posted by bugsplat on Jan 16, 2007
My Bosch Exxcel has a leak, allegedly between the motor and pump - but I can't get to it because the one-piece plastic base doesn't come off. The side panels and top come off easy enough but I have run out of screws to undo, the thing doesn't come apart. I'm reluctant to take off the spring loaded door, if I have to how do I tension the springs again ? Is there a clever way to pull it apart just enough to get at the motor and pump ?
Thanks
Solution #1
posted on Jan 30, 2007
It will come apart.Sometimes the whole front panelcomes off them with the door attached.
every thing is put together in a certain order.
You can get a front loader manual from your local libuary.Take your pump cover off and start looking for screws.
You must locate your water leak first.
If its a tub leak you will need to change a rubber seal.
Dont be fighten to ask for advice,go to your local Bosch parts shop and tell them your w/m has a leak in a certain place and you need a part and ask for advice.These people are the experts. PS I like the Bosch, Stick with it and keep it simp-le
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Bosch 24 in. SGS45E02 / SGS45E08
Email this problem
Email this problem
Can you Help with these Dishwashers problems?
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Dishwasher bosch exccel...
How can I set the auto timer on... Answer This...
Bosch Exxcel dishwasher...
Hi - a couple of days ago my... Answer This...
soap dispenser not opening
I have a bosch dishwasher... Answer This...
Bosch dishwasher
Bosch dishwasher
My Bosch dishwasher is not... Answer This...
standing water left in...
Hi, After some washes... Answer This...
Repair Service
Find Dishwasher Repairman Near You:
Find Parts
