Question about GE GSL22JFPBS Side by Side Refrigerator
Fridge stops working for no reason
Hi, The fridge stops working and after a few hours when I unplug and replug it back in starts to work. The blower and the compressor start working. Looks like an overheating issue may be? The blower has a coil in front of it. Is this a temperature sensor? or is the compressor over heating?
Thanks
  • sahara_12002 Nov 29, 2008
    I have already done this. Thanks
  • 121 Answers
Sounds like the coils may need cleaned
Posted on Nov 29, 2008
I have a MFI2568AEW not cooling. A door was left open a few hours. After closing it stop cooling. I unplugged it for a few hours then replug NO COOLING! . I saw on utube on the same scenario and he said...
the ptc overload on the compressors bad,unplug the unit,remove the ptc off the side of the compressor and purchase a new replacement and it will again cool,this part is what starts and operates the compressor
Feb 16, 2012 | Maytag Refrigerators
When my refrigerator needed to be cleaned, underneath (I have cats and dogs) the refrigerator section would quit working and I would have to unplug and clean then replug and it would be fine until it...
check the start relay located on the compressor when this gets fur in it it tends to burn out much quicker then without pets. This is the plastic piece located on the compressor that turns the compressor on you would also need to pull the unit out and take off the back panel and clean around the compressor and start relay area this way as well if you have never done this there would be alot of build up if you have any further questions message me back and please remember to rank how this opinion has helepd it allows me to help others in similar situations p.s remove the start relay and shake it in your hand if you are hearing something jingling on the inside of the relay replace the relay Thanks Rick
Apr 04, 2011 | Whirlpool Refrigerators
My fridge stopped cooling and freezing 4 days ago.I hear fans inside running and it just blows slightly cool air against the ice maker.The compressor is HOT and the main fan for the condensor doesn't seem...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 12, 2010 | Frigidaire FRS26R4A Side by Side...
Freezer won't stay consistently cold
replace temp sensors in fridge and freezer (easier to do together) should work fine...
Feb 04, 2010 | Amana ARS266ZBS Side by Side Refrigerator
Fridge/freezer warm, water puddling underneath
Hi, clicking sound from compressor, means compressor not running (working) compressor overlay relay is what making that clicking sound, possible your compressor have a hard start, you can purchase compressor ( hard start kit ) from appliance store, your fans could be working, but compressor short cycling, you said fan not working? which one inside of ref, or one near to compressor, check fan, remove 2 wires from fan terminal, use ohm tester, place tester lead one on each fan terminal, if you get a beep sound (continuity) fan is o/k, if not, fan burnt out, replace fan, now if compressor is good, fans are good, then check or replace, defrost timer, but before doing any repairs, unplug ref, excessive water is because ref defrosting, because there's no refrigeration, remove your produce, leave ref. off for about an hour, then replug it, let it work for about another hour, then check to see if temp. dropping (colder) maybe you experiencing, low voltage, let me know what happened, then i can tell you exactly, what's the problem. good luck.
Aug 11, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
When plugged in, the compressor never kicks on. It just clicks.
If the compressor is getting hot then the compressor is gone. But the price on a relay is fairly cheap so you can at least try it and if it doesnt work then return it and dump the unit. But like I said before when a compressor gets hot it means that the piston is bad and the rings are burnt and the oil is bad in the compressor.
Feb 13, 2009 | Haier HBF05EBSS Commercial Beverage...
Quick Fix?
The compressor is locking up when it gets hot. We have seen alot of this on the units with Tecumseh compressors. If it is less than 5 yrs old it should still be covered by the sealed system warranty and repaired free of charge.
If it is out of any warranty, there are "fit-all" compressor starters with start capacitors built in them that give it a little extra boost on start-up. They are called 3-in-1 or kickstart starters. This will usually buy you a few months until you can replace fridge.
If it is covered by warranty but will take a few days to get repaired, you can get by ok by unplugging fridge at night and plugging back in in the morning. This is what I tell my customers when I have to order a compressor and so far they have been able to keep from losing food.
Nov 05, 2007 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
GE GSL22JFPBS Side by Side Refrigerator Logo
128 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
