Question about LG DLE5977 Electric Dryer
Help. My LG electric dryer, DLE5977 is not working
  • donna791 Dec 02, 2008
    My 5977 dryer stopped heating. It comes on and the drum turns, but it does not heat up. I contacted service for repair. The tech arrived, turned on the dryer, vertified it does comes on and reached over the dryer to the power cord, which was melted and discolored. He states I need to contact an electrician to have the electric repaired and he will order an elctricial cord. I contacted an electrician, his first question was...how many times did the curcit breaker trip. When I told him the breaker never blew, he stated it sounds like the dryer shorted out. All this from a 26 month old dryer. Is this a defective unit? LG states they are aware of an issue with mis-wiring by the techs on the power cords. Once I repair the electric, purchase a new cord, I will still need to solve the orginial problem of the dryer not heating. Please help!
Basic electronics tells us that if the cord was melted, the breaker is primarily responsible for keeping that from happening. It is extremely unlikely that the dryer caused this, although exposed wiring could have caused an arc that would have melted the chord, but then the breaker should also have tripped. You should definately have the breaker checked and or replaced first.
From there, if the breaker repeatedly trips, or the dryer won't heat, then the dryer is at fault.
Hope this helps.
Luke
Posted on Feb 20, 2009
  • 706 Answers
Hello berkyiu2002,
I'd be happy to assist you but an you elaborate on what happened? I can only assume you checked the basics...such as the circuit breaker has not tripped to the receptacle your dryer is plugged in to.. and the cord from the dryer is plugged in to that receptacle properly.. otherwise, please tell me what happened and when it last worked...
Regards,
Rick
Posted on Nov 29, 2008
My LG Front-load dryer is making a loud noise during the drying cycle. If i press on the lower left front panel - the noise is muffled quite a bit. Model # DLE5977
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
gfg
Sep 27, 2010 | LG DLE5977 Electric Dryer
My LG DLE5977 dryer won't heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 06, 2010 | LG DLE5977 Electric Dryer
My lg dle5977 electric dryer is not completely drying my clothes, what can i do about it?And also how do i take it apart?
If the dryer is heating the most likely problem will be clogged or restricted exhaust. Make sure you are getting good airflow to the outside of your home when the dryer is running. Also check to make sure the exhaust on the back is not closed off and especially make sure that it is not crimped.
Feb 21, 2010 | LG DLE5977 Electric Dryer
Dryer won't work say's clean filter but it is clean electric dryer lg model dle5977s
clean the filter and the front air duct assembly go to AppliancePartsPros.com and look at the diaphram.
Oct 10, 2009 | LG DLE5977 Electric Dryer
My LG DLE5977W electrical dryer won't heat
bad thermostats or heat element broken
Feb 24, 2009 | LG DLE5977 Electric Dryer
LG DLE5977 Electric Dryer Logo
234 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
