Question about Garmin GPSMAP 60CSx
How do I get my Garmin GPSMap 60Csx to work with C-map software
Hi, I have a Garmin GPSmap 60Csx and an Inspiron 1300 laptop without a serial port. When I connect the gps, via USB, to the laptop and start the c-map navigation software, I get the message 'COM 3 not found'. I have looked in devices and there are no ports configured. I go into the bios and cannot see how to turn on com 3 - if it is indeed there! I have downloaded some trial virtual serial port software apps and (using the basic setup) have configured 2 virtual ports. I can then see com 1, 2 AND 3! I then enter the configuration utility for c-map and no matter what com port I select, the software still does not recognise the gps. Unfortunately, I don't have the skills to try and reconfigure the virtual ports, even if this would, indeed, work. The garmin help for their unit is of no use whatsoever, I can't find any online help for c-map so any help here would be greatly appreciated. Thanks, Russ
  • 3 Answers
Make sure your usb ports are turned on in cmos and also make sure that you do not have them set to power saver mode
Posted on Nov 22, 2007
  • 944 Answers
Try posting the problem listing your virtual port software or the laptop itself as the product, you may get many more experts taking a look. Other than that, one thing to try would be to set it up on a machine with a serial port, and if you can get it working see what all the settings are - it may give you some clues. I used to use C-map years ago, so probably now much different, but we often had unrecognised port problems that usually meant two or three restarts before it would pick up the port (this was without changing any settings). Maybe they cured this in the last few years, but the best answer I got back then for why it happened was bad software code in c-map, never bothered to try the later versions. Hope this helps a bit :)
Posted on Mar 26, 2007
Compass will not caibrate
Garmin GPSMAP 62 - Initial Setup - Calibrate Compass ...
? 7:27
https://www.youtube.com/watch?v=OG7uVh2kQ24
Nov 9, 2010 - Uploaded by Jim Cyr
have owend 3 garmins. will be using handheld for biking. this looks like fast map ... Anyways, your review was decent, just don't know if I like garmin (possibly not). .... Compare Garmin GPSMap 62S vs Garmin GPSMap 60Csx ...
How to Reset the Garmin GPSMap 62 Series Handheld ...
? 1:23
https://www.youtube.com/watch?v=v-M7Ev6YTcA
Jul 20, 2012 - Uploaded by GPSCity
GPS City will show you how to RESET your Garmin 62 series GPS back to factory default settings. Back up all ... -My GPSMap 62s will not track satellites! -Forgot what ... -My barometric altimeter will not work or calibrate.
[PDF]GPSMAP® 62 series - Garmin
static.garmin.com/pumac/GPSMAP62_QSM_EN.pdf
Jan 04, 2016 | Garmin Gpsmap62s Hand Held Gps
Keeps restarting
try useing the webupdater at garmins website to upgrade the software on your gps, this may solve the problem let me know if you need further assistance.
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Jun 12, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Using dnr garmin or map source how do I transfer from excel
I've just had to do this. Somewhat annoying and I'm sure there must be a quicker way. Let me know if you find one. <br /><br />Firstly you need ArcGIS or something that can create .shp files. Load the Excel file into this. In Arc you need to right click the table and display the x y data (just to make sure it's all okay). Then save as a layer. Then export as an .shp file. <br /><br />You can the open the.shp in DNRGarmin and upload to your GPS..,<br /> <!-- from fixya rte -->
Jan 13, 2010 | Garmin GPSMAP 60CSx GPS Receiver
How to Transfer Maps to GPSmap 60csx
You have use the unlock wizard to install the key that is provided with the software. When I bought my Mapsource CitySelect, it came with two keys. The way Garmin does it is, you can install the software as many times as you want on as many machines as you want, but can transfer the maps, data, etc ONLY to unlocked devices. Last I checked Garmin wanted $75 for additional unlocks. Some data is not locked, like Topo maps and some tide points since this data is obtained (by Garmin) from the gov't, which is free for us (wel, minus taxes we pay). Contact Garmin support, they are very attentive.
May 29, 2009 | Garmin GPSMAP 60CSx GPS Receiver
I have cganged settings on my GPSmap 60CS and it now display only waypoints and not complete tracks. Can anybody out there advise?
On the Map page press Menu. From the options shown choose Setup Map. Go to Track tab and make sure Saved Traks is not set to OFF.
Jan 12, 2009 | Garmin GPSMAP 60CSx GPS Receiver
Can not updait a GARMIN GPSMAP 60CSx
Try http://brilliantcorners.org/nodes/87-fixing-a-dead-garmin-gpsmap-60csx. It has helped many people. Complete steps to fix a dead Garmin are listed there.
Dec 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Garmin GPSMAP 60CSx
I think all the Garmins allow to do is generate a waypoint list on your PC and upload THAT to the GPS, according to what Garmin told me about my Streetpilot C340. You also need Mapsource on the PC.
Mar 31, 2008 | Garmin GPSMAP 60CSx GPS Receiver
Have you highlighted the section with the map select tool, then hit the Transfer to GPS button? If you do, what happens then? Does it freeze?
If you are able to send routes and waypoints to the unit, you should be able to send selected unlocked maps as well.
Dec 31, 2007 | Garmin GPSMAP 60CSx GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin GPSMAP 60CSx Logo
586 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
