Question about Dell Wireless Keyboard Optical Mouse w0147
How do I open the receiver for my wireless mouse to replace batte
My Delld I.T.E. receiver needs batteries and I can't open it.  Serial Number is LZB41100087
  • JDTec
    JDTec May 11, 2010
    look on the back of the keyboard, type the model # you find here.
    President:
  • 8,637 Answers
The receiver is plugged into a USB port and doesn't use batteries. The keyboard and mouse use batteries and they need to be replaced ever so ofter. to do so, follow thes instructions.
Normal 0 Are your batteries in the Keyboard and mouse good?
Press the Receiver button (and the lights will start flashing, then if its the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect.
If the MOUSE isn't working, do the same except push the small RESET?CONNECT button on the back of the mouse to connect. Then they should work properly. Hope this helps. Bud
Posted on Jan 17, 2009
My wireless mouse has quit working. I'm guessing I need a new battery. However, I can't figure out how to even find the battery, let alone change it! How do I do that????
Cutting down on the number of wires that must be tolerated in a work station adds to maneuverability and ease of location. For all their convenience, though, wireless accessories bring with them a number of issues not present in their wired counterparts, most significantly battery change.
Instructions
    • 1 Turn off the mouse.
    • 2 Remove the top of the top of the battery compartment. The button that releases it is located toward the rear of the mouse.
    • 3 Remove the old battery and place the new one in its place. Replace the cover and turn the mouse back on.
Read more: How to Replace the Batteries in an HP Wireless Mouse ' eHow.com http://www.ehow.com/how_6947071_replace-batteries-hp-wireless-mouse.html#ixzz1LpG7oNYf
May 09, 2011 | HP Wireless Optical Mouse
I need instructions on removing the cover to replace the battry.microsoft wireless notebook laser mouse 7000.
  • Press the "button with the star symbol" while prying up the top cover of the mouse's body to replace the batteries. If the batteries have power, the LED on the underside of the mouse will illuminate.
  • 2 Plug the receiver component into an open and working USB port on your computer. Your computer should make a noise when the receiver is connected, and the system tray will show that you have connected new hardware. Some USB ports may not be compatible, so it is important to try several ports to find one that works.
  • 3 Press and hold the "connect" buttons on the underside of the mouse and on the receiver for several seconds to refresh the connection. An interrupted connection will cause jerky or inconsistent on-screen performance of the Microsoft Wireless Laser Mouse 7000.
  • Read more: How to Troubleshoot the Microsoft Wireless Laser Mouse 7000 ' eHow.com http://www.ehow.com/how_6803319_troubleshoot-wireless-laser-mouse-7000.html#ixzz1K9LY5L4u
    Apr 20, 2011 | Computers & Internet
    How do i connect my wireless i.t.works optical mouse model MWO03 to my eee laptop windows 7?
    Follow these steps :
    1.
    Check to see if your laptop supports wireless technology (Bluetooth, 802.11 or other). If it doesn't, you will need a wireless receiver. If it does, verify that your laptop is compatible with your wireless mouse, which could use either Bluetooth technology or a radio signal.
    2.
    Unpack your mouse and open its battery compartment. The wireless mouse won't receive any power from the laptop, making batteries necessary.
    3.
    Add new batteries to the compartment. Make sure that the + battery end is inserted into the + niche in the compartment.
    4.
    Place the mouse where it is easy to use and least stressful on your fingers.
    5.
    Place your wireless receiver appropriately if your laptop doesn't support wireless technology. The receiver should be kept at least 8 inches away from the laptop or any other object that would cause any interference.
    6.
    Place the wireless receiver anywhere from 8 inches to 6 feet from the mouse.
    7.
    Insert the driver CD into your laptop and follow the instructions to install the software for running the mouse.
    8.
    Connect your receiver to the laptop by plugging in the mouse's USB connector to the USB port of the laptop. If you do not have a free USB port, simply use an external USB hub for more ports.
    Nov 07, 2010 | Computers & Internet
    My acer mouse model number mg-0919 stops working after about 2 minutes. I have to turn the mouse off then back on. This happens constantly. What is going on? Is it defective? My mouse is under...
    I had the same problem. This mouse came with my Acer Revo which was still under warranty. Tech support basically says to check the obvious (batteries, USB connection, RF interference). Their obviously canned answer goes on to detail a manual reconnect procedure that does not apply to this model. And when all else fails, get a new mouse.
    This is what Acer tech support emailed me:
    If you are experiencing issues with your wireless mouse not working properly, perform the following steps to troubleshoot the wireless mouse.
    1) Ensure that the receiver is 8-inches from other electrical devices. Avoid placing the cordless devices on metallic surfaces.
    2) Verify that the USB connector from the receiver is properly plugged into a USB port on the computer. Try plugging the receiver into a different USB port to ensure that the USB port is working properly.
    3) Remove the batteries and then reinsert the batteries into the mouse, making sure that the battery polarities are correct.
    4) Test the batteries to ensure that they still have a charge.
    5) Try the manual connect procedure.
    Manual connect procedure:
    1) Press and release the Connect button on the receiver.
    2) Within 30 seconds, press and release the Connect button on the mouse.
    If the issue persists, we can replace your computer's wireless mouse.
    We will ship the new wireless mouse within 3-5 business days.
    Before placing an order for wireless mouse we would like to confirm the following.
    1) Complete shipping address:
    2) email address:
    3) phone number:
    In order to place an order for wireless mouse, the computer must be registered.
    Oct 06, 2010 | Acer Aspire One PC Notebook
    Can't ope batt compart' 4 toshiba n554 wirelss mouse pa3573u-1eta
    press longer silver bar on top of mouse and pull top off from back
    Jan 01, 2010 | Toshiba Wireless Mouse PA3205U-1ETC
    I have an hp wireless mouse, and it doesn´t work!! Tried everything...
    Wireless device like the mouse needs a wireless connectivity to a computer like a bluetooth or a wireless receiver. Make sure that your mouse batteries are all working and the wireless receiver is properly plug into the USB(Universal Serial Bus) port of the computer. The wireless receiver don't need battery so you don't have to worry about it. The two both have a push button, press both buttons to activate the connection. Wireless connections has limit in distance so make sure that you are not too far away from the receiver while using the mouse and that is 9 feet or 2.7 meters so keep that in mind. When the cursor moves when you move the mouse, you have connected the mouse properly. If the cursor doesn't move, try repositioning the receiver. If it still doesn't work, you may need to restart your computer (if you haven't already) or reconnect everything.
    Hope this could help you a lot..:-) Thanks..
    Dec 27, 2009 | HP Wireless Optical Mouse
    Wireless keyboard and mouse not working, battery in receiver?
    The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
    Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
    Kennsington 72216 mouse continuosly clicking after changing batte
    try installing the software that came with the mouse. if none came with it then go to the manufacturers website and down load the drivers. if none available then there might be something physically wrong with the mouse and you replace it.
    If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
    Feb 28, 2009 | Kensington PilotMouse Optical Wireless...
    Hp optical ps/2 3 button wireless mouse
    have you tryed to reconnect it?
    I supose you put the same type of batterys in? same voltage and so on. it might be that the mouse doesnt get enought power.
    Apr 30, 2008 | HP Wireless Optical Mouse
    Mouse less than a month old, stopped working
    Hiya! Try using the buttons on the receiver and the button on the bottom of the mouse to re-sync them.
    Feb 17, 2008 | Logitech Cordless Mouse
    Dell Wireless Keyboard Optical Mouse w0147 Logo
    194 people viewed this question
    Alun Cox
    mukhtar21 shaikh
    mukhtar21 shaikh
