridge epson stylus R390 uses can't find
You can see the reference on the cartridge itself.
Take it with you when you buy new ones.
Jul 29, 2009 | Epson Stylus Photo R390 InkJet Printer
Error message after replacing black ink cartridge
This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
Epson Stylus C86 - prints faint magenta even though ink levels are in a normal printing range - does not print anything or a barely seen magenta line during nozzle check and heading cleaning
You probably have a slowly worsening clog building up in the Magenta nozzles. It's also possible that your ink is reaching its end of life which, given the age of the C86 is entirely possible, especially if you are refilling or using a CIS sytem with your printer.
If it's a clog issue you can try soaking the parking pad with a mildly ammoniated cleaning solution (original Ammonia windex is good for this) or even distilled water. Leaving this with the printhead parked above it allows the solution to wick up into the nozzles and break down any clogs in the printhead.
If the problem is ink age though you will probably want to carry out the solution above AND replace your ink with a fresh solution. A CIS will need a thorough flush to remove any algae and cloggation residues before you use it again or you will just reintroduce the problem.
Hope that helps.
Martin
May 27, 2009 | Epson Stylus C86 InkJet Printer
Colour Ink Jet Cartridges emptying during a black ink print run
If you go to your printer properties, there should be a setting whereby you have to select the option to "PRINT USING BLACK CARTRIDGE ONLY". Make sure this option is selected, otherwise your printer will use ALL colors even if you only print black.
Let me know if you need any further assistance.
Best wishes,
Graemevm
May 07, 2009 | Epson Stylus DX6050 All-In-One InkJet...
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Epson Stylus C86 InkJet Printer Logo
91 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
