I am wondering what the best cable option is to hook up my new Samsung 50" Plasma 720 to my Direct TV HD/DVR Receiver
  • 320 Answers
Your best cable choice is going to be HDMI, but for heaven's sake don't be suckered into paying an enormous amount of money for an HDMI cable. Any good quality cable will work, you don't need a $100 MONSTER cable, because you won't see a difference in picture between the $10 cable and the $100 cable, regardless of what the sales person might tell you
Posted on Nov 29, 2008
No picture on Samsung HP-R5052
Just a couple of things to try:
You say you tried another cable box and a roku. Are you using the same cables? Are you using hdmi, component or coax cables? Could be a bad wire. True high def tv 1080 requires an hdmi cable for the best picture. The next best choice is the component cable. This is a triple cable with red, green, & blue and provides 720 resolution. The least quality is the coax wire which will only provide low def standard quality picture. Sometimes people hook up 1, 2, or all 3 of these choices not knowing what it all means. If thats the case with your tv it may just be a matter of selecting the correct input on your tv with your remote. On your samsung remote there should be a button for input. Try pushing that button and make sure it's set to hdmi or component, whichever your using. If none of this, is it possible the plasma tv itself is defective?
Apr 08, 2014 | Samsung HP-R5052 50 in. Plasma HDTV
Stuck on 480i with Panasonic HD Plasma
It sounds that a software update is necessary. Contact the service centre for Panasonic, to get the latest software to this model Plasma tv.
Jul 04, 2013 | Panasonic VIERA TC-P55ST50 55 in. 3D...
The other day my plasma was on and everything was fine. Connected to it is a charter DVR. Suddenly the picture and sound went out. I have a PS3 also hooked up to it and it displays and sounds fine. I...
Most likelly it is your DVR that has a problem. Their are a lot of issues with those DVR's from the cable or satellite companies. I would recomend swapping it out.
Jun 08, 2011 | Panasonic TH-50PX60U 50 in. Plasma HDTV
I have an HD PVR (Explorer 8300) and have connected to my Samsung TV using HDMI cable. My question is can I connect my SONY STR DE605 receiver or do I need a new one?
Depending on your tv output, you shpuld be able to hook your TV to receiver via audio output. Running your video components through your receiver will not give you the best performance anyway. Run your HD DVR to TV the way you have it then, if it's possible to run audio out from TV, via, RCA, digital optical, etc., to your receiver. The sound will be transfered through the TV. You may also be able to utilize component out from your HD DVR and a separate audio cable.
May 22, 2011 | Sony STR-DE605 Receiver
Just bought the Samsung 550 Plasma Hd Tv can you tell me if we just use a regular cable from the wall to the Tv will the picture quality be sort of off.. WE have an HM MI cable from the cable box to the TV...
unfortunately cable does not give you the best quality picture and "fuzziness ' is the reduced resolution being displayed on the tv.
the easy way to check the picture quality is to get a decent hd antenna and scan using it for free hdtv signals, if these are also fuzzy, on all channels then the tv has a problem but if it is only on a few lower resolution channels then its just the way it is until everyone is hd 720 or better.
Jan 31, 2010 | Samsung 50 in. Plasma TV
I just bought a 50" LG tv plasma and its supposed to be a 720....
Well it depends on what your watching on the tv. If you hook up an HDMI cable with a dvd player or other accessory, such as HD cable box on an HD channel it will swap to 720p.
Aug 04, 2009 | LG 42PC1DV 42 in. EDTV-Ready Plasma...
I have a HDMI cable hooked between my Direct tv DVR receiver and my Samsung flat screen HD plasma tv. When I turn to Direct tv channels 100 or 200 the screen begins to flicker. My tv is 1080i. This is what...
If the TV just Flickers for a few Seconds then the Picture is Good and Stable, That is just the HDMI re-syncing often due to different signals from 480i to 1080i being broadcasted. If it continues to Flicker then check the options for Video set-up in your DTV menu. Make sure all available resolutions are checked to display or select AUTO if possible. TIP: NEVER Unplug or Plug in HDMI cables with the Power ON. This can Short out the HDMI Input leading to a Repair. Turn off All Units then plug in your cables, When ALL are in then hit the Powers.
Apr 28, 2009 | Denon AVR588 Receiver
Don't want to use receiver to turn Plasma on via Verizon DVR
You can not have a signal from cable/satelite TV when reciever is OFF.The only way is reconnect by using defferent setup configuration to illiminate the receiver.In that case you well see just regular Tv program but you should connect antena to your TV.
Apr 17, 2009 | Onkyo TX-SR705 Receiver
No Video
have you gone through the menu to assign which signals the receiver recognizes?  I had to change the source when i switched to the Dish Network HD receiver.
Aug 24, 2007 | Pioneer VSX-1016 Receiver
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
