Question about Technics SA-EX310
Problem with display
The amplifier works fine, however the display does not work at all.
There's a 'daughter board' mounted vertically on the mother board on the right end (when viewed from the front). Pull it out and clean the contacts on both the boards. Should rectify the problem. If not, check the power coming to the display circuitry/board.
Posted on Apr 14, 2007
Pioneer vsx 7500
Dead display? not a problem, as long as the sound is there.
Feb 15, 2014 | Audio Players & Recorders
NAD M3 power light turns red immediately and PROTECT message displays. Amp keeps functioning but volume control doesn't work up or down.
Hello
Check the connection to speaker with this amp, for any short or any other fault. disconnect the outputs, ie, speakers from the amp, and switch it On, and see the protect display comes or not. If it comes, the fault is internal and the set need service.
Your M3 dual Mono integrated amp, is of high output power and its outputs are protected against any overload or short circuit. If the system detect any among this condition specified above, it will show protect mode display.
Never load this amp, as protection display is there, as it may damage the speaker or its internal power amplifier section circuits, may cause more money to get it repaired. OK.
Jan 23, 2012 | NAD M3 Master Series Integrated...
I recently installed a sony explode in my truck everything works fine except for when u put a cd in, no sound and the display shows the cd is playing and all the function buttons work i just have no soud...
It sounds like you are using an amplifier. Make sure you are using the blue/white wire to turn the amplifier on. The blue/white wire is amplifier remote turn on and the blue wire is power antenna remote turn on. The blue wire turns off when leaving tuner mode, turning the amplifier off.
Aug 24, 2011 | Sony Xplod CD Player w/MP3 Playback...
CD will not play. The CDs goes in and out fine and looks like it is playing according to the display. I can change songs, fast forward and reverse through the songs according to the display but nothing...
Do you have the radio hooked up to an amplifier? If so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amp on. The antenna remote wire turns off when leaving tuner mode.
Jun 22, 2011 | Alpine CDA-7863 CD Player
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
CD player looks like its working but no sound. Quit during Play.
HI...CHECK TO SEE IF THE AMP IS GETTING POWER (REM) POWER-----(AMP)POWER--GROUND,, CHECK FUSES BOTH OF THEM--....YOU MAY HAVE DONE THIS ALREADY--CHECK TO SEE IF THE RADIO FUSE IS OK (POWER)..THE DISPLAY CAN STILL WORK FINE BECAUSE THE RADIO HAS 2 FUSES 1 FOR (POWER) AND ONE FOR MEMORY(DISPLAY) HARD TO SAY WITH OUT LOOKING AT IT.... GOOD LUCK
Feb 12, 2009 | Crunch BLX5520 Car Audio Amplifier
254 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
