Question about Lexmark Office Equipment & Supplies
I have an X3470 Printer, I took out the ink cart. and put it back in and now the printer says Cover open and will not allow me to print. What do I do?
  • Lexmark Master
  • 4,338 Answers
Remove the ink cartridge.
Unplug the power cord from the electrical outlet.
Reconnect the powercord to the electrical outlet.
Power the unit on (if it is off)
Reinstall the ink cartridge.
close the cover and print.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Nov 29, 2008
Please help me find the spot to re place the ink cartige to an x 3470 printer
Perhaps the Lexmark X3400 Series User's Guide will give you a better picture. You can download it using this link: http://bit.ly/cSUqq8. Scroll to page 52 for the instructions on how to change the print cartridge.
Sometimes the ink cartridge carrier won't position automatically to the middle even when the printer is on and the cover is open. Just unplug the printer from the power source. With the cover open, hold the solid white strip and gently slide the carrier to the middle of the printer. Load the cartridges. Close the cover. Plug the printer back to power source. Thank you for choosing Lexmark.
Oct 15, 2010 | Lexmark X3470 All-In-One InkJet Printer
Ink cartridge put in backwards
try to clean the cart once again.. or else try out with another set of cart as well
Oct 21, 2009 | HP DeskJet 5740 InkJet Photo Printer
Says cover open but its not
Open the cover, remove the ink cartridges, reinstert them, close the cover, and power it back on.
Apr 21, 2009 | Lexmark X3470 All-In-One InkJet Printer
Installed a new ink cartridge and the display mentions cover open when it is closed.
never let a machine defeat you
there's a sensor in the printer that checks ink levels. the sensor uses a beam of light to check; if the light bounces back, the machine assumes there is ink in the cart and continues to operate. If the light is not bounced back, the machine assumes that the cart is empty and starts beeping or displaying an error message. on a refill the ink is not "packed in" like it is on a new factory one. so take black electrical tape and tape it around the spine and the outline of the cartridge to make it ALL BLACK with no transparencies, which causes the light to beam back (sensor then triggers error message)
tricking the machine into thinking the cartridge is full defeats it.
Apr 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Cover open is on display
put your finger on the second hole on the top from the right and press the switch (it's small, gotta try a little...), when the display changes, press copy and close the door... it just worked for me!!
good luck
Apr 02, 2009 | Lexmark X3470 All-In-One InkJet Printer
Printer Ink is Low
If had refilled the ink then this printer as in build sensor which works only once , that reasons your getting this message if your using original Lexmark cart then if your getting this message then you can contact lexmark get the cart replaced as the cart comes with 6 months warranty.
May 16, 2008 | Lexmark X3470 All-In-One InkJet Printer
Can't install new ink, can't do anything
open the cover of your printer and ink cartridge will move to the left therefore allow you to change your ink
Apr 16, 2008 | Brother MFC 3100C All-In-One InkJet...
YELLOW INK LOSE
Take all carts out. Have a close look into the cart holder. If you have lost ink it will be beneath the cart holder! That might be because the cart holder leaks. You need a new cart holder then. You have to open the printers top cover, carefully take the holder out, clean the bottom of printer and replace the holder with a new one.
This happens sometimes because the glue which fastens the foil (this is the bottom of the holder!) lost its adhesivness.
Feb 11, 2008 | Brother MFC-5440CN All-In-One InkJet...
Printer Door
I have that exact problem at work. There is a bump on the right side of the lid...and when you close the lid it presses on a lever. Check and see that the bump actually pushes that lever downwards. That's how the printer determines that it's closed.
Feb 03, 2008 | HP DeskJet 3650 InkJet Printer
Printer will not start after changing ink cart.
u better remove both catridges ,switch on the printer ,after that the print catridges lights will blink ,open the cover the catridge holder will come at the centre,put the catidges n perform the catridge alignement,n complete it
Dec 19, 2007 | HP Photosmart C3180 All-In-One InkJet...
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
