Wall heater does not work
I bypassed thermostat and shorted thermoswitch on regulator and how can i verify if ignighter is ok
  • 706 Answers
Hello drfixsit,
I can only make assumptions on your setup based on your description. I am assuming you are referring to a gas wall heater that has an electronic ignitor and that you shorted the thermostat wire leads together to simulate 'calling for heat' .. If that's correct, then here's a few things you can try.. If you can open the wall heater access panel to see where the burner is, you should see some kind of igniter there too.. Rather than short the wires at the thermostat, why not ,...make a wire jumper at the heater itself and short across the contacts of where that thermostat would plug in? By doing that, you take the wiring out of the equation.. A short across the thermostat terminals at the heater should turn th eheater on and call for heat.. If everythings working, you should get gas into the burner and the ignitor should provide a spark to get a flame established.. I hope I helped you.. if not.. please elaborate on whats actually happening or where I am wrong..
Regards,
Rick
Posted on Nov 29, 2008
My mazda protege is having a heating problem. The temp guage will go up to the normal place as the engine warms up but then when I drive down the road the temp guage goes down to below cold and then my car...
I believe the mazda protege has a separate thermoswitch to activate the radiator's fan. Perhaps the fan keeps blowing until the temperature is too low. Try replacing the fan thermoswitch. Just take care to put in tis place a thermoswitch of the same temperature range.
Nov 11, 2013 | Cars & Trucks
Overheat
Hi.
First check that exhaust, air ducts and filter are not blocked and free from lint. Make sure that the dryer has proper ventilation.
If there is no lint, there is proper ventilation and the machine keeps overheating, then either one of the thermostat is shorted or there is a contact in the wiring to the heater element.
A shorted cycling thermostat is quite a common fault. Testing is done reading impedance across the thermostat contacts. A shorted thermostat will read zero or an impedance smaller than 0.5 Ohms. If the cycling thermostat is shorted, the other thermostats in the heater assembly must also be tested.
If thermostats are OK check wiring to the heater looking for a contact that can keep the element 'hot' even when not directly energized from electronic control. Such fault is not common in recent appliance models.
If there is no problem concerning heater assembly you may have a defective control board.
Dec 15, 2011 | GE PFDS450ELWW Dryer
How do I short my thermostat?
If you are asking how to bypass thermostat to make heat work then remove cover plate from t-stat and remove screws that hold base to wall. Disconnect wires to Rh and W and jumper together. This should make heater run non stop. Thank you.
Dec 25, 2010 | Honeywell Programmable Thermostat Heater
F8 heat low it goes up to 494 and stops there
It generally is the IR Element that has gone bad. Look for burned wiring where the IR Element enters the oven cavity. Check for continuity through the IR Element.
1. Check that the blower motor is moving air.
o Blower motor is not moving air: Check blower motor assembly
and verify motor is stalled. Unplug oven and correct obstruction or
replace motor. (For access to motor shaft, remove top panel.)
o Blower motor is moving air: Verify high-limit thermostat is
not tripped. See the high-limit thermostat information below.
High-Limit Thermostat:
o Thermostat tripped: Reset and determine why the thermostat
tripped (See Figure 38, Item 114). Look for excess build up of
grease inside the oven or any other source for a fire.
o Thermostat is not tripped: Check main convection heater.
1. Convection heater is defective: Unplug oven and replace the
convection heater and verify the K4 SSR (Figure 37) is not
shorted across output.
2. Convection heater OK: Check the K4 SSR.
o K4 defective: Unplug oven and replace.
o K4 OK: Unplug oven and verify all wiring. Verify P1 voltage on
I/O board is 5.0VDC (+/- 0.02) -
Aug 28, 2010 | TurboChef TORNADO Electric Oven
I have a brand new Raypak heater. Pump is on
Umitherm governor (looks like an automotive thermostat) is bad or bypass valve defective. Both of these are in the header. You should have a manual bypass valve on the pool plumbing to regulate the flow in the heater. Try increasing or decreasing the water flow through the heater first.
Jun 18, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Dryer do not spin if thermostat is plugged
Ok. The model number pulled up a stack unit and a regular standalone dryer. Im refering to the standalone Dryer.
Your Temp control thermostat is located in the front of the blower housing in the front of the machine, part # 134048800
the thermostat that your jumping is either the thermostat on the heater housing, Part # 3204267
or the Thermal fuse on the back wall,
Part # 134120900
If you have not changed the Thermostat on the blower housting, this is why you have not solved the problem.
Make sure your heater coils are not shorting to ground as well.
Make sure to replace the thermostat that your jumping and the one on the blower wheel. and as always make sure you unplug the machine while you work.
Jan 08, 2010 | Frigidaire FSE748GF Dryer
3 amp fuse blows on ruud silohette II. With A/C off blower runs on manual OK With Heat on, gas heater runs OK, blower OK on Auto Disconnected relay wires at condenser and turned A/C on. Ran for a...
this sounds like an issue with the control wiring, there could be wires shorted togeher either at the thermostat, or in the wall, you need to isolate the wires at both ends then check for continuity with an ohmmeter there should be none) to verify which wires are shorted
Jul 19, 2009 | Heating & Cooling
Sta-rite pool heater SR333LP
This heater has a thermal regulator and a high limit that could be the problems. If it were a high limit that was bad, the display would show the error when the heater goes off. In the absence of an error, one would look to the regulator. A bad regulator would cause the water flow to bypass the exchanger and cause a slow heat. The part is easily replaced and runs about $90. It sort of looks like a car thermostat and also has a spring. It is accessed by removing the large black plug near the plumbing inlet/outlet.
Dec 16, 2008 | Sta Rite Sta-Rite Max-E-Therm High...
Gas wall heater
the thermastat is broke...replace and will work fine!
Nov 09, 2008 | Reddy R70ET Utility Heater
Heating & Cooling Logo
399 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
