Question about Zanussi Washing Machines
Door locks but washing cycle will not begin. The lights show that the door is locked and the cycle in process. But the drum does not fill with water, and there are no signs of life.
  • 121 Answers
What brand and model but check that the water is on
Posted on Nov 29, 2008
My maytag washer does not spin fast enough to get the water out of the clothes. Please advise
Randall, the high speed spin failure can be caused by a number of issues. I would suggest starting the machine without any clothes in it. Once it has filled, make sure the door lock light is on and that the door is, in fact, locked. If the light is not on, or if the door is not actually locked, either the door lock assembly or the control panel is at fault.
If the light is on and the door is locked, stop the wash cycle and start a drain and spin cycle to see if all of the water is pumped out of the drum. All water should be pumped out within 10-15 seconds. If excess water is in the drum, the high speed spin will not start.
Mar 06, 2015 | Maytag Washing Machines
Problem with AWO3561 wash machine red door light flashing
there is a valve for the door lock if this goes it thinks the door is open and shuts down thinking the door has been opened if the feed pipe become blocked the water pressure sends air pressure to the switch when water is added. spin/drain setting it don't use this sensor switch, but on filling up it will. its usual down to a blocked pipe , or a leak in the line. sometimes it can be the switch, the pipe is located at the bottom around 2 inches from the bottom and the feed wire goes to a sensor , take the pipe off and blow down it best to have some water in the bottom of the drum, so suck and blow on the pipe to loosen anything blocking the pipe. switch don't blow or suck on this as it can damage the sensor. if the sensor is at fault you can only replace it as the valve inside for the switch if you use anything it will pierce the valve , hope this helps you.
Jun 24, 2017 | Washing Machines
Whirlpool wfc7500vw when put into any cycle selection the door lock lights comes and stays on and the draining/unlock light flashes for a minute then the door unlocks once opened and closed the cycle...
When you first start a load, the machine does perform several self checks. One of them is the door lock test. It locks the door and checks a loop back signal from the lock. At this point, it usually tests the drain pump to make sure it cycles on and off. In my case, the Maytag unit we own actually unlocks the door and immediately locks it again right before the actual wash cycle begins. I suppose this is a double check because if the door indicates it is unlocked, the washer won't do anything (like fill up with water, or spin...anything that either floods the room and hurts somebody). The door switch should be the impetus to start the tests. If the switch is mounted to an adjustable bracket, or the bracket is loose, then maybe it is being pushed out of position when you close the door. The fact that you can open the door after it unlocks, re-close it and the machine works normally tells me there is adjustment that needs to be made. Either the the little lever or pin that actuates the switch is bent or broken, or the door needs to be adjusted on its hinges to get the pin aligned correctly. Hope this helps. Keep us posted.
Kindest regards, Carl
Aug 15, 2014 | Washing Machines
I dont have a stop buttom
You're start/pause button should pause the cycle, cancell should completely cancell. After pressing the Start/Pause within a cycle, the door lock may require time to unlock as indicated by the lock light on the panel.
Apr 11, 2014 | Frigidaire Affinity ATF7000E Front Load...
Machine will fill and wash , but will not fill and rinse
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Motor won't turn on Samsung VRT Plus WF433B*GJ**
When washing heavily soiled loads, do not overload your washer in order to assure good cleaning results.
To add a forgotten item:
1. Press the Power button.
2. Press the Start/Pause
3. Wait for the door lock light to go out (Immediately).
4. Add the item, close the door, and press the Start/Pause
The door safety state continues for 15 seconds and the cycle is restarted.
ensure thorough cleaning,
Try washing bedding, towels, undergarments,
contact using the ActivFresh
1. Load your washer.
2. Close the door.
Push the laundry into the drum completely to prevent the laundry from being caught in the door or
....... from falling out of the drum.
3. Press the Power button.
4. Add detergent and additives to the dispenser (page 20-21).
5. Select the appropriate cycle and options for the load (page 14-16).
6. Press the Start/Pause
7. The Wash Indicator light will illuminate.
8. The estimated cycle time will appear in the display.
The time may fluctuate to better indicate the time remaining in the cycle.
The actual time required for a cycle may differ from the estimated time in the display depending on the
water pressure, water temperature, detergent, and laundry.
9. Before your washer starts to fill, it will make a series of clicking noises to check the door lock and do a
quick drain.
When the cycle is complete, the door lock light will go out and "End" will appear in the display.
DO NOT attempt to open the door until the door lock light is off. To add a forgotten item, see
"Loading your washer" section (page 13).
When your washer is restarted after a pause, expect a delay of up to 15 seconds before the cycle
Pressing Power button cancels the cycle and stops your washer.
The pre wash, wash, rinse and spin indicator lights will illuminate during those portions of the cycle
Nov 28, 2013 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Nov 08, 2013 | Hoover Nextra 160 HNWF 3137 Front Load...
Kenmore elite he5t front loading washer door locks, unlocks, then locks again before beginning cycle
This is aself test procedure on the door locking mechanism . You will also hear a click, the drum will make a partial turn,and the door will unlock berore locking again. Once the door has locked a second time the washer will begin tumbling and adding water. The sensing process will continue until the correct amount of water is added to the load.
Feb 12, 2013 | Kenmore Elite HE5t Washer
Washing Machines Logo
50 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
