Question about Toshiba Satellite A135-S4427 Notebook
Toshiba Satellite A135-S4427 Frozen
I've had this problem for a time now, whenever I turn on the laptop it loads the primary screen and along the bottom, there's a gray line that says "Press F2 for Set-up of press F12 for boot selection menu." No matter which option I press, it just says "Please Wait..." and never does anything. I've been unable to get past this screen, nor use the system recovery disk to do anything. Is there a fix for this, or am I S.O.L.?
  • 108 Answers
There is problem with the mother board try repairing at repair shop
Posted on Jul 22, 2009
Why aren't o i u keys working?
Try laying down a piece of paper, then carefully flip the laptop screen side down and tap gently along the bottom of the laptop with a plastic utensil to dislodge food debris then make sure there is jammed under the keys....if that doesn't resolve your problem you have the option of using Windows On-screen Keyboard by selecting Start Menu/Programs/Ease of Access when the keyboard pops up on the screen you can now use your mouse to type whenever you have an empty text box, Look for the Options Key located on the Bottom Right if you'd like to add a numeric keypad as well, just be sure to pin it to your task bar...last but not least, you can invest in a wireless usb keyboard and voila! problem solved Best of Luck!
Jan 07, 2016 | HP 2000-369WM AMD E-450 DC 1.65G4GB 320GB...
Macbook stuck on load up screen
When you say "load up screen", I assume you mean the Apple boot screen (it has the apple on a gray background).
You might try resetting the PRAM on the macbook.
You can do this by pressing and holding the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
So, turn the macbook completely off. Turn it on and immediately press and hold the Command-Option-P-R keys until the computer reboots and chimes. Once it chimes, release the keys. Your system should boot normally.
Jan 19, 2014 | Apple MacBook Pro Laptop Computer with...
White screen
Do you always shut down and unplug the laptop when not in use? Has it been cleaned recently? Fan, Vents, heatsink? Has there been ANY damage? It sounds like your Graphics Adapter. screen, Inverter, is going? Have to say exactly. Does the Laptop Overheat?
May 12, 2013 | Dell Inspiron 1545 Notebook
Lenovo z570 screen is getting grey lines problem
it may be the actual video cable going from the board to the screen which would make sense if you've had to have the screen replaced 3 times. the cable may have come loose, or it may have gotten damaged during one of the transplants. unfortunately the only way to test it is to either put it in an identical laptop or try a new one.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 18, 2012 | Lenovo ThinkPad® R50e (1842SRU) PC...
I have an HP compaq presario cq71-230sa. Laptop worked fine a few hours before, and then when I lifted the lid, the screen was black with 2 lines of white dots running down the left hand side, and the...
Can you check the function buttons and make sure the primary display is set to show the output on the laptop. Try repairing your OS. If not then re-install the os. As you are saying till the time windows gets loaded, all works fine so it seems the issue isn't really the hardware.
Jul 18, 2011 | Compaq Presario 700 470024-192 Notebook
A horizontal (2mm wide gray line) appears along my screen steady.
try plugging into an external monitor.. if the screen looks ok then it is most likely the laptop LCD screen is bad.. had the same thing on a HP laptop .. replaced the screen and all was well again with the world...
Dec 23, 2008 | Computers & Internet
Screen flickers and then turns gray
Access BIOS and test if the flickering continues.
If not, it is a Software problem, do a full system recovery
If yes, it is a hardware issue, better contact Toshiba tech support to have your LCD repaired if you are still in warranty.
If your not in warranty, you need to check out the LCD harness that might have been loosely connected.
Hope this helps...
May 12, 2008 | Toshiba Satellite A135 Notebook
Camera: Pentax S45 The top half of the screen is black with gray lines through it when turned on. When off the screen looks fine. Also turns off almost immediately after being turned on, despite...
my camera has a gray screen and a black line at the bottom right corner and you can not see any thing you are looking at. what do i do!!!!!!!!!!!!!!!!!!!!!
Apr 22, 2008 | Cameras
Laptop Toshiba M50-MX2 - Celeron M - Grid lines at the bottom of the screen
how do i restore my computer back to its factorey settings and deleat everything else
Apr 19, 2008 | Toshiba Satellite M50 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
295 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
